Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. yobuddy
    51,564Coins
    @Foehn,
    Can I see a pic of your sim buddy?
    Then I can help with some settings.
    Take care,
    153,992Coins
    +11,162 / 57 / -2
    @yobuddy means pictures of your rig, so he knows what configuration it is and hence can offer some setup advice.
  3. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    Try heave around 7 and sway also.
  4. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Using my SCN5 motion setup and Simdisplay Simr-DLX.
    Running SLIMAXmanager Pro, Simtools and F1 2019 DX11 in UDP=legacy mode through Sim Race Proxy Server works fine for motion. (Not for Simr-DLX display)
    Changing UDP to 2019 formaat works fine for Simr-DLX display but gives uncontrolled jerky motion.
    Does anyone has a workaround ?
    and
    Does anyone know if the 2019 UDP format can be changed to legacy within the Sim Racing Proxy Server ?
    regards,
  5. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    Same happens with Simhub, Simtools and F1 2019
    any update on this?
  6. DoubleM
    Amsterdam
    - 23Coins
    Can you change the F1_2017 Plugin to look for target F1_2019.exe
  7. Mu-KwangKim
    South, Korea
    - 689Coins
    It seems to be the same as Windows local configuration problem.
    Control Panel-> Regional Settings-> Administrator Options-> Change System Local -> English (US)
    change it this ~
  8. nornesnaj
    Netherlands, Zelhem
    125Coins
    F1-2018 with simtools & simhub is running just fine.
    However i cannot get F1-2019 simtools & simhub to run together.
    tried everything i have read in the forums but no sucsess
  9. nornesnaj
    Netherlands, Zelhem
    125Coins
    There are no other apps running
  10. Trigen
    Trigen Active Member
    2,891Coins
    Not working in Simtools or PT mover. Simhub is receiving and my buttkickers are fine. Tried all options. Have completed a race and installed patch. Pt mver tried before patch and says show connecte but no data.
    Seems game engine and manager is not connecting properly and needs updating. The game is a mess though but seems to be the plugins that needs updating since simhub is fine.
  11. bruno1210
    bruno1210 schumi06
    103Coins
    UDP FORMAT legacy mode NOT 2019
  12. Renoboss
    297Coins
    2DOF, SCN5
    Hi Trigen,
    Only run in DX-11.
    UDP format has to be set at "Legacy".
    You will loose output in all other (Simhub / buttkickers)
    I tried everything to get it running but no luck.
    Even with "Codemaster Proxy Server" and "Sim Racing Proxy Server" it can not be done.
    Simtools needs to get an F1 2019 plugin for at least UDP 2019 compatibility.
    Sick of waiting and not being able myself to make a plugin i ended up buying Motion Max Manager Frex Edition.
    Runs like a charme !!!!
  13. bruno1210
    bruno1210 schumi06
    103Coins
    Hello again,
    I run simtools and simhub at the same time you just have to modify a file in simhub.
  14. bruno1210
    bruno1210 schumi06
    103Coins
    SIMHUB AND SIMTOOLS
  15. Trigen
    2,891Coins
    Got it working thanks.
  16. nornesnaj
    Netherlands, Zelhem
    125Coins
    Still not working only when i use the simhub F1-2017 i get some info but info like DRS etc still missing.
    and id will do nothing if i select simhub F1-2019. any more information ?
  17. bruno1210
    bruno1210 schumi06
    103Coins
    simhub f1 2017 works correctly in f1 2019 games with legacy telemetry and simhub works only with f1 2019 telemetry
  18. Newgun
    Newgun Member Gold Contributor
    77Coins
    AC motor, 4DOF
    Will we ever get the plugin with UDP 2019 using DX12?
    Hoping to use either SLImax Dash or Simhub dash, both of which works only with UDP 2019.
  19. ludo22420
    ludo22420 Member
    206Coins
    does the plugin work with ps4?
    153,992Coins
    +11,162 / 57 / -2
