Andreas Ewe
Aerofly FS 2 Plugin 2.1.1.0
SimTools plugin for Aerofly FS 2
  1. slipstream
    slipstream Airborne
    508Coins
    But it’s not necessary to have it as part of a motion plugin.
    What I have been trying to explain is that air turbulence is an invisible force, you cannot see it. Therefore there is no reference frame. There is no requirement to link it to any flight sim.
    It could be an additional plugin named ‘turbulence effects’ that would randomly provide force to the actuators giving the realistic effect of turbulence.
  2. SeatTime
    MFS2020 will map turbulence and their effect on the aircraft at a thousand points across the flight surfaces based on the actual weather, ground and buildings. But yes, you could generate sudo-random data for a simulated turbulence. A developer would just need to implement it if he thought it necessary. None have at this time.
  3. volker metzger
    volker metzger New Member
    - 725Coins
    Hello, @yobuddy can you ask ipacs to send you the new sdk dec 2019, they said the will send the new sdk to developers who are intersted in, maybe with this sdk a working plugin is possible, the sdk is not offical released its only for developers
  4. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    Hi, just wondered if you’d had chance to see what the new SDK offers?
    https://www.aerofly.com/community/filebase/index.php?file/2-sdk-tools/
    153,770Coins
    +11,149 / 57 / -2
  6. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    I haven’t downloaded it. I do suspect that it is more about modelling, but my technical skills are not up to inspecting its capabilities. I emailed Torsten at IPACS and asked him if it would address the telemetry issues but got no reply.
    153,770Coins
    +11,149 / 57 / -2
    I suspect the non response pretty much answers your query :(
  8. SeatTime
    Let's hope MS FS2020 is not so hard headed. I have not used, or purchased anything for FS2 since telemetry was dropped.
    153,770Coins
    +11,149 / 57 / -2
    MS FS2020 has been publicly demoed on a motion sim, supposedly running SimTools, so fingers crossed the early signs are good it won't go the way of FS2, which I have now uninstalled and regret buying: https://www.xsimulator.net/communit...-new-flight-simulator-2020.13500/#post-190071
  10. SeatTime
    Yes, I should also uninstall it and free up allot of storage space, as I have the game + 8 DLCs. What a waste of money..:rolleyes:.
  11. Andreas Ewe
    Andreas Ewe New Member Gold Contributor
    Germany, Hessen
    225Coins
    Hi Andreas here
    Because this plugin doesn't seem to work anymore, I looked at the SDK for Aerofly FS2 and wrote a new GamePlugin. It delivers Roll, Pitch, Yaw, Surge, Sway and Heave via UDP Packages.
    Everything is working well here with my DOF reality P6, but I'm new here and it's my first plugin for motion platforms and vb.net, also it's not my main coding language. Anyone interested in testing this?
    Download my plugin here:
    http://www.ewe-software.de/downloads/sonstiges/Aerofly_FS_2_GamePlugin.zip
    Download the sourcecode here, if you wish:
    http://www.ewe-software.de/downloads/sonstiges/sourcecode_aerofly_fs_2_gameplugin.zip
    http://www.ewe-software.de/downloads/sonstiges/sourcecode_aerofly_fs_2_gameplugin_telemetry.zip
    It based of the plugin sample code by yobuddy. Thanks yobuddy!
    Happy flying :)
    • Winner Winner x 3
  12. Imeleon
    Imeleon Member
    Construction Engineer
    Chippenham UK
    - 44Coins
    2DOF, SCN5
    Just tested it. Thanks for this. Works well with my 2 scn5 simxperience set up.
    A bit juddery first off so added 10% smoothing to roll and pitch (I only tend to use those 2 with just a seat mover)
    Forgot to patch game first of all so thought it wasn't working.
    Been a while since i added a game.
    Good stuff. thanks again.
  13. SeatTime
    Nice :thumbs, although has the issue with slow data updates from the game/SDK been fixed?
  14. Andreas Ewe
    Germany, Hessen
    225Coins
    It looks like, but I never downloaded an previous SDK version. So I don’t know. Also I used there external_dll sample code and coded my own dll which sends UDP data to the GamePlugin dll. The update rate for this is roundabout 10 times per second.
  15. Andreas Ewe
    Germany, Hessen
    225Coins
  16. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
  17. J-1775
    J-1775 Aviator
    1,588Coins
    Hi Andreas and welcome here. And thanks for the plugin ─ what a way to introduce yourself!:cheers
    I'll certainly give it a try. Though I must confess I don't see me fly AFS2 much more once FS2020 has VR support. The only reason might be FPS. Only a couple of days ago I was accepted as Alpha tester and have only a few hours flying time in FS2020. But AFS2 now looks, kind of, how shall I express myself... ridiculous? No traffic, all waters as STILL satelite pictures, the LEGO buildings in non-DLC-zones...
    But allow me a quick question: can you code in C++? You can get a rich man ;) if you can fix and expand OVRIE and maybe even help us for a completly new solution! Please head over to this thread.
    Greetz.
  18. kevinmarz
    kevinmarz Member
    346Coins
    I couldn't get it to work...I unpatched the game ...drop this new plugin into plugin tool... got nothing..any help? never did get to the fly the Heli? :)
  19. J-1775
    J-1775 Aviator
    1,588Coins
    Silly question: did you re-patch it?
  20. SeatTime
    It worked for me - did not do anything special.
