value1
Assetto Corsa Plugin 2.0.7.1
SimTools plugin for Assetto Corsa
  1. katsu713b
    katsu713b New Member
    - 78Coins
    SCN6, 4DOF
    Hello.
    Please support the Japanese version of ASSETTO CORSA.
    It works just by adding `acs_dmm` to the process name.
    Thank you.
  2. value1
    14,270Coins
  3. katsu713b
    - 78Coins
    SCN6, 4DOF
    @value1
    Thanks for the great response!!!!
  4. HASAN1453
    HASAN1453 Member
    Vr arcade owner
    VANCOUVER
    424Coins
    2DOF, 3DOF, Motion platform
    Hey guys. It’s been a long time, I sold my dof reality p3 long time ago. Now I have yaw vr. Not sure if you guys know about it but anyhow I was trying to play AC but with new updates did the patching change, I don’t get any movements or readings. Maybe I am forgetting something. Would you guys remind me one more time how to patch AC please? Thank you
    154,502Coins
    +11,184 / 57 / -2
    You can grab the SimTools manual here, which covers patching and all the fundamentals: https://www.xsimulator.net/community/threads/official-simtools-user-manual.12424/
    Once you have motion here are some tips to refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  6. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    I play AC on PC patched the latest pluging but it not connecting it stays green.
    do i need to install anything else. F1 series - RF2 - Dirt2 all working.
  7. nornesnaj
    Netherlands, Zelhem
    125Coins
    Solved its working now did not change anything. It just toke some time (drive more rounds) before it worked.
  8. yobuddy
    51,667Coins
    Hi @nornesnaj,
    It looks like the game was not patched in the pic above, that why it did not startup.
    (See the little red bar next to the word "patched" in the upper right?)
    Just something to check for future reference.
    Glad its working now thou, take care!
  9. Morket
    Morket New Member Gold Contributor
    52Coins
    Hi. With this plugin I have a problem. When I accelerate and brake my simulator does the opposite effect. In the right and left corners it works well, but the forward and reverse movement does the opposite. How can i fix this? it does not work like this with pc2 or f12016
    Hola. Con este complemento tengo un problema. Cuando acelero y freno, mi simulador produce el efecto contrario. En las esquinas derecha e izquierda funciona bien, pero el movimiento hacia adelante y hacia atrás hace lo contrario. ¿Cómo puedo arreglar esto?
    154,502Coins
    +11,184 / 57 / -2
    The DIR checkbox orange or not in Axis Assignments controls which way an axis moves, so try reversing yours for surge.
  11. laserbeak43
    laserbeak43 New Member
    200Coins
    I've installed the plugin, how do I setup the Axis for 4 DOF? I've followed the settings from the AMC-AASD15A Manual, but some of the settings have the filter enabled, and those filter settings aren't listed.
    154,502Coins
    +11,184 / 57 / -2
    See the FAQ motion profile tips for a summary of how to expose functionality such as filters: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  13. laserbeak43
    200Coins
  14. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    Hello friends,
    I have a problem and I need your help ...
    Today I bought the asseto corsa on instagaming because it was on sale, so I installed it on Steam and everything was fine until there.
    The next thing was to install the pluig and then patch it. Supposedly everything is fine ... but the problem is that when opening the game the simtools does not detect anything "normally when it detects a game the window turns blue but now it does not change color ...
    my question is ... do you have to configure something? in game or on steam
    I hope you can help me, greetings !!!
    154,502Coins
    +11,184 / 57 / -2
    Can you please post pictures of all of your settings, including the Tuning Center while in an AC race.
  16. RENZOREY18
    RENZOREY18 Member
    46Coins
    2DOF, 3DOF, Arduino
    in the end if it worked but it is because of my lack of experience, this game unlike others only communicates when you are already in the race but well thank you very much for your quick response Greetings!
    :thumbs
  17. Scott clow
    Scott clow New Member
    - 17Coins
    4DOF
    Would it be possible to add Sway to Game Dash? I'm looking to mix Speed and Sway on the arduino side of things to provide different left/right fan speeds.
    Thanks!
  18. noorbeast
    154,502Coins
    +11,184 / 57 / -2
    That is one for @yobuddy to consider.
  19. yobuddy
    51,667Coins
    This will be eventually be built into the game dash for v3.
    I have a few ideas to make v3 GameDash allot better, but I was holding off chatting about it until I have the alpha version of v3 ready for testing.
    (v3 alpha will include all of the motion side of things and allot more, but GameDash and GameVibe will be built in after the alpha version of v3 ready.)
    Take care,
  20. dirk van O
    dirk van O New Member Gold Contributor
    - 49Coins
    will there be an other plug-in for Assetto corsa competizione or can i use this one?
