Question Arduino to ACS306 controller
Discussion in 'Electronic and hardware generally' started by Elizar, Jan 3, 2020.
  1. Elizar
    Elizar New Member
    129Coins
    SCN5, SCN6
    how do i connect the arduino uno to an acs306 controller. ive been using the SCM3 sketch for the arduino and changed a couple of pins but still does not work.
    the acs306 controller also has a direct usb cable but the motors doesnt work even if the preset in simtools is SCN or Serial.
    i attached a picture of the wiring and the sketch used below.
    153,830Coins
    +11,151 / 57 / -2
    I don't believe anyone has used the acs306 before, so you are the trailblazer in terms of how to make it work.
    I would suggest you post the specs for the acs306, that way other members may be able to make suggestions.
  3. Elizar
    Elizar New Member
    129Coins
    SCN5, SCN6
    here are the motors and drivers im using. i bought it from china.
  4. Thanos
    Electronics Engineer
    2,907Coins
    Hmm, you are trying to interface to a closed loop stepper? Its not that hard, but the same time would be impossible to make it work with SCM3 (PWM)... it needs steps and direction signals. And a position buffer process. And a way to calibrate home position...
    Also these steppers are noisy! Reminds me of SCN5...
  5. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    Can you give a link to those motors/actuators please
    153,830Coins
    +11,151 / 57 / -2
    If you click on a member's name you can check when they were last active, in this case a year ago.
