  1. noorbeast
    153,710Coins
    In Interface Settings it should be:
    [A<Axis1a>][B<Axis2a>]
    Also MMs must have cooling, or you will damage them.
    Here is the SimTools manual: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Axis % totals should be around 100% for all allocated axis: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    See here for tips on how to refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  2. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Aleluya!!!! My Friend!!!
    it was the B<axis2a>
    Thanksss!!! Again!
    ‍♂️‍♂️‍♂️‍♂️‍♂️ Works great!
  3. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Other question, where in the manual say the correct output write?
    I cant finde where need to use [ ] and define the second axis to a B uppercase.
    i see <x> 1a <x> 2a
    for under stand .
    Thanks noorbeast.
    153,710Coins
  5. XaviAlonso
    XaviAlonso Member
    España
    103Coins
  6. kevinmarz
    kevinmarz Member
    346Coins
    power help please....I Put together the first board set up,for a 12 volt wiper motors test,motor were to weak for anything I wanted to do with them..but it got me going with the basic understanding on how things work,(good Thing) I since upgraded to 24 volt wheel chair motors...running on the same set up...i,m a noob...haha..my voltage test shows,12 volts going in to motor board..then when I test on the motor side, it get,s a max of 8 volt while Sim is running...(game on)...feels way under power...My question is...How can I use two power supplies to increase voltage...
    153,710Coins
    I suggest a 24v controller, like the Sabertooth, and 24v led PSU which are pretty cheap on Ebay.
  8. kevinmarz
    kevinmarz Member
    346Coins
    So,I guess i,m starting over..and getting sabertooth..motorboards..I,m cool with that..is there a wiring diagram for the sabertooth for a 3 dof..I was looking @ amazon for a 24 volt power supply is 600 watts good enough or will I need more...I,m still going with 60:1 and the motors you suggested ..thank you..
    153,710Coins
  10. Martin.Berger
    Martin.Berger Member
    216Coins
    Hi Guys,
    back again. I´ve a stupid problem. After a systemcrash i´ve lost my Arduino Code for SNC3. Does anyone have the code for download?
    My setup:
    Arduino Uno3
    Motormonster
    Thanks to all
    Martin
  11. Martin.Berger
    216Coins
    My detailed problem ist the following Respons when i check the code or upload it:
    Any ideas?
  12. BlazinH
    16,688Coins
    Assuming you downloaded the latest sketch from the first post of this thread and didn't modify it the only thing I can think of right now is to check that you have Uno selected as your board in the programmer. If that doesn't work try using a different Uno.
  13. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    I'm having a problem with Arduino serial port disconnecting. In order to fix it I keep having to exit the sim, kill the Game Engine then unplug and reconnect the Arduino then relaunch Game Engine. It's really annoying, anyone here experience this or know how to fix it?
    153,710Coins
    In what circumstances is it happening, a car crash or something else?
  15. getti
    Canada
    45Coins
    It disconnects before I enter the SIM but I have no idea so when I start driving it doesn't move.
  16. noorbeast
    153,710Coins
    Any error messages?
  17. getti
    Canada
    45Coins
    No error messages.
    The only way I can tell beforehand if it's working or not is to go into output testing before entering the SIM. If it's disconnected I'll just get a beep.
    I've been going into output testing before launching the game to check if it's working or not.
  18. noorbeast
    153,710Coins
    Have you tried swapping usb ports and cables?
    What about Windows logs?
  19. getti
    Canada
    45Coins
    Yes I am using a different cable now and I've tried different usb ports. I have not lo
    Yes I'm using a different USB cable and tried several different ports.
    No, haven't looked at windows log, where do I find that, what am I looking for?
    153,710Coins
    Click on Windows start button and search for Event Viewer.
