Showroom ODrive Turnigy 190kv BLDC 6DOF - Here we go again
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Oct 12, 2019.
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    4,964Coins
    Hey bud, I see you are using PLA filament.
    Have you ever tried PETG? It is more resistant and is a little more flexible than PLA (PLA will break easily on small part that you try to flex, but PETG will tolerate more).
    I have a lot of 3d printed part on my rig and PETG last longer for me.
    Only downside, it is a little harder to print than PLA. (at least on my ANET A8)
    You may want to try if you haven't yet.
    Just my 2 cents.
  2. SilentChill
    20,567Coins
    I'm using "PLA Plus" supposedly as strong as PETG but soo much easier to print with not as flexible but not brittle like normal PLA
    I did try PETG did a couple of spools but didnt really take to it
  3. SilentChill
    20,567Coins
    Because all my 3D printed parts are building blocks, child is there for size reference. @Pierre Lalancette he is 7 and half years old just so you know 20191207_194231.jpg
    • Funny Funny x 3
  4. pmvcda
    15,372Coins
    Liar, by the clothes, it's an elf, they are smaller! :p
    So is this going to be wood again?
    Edit:... elf or gnome... where is my English dictionary...
  5. SilentChill
    20,567Coins
    Haha yes Elf !!
    The base will be wood but the frame aluminium, the top wood frame is just temporary to see how big its gonna be and decide how I'm going to build my frame as I have not designed it yet.
  6. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    Hi Craig
    I think you have given the secret away now mate as to being able to build a great sim in such short time, you just need to get the elf's to help lol.
    No seriously I see on your parts list there is 15 meters of 30mm aluminium box section (guessing this is for your frame). I was just wondering if you were going to tig weld the joints as i cant see you using nuts and bolts ect. If you don't have a tig welder and was going to pay to get it done then I thought you might try the aluminium flux cored rods.
    you would probably have to v out the ends of the box fairly well and maybe use some gussets in places but you could build the whole frame for a sim with just a hacksaw, file, wire brush and a gas torch and should be strong enough for sim use.
    I would build the whole frame out of 30x30mm timber (same as the aluminium box section) using superglue and activator for quick drying on the joints. get the frame/platform working with sim tools as your motors would prob break the frame if something isn't right rather than something more expensive. Once you feel the frame is right then re make the frame in aluminium box using the timber one as a drawing/example.
    Im sure a man of your sim building experience has already got all this worked out but just tryin to help a fellow uk sim racer out.
    Matt
  7. SilentChill
    20,567Coins
    Great minds think alike ! That's exactly how i'm doing it ! :D
    I have bought some brazing rods and some gas, I'm really hoping it will work because I wont be able to fit the frame down into the basement if I have it TIG welded by someone
  8. SilentChill
    20,567Coins
    • Winner Winner x 3
  9. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    3DOF, DC motor, Arduino, 6DOF
    7 and half years old or an elf, they are about the same size. It's a good reference.
    Man, I was laughing my head off.
    Good idea to film a full build. It will avoid many questions in the future.
  10. gigi
    gigi Active Member
    912Coins
    2DOF, JRK, 4DOF
    Wow really a great job! .. Thanks for sharing it.
    Some questions...
    Do you put grease in the worm and also in the plastic part that flows and crawls in the actuator sheath? At the end of the video install the joint ... how do you fix it to the stem?
    Wich is the actuator excursion and what is its total length?
  11. JAD
    JAD Active Member
    Australia
    1,446Coins
    I once tried this welding with rods and gas but it didnt go so well for me.
    I used regualr propane and also tried the MAP gas which supposedly runs 30% hotter.
    But I really needed to mix with oxy to get the hotter flame for it to work. I didnt go with this in the end for various reasons.
    I havent watched the video and you may be already aware of this.
  12. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,748Coins
    Hi Craig,
    may I call you MASTER from now on? :grin
    I love your fantastic actuator design!
    I think if you manage to make a good working and reliable simulator with this 3D-printed BLDC actuator you will revolutionize the DIY - sim building szene. Great!! I love to see people walking an unknown road.
    Wish you a great success!
    :popcorn
    Wickie
  13. SilentChill
    20,567Coins
    No no, I've just copied you but in plastic, well kinda but yours inspired mine to be honest .
    Thanks for the compliments though :D
  14. SilentChill
    20,567Coins
    Finally we have 6 ! So much to do so little time
    • Like Like x 9
  15. thecures
    thecures New Member
    68Coins
    nice work !!! i like your actuator...but the stl file are available?.tks
    • Optimistic Optimistic x 1
  16. SilentChill
    20,567Coins
    Once I have it up and running and tested to make sure it's all strong enough I will share them, I dont want to waste anyone's time printing a failure
  17. thecures
    thecures New Member
    68Coins
    you're right...!!!!!
  18. wannabeaflyer2
    london uk
    8,320Coins
    hey @SilentChill enter expletive here , mate jsut saw your youtube vid part two ...Gobsmacked would be understatement . i knew you did not hang about . BUT DAMMMMM man theres progress and then there is warp-speed ...Gotta say mega well done good buddy . great work and progress .. im thinking your def a not let grass grow beneath feet sorrta guy thats fast work by any standard :cheers:popcorn
  19. SilentChill
    20,567Coins
    Part 2 :)
    • Winner Winner x 5
  20. SeatTime
    28,320Coins
    You don't stuff around, it's like you have built one before :).
    • Agree Agree x 3
