Hannibal's thread into DIY motion platform
Discussion in 'DIY Motion Simulator Projects' started by hannibal, Feb 15, 2019.
  1. hannibal
    hannibal Active Member
    4,491Coins
    i guess this is where my next area of time will go.....
    thanks!
  2. thecures
    thecures New Member
    68Coins
    Hi hannibal...it's possible to have all material for replicate the actuator?...tks leoanardo
  3. hannibal
    4,491Coins
    some parts were 3d printer but others were hand made like the pot/belt pulley assembly i think its easier to follow @wannabeaflyer2 or @SixDegreesOfFlight plans. i more of a paper calculations guy, so i dont have alot of it digital, rather on scribble scrap paper
  4. hannibal
    4,491Coins
    i am running through the 6dof gauntlet and learning the hardway
    something was off, and after my hard trip, i discovered that it ate the anti wobble ring..
  5. hannibal
    4,491Coins
    after repairing broke anti wobble, i realize i have to stop messing around on actuators with power applied.
    need to spend time away from hardware and understand more about tuning settings and the interfaces.
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    3DOF, DC motor, Arduino, 6DOF
    When everything fail, read the instructions.
  7. dureiken
    dureiken Active Member
    1,248Coins
    Hi @hannibal
    thanks for your thread and all details !
    I am trying to design my own 6DOF and linear actuators inspired by you and @Dirty mainly.
    What are final specs of your actuators ? (stroke, carbon tube outer/inner/length) and how do you joint ball nut and carbon ?
    THanks a lot :)
  8. hannibal
    4,491Coins
    i attribute my actuator build and design from @SixDegreesOfFlight @wannabeaflyer2 (the crazy tinkerer that likes to talk about bears lol) and @SilentChill (the 6 Dof freak.. :) )
    my actuator spec is i set it for 11" stroke (could be more but im not going to push it)
    using 500mm v slot 20mm x 60mm for the structure
    carbon tubes are 500mm , with 25mm OD, and 20mm ID (other guys went 22mm/23mm..i thought that was thin)
    25mm linear igus bearings.. (do not go steel bearings, i had my carbon tubes scratched) (go alibaba for 15$ a piece, unless u want to pay 60$ a piece from igus)
    powered by E30-400 ampflow motors.. ( i been told its overkill, the E30-150 is feasible)
    i am using 9mm 3d printer belts with GT2 pulleys.
    custom hand made aluminum pot & pulley fixture with bournes hall effect 3600 degree 10 turn pot (36 $ a piece, if you going to make your own actuator, dont go cheap, u lose at the end)
    how i attached the carbon tube is that i epoxied to the nut housing that comes with the ball screw (sfu1605 type ball screw), but put a 3d printer 3/4" spacer so that i have more surface area to epoxy the nut housing to the carbon tube with $$$ 3M 2216 A/B flexible epoxy. (photos a few pages back)
    good luck.
    welcome to 6 dof, be on our team
  9. dureiken
    1,248Coins
    thanks for your answer.
    My 1605 nut is 28mm diamter, how do you put your 25/20mm carbon in ? :)
  10. hannibal
    4,491Coins
  11. hannibal
    4,491Coins
  12. dureiken
    1,248Coins
  13. hannibal
    4,491Coins
    happy new years.
    im still working on my 6dof.. but at snails pace.
    trying to finialize controller positions before i take down frame for additional welds 20200111_205054.jpg 20200111_145552.jpg
  14. hannibal
    4,491Coins
  15. hannibal
    4,491Coins
  16. hannibal
    4,491Coins
    protective table... 13inches high.. i hope its not too high to hit actuators.. 20200118_190048.jpg 20200118_190056.jpg
    • Like Like x 5
  17. SilentChill
    20,586Coins
    And a mop bucket !
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,053Coins
    Man, so much time is spend to make it look beautiful.
  19. hannibal
    4,491Coins
    thank you @Pierre Lalancette @SilentChill .. i just hope it will work, i feel like im almost building a tank.. i see both of you guys are going for mimimalist with lightweight materials..
  20. hannibal
    4,491Coins
