Analysis of a 2DOF motion platform
Discussion in 'DIY Motion Simulator Projects' started by Andrei14, Mar 4, 2019.
Tags:
  1. noorbeast
    153,986Coins
    +11,162 / 57 / -2
  2. Andrei14
    Andrei14 New Member
    183Coins
    Connected the PSU. Also did a first run in LFS, then patched it.
    After I patched the game, did some minor settings just to see how the motors will move with the game on. But I believe that I have to work more at axis settings. I find weird that after I take a bumper/corner in LFS the motors start moving after 2-3 seconds (sometimes doesn't move, but most of the time it moves with delay).
    I'll update the thread once I find the right settings :D
    And @noorbeast I know that you live in Australia, and I'm really sorry for what is happening there man. My thoughts and prayers are with you guys.
    153,986Coins
    +11,162 / 57 / -2
    Thanks for your kind thoughts. It has been a rough time for many Down Under, luckily the fires the closest to me is not an immediate threat, but are also not yet under control.
    There should not be a significant delay in your rig's response. Here are some tips to refining your motion profile, initially do one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  4. Andrei14
    Andrei14 New Member
    183Coins
    Nice that's what I was reading.:nerd
    Thanks for your kind support.
    If I will not be able to refine my rig, I'll ask for help here.
  5. Andrei14
    Andrei14 New Member
    183Coins
    Ok so I believe that it's time to update this post.
    So I bought a Logitech g920, and this week I started to build the frame.
    I will attach some pictures with the frame.
    I hope that today I will link the frames together with the motors.
  6. Andrei14
    Andrei14 New Member
    183Coins
    More pics coming haha :D
    I believe that I made a mistake, and I have to move the 2nd frame forward a little bit.
    Not sure yet about that.
    153,986Coins
    +11,162 / 57 / -2
  8. Andrei14
    Andrei14 New Member
    183Coins
    Yes the motors are isolated.
    I am following the RacingMat's design.
    The motors will be place at the back of the platform.
    153,986Coins
    +11,162 / 57 / -2
    I will be interested to see how it goes, as a car seat is much heavier than a race seat.
    Why is the seat mounted so high on the top frame? It is preferable to have the seat base as close to the uni joint as possible, otherwise it puts additional strain on the motors, as well as introducing some odd geometry.
  10. Andrei14
    Andrei14 New Member
    183Coins
    The seat didn't allowed me to modify it and make it lower.. That was a problem. I hope that the motors have enough power to move the top frame.
    If not I will search for another seat, lighter
  11. Andrei14
    Andrei14 New Member
    183Coins
    Hi, you were right ahhaha :D the seat is kinda heavy - but right now this is not a problem.
    I need to calculate the G force or at least to approximate it.
    Any idea how could I do it?
    Thanks a lot!
  12. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    first grab the grinder and lower the seat right down.
    then make a shorter motor arm (5-6cm center holes - this should be enough to feel good force and not to burn the motors.
    Good luck
  13. Andrei14
    Andrei14 New Member
    183Coins
    Yeah I need to redesign the whole thing - at least now I have a better view of how it should be. Anyway I will buy a lighter seat. This one have 20kg or something like that...
    The problem that I have right it is that I need to finish my thesis - and theoretically, I need to calculate the forces that acts on my sim and the G-Forces generated by the linear and longitudinal acceleration.
    I will work more at the design of it after I finish writing my thesis, which is very time consuming..
    153,986Coins
    +11,162 / 57 / -2
    These tools may be of use:
    SimCalc will give you a basic idea of design Vs physics tradeoffs, there is also a link to the underlying mathematical assumptions for SimCalc: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    The Axis Analysis App will give you a real time analysis of SimTools Axis Settings: https://www.xsimulator.net/community/faq/axis-analysis-app.282/
    You can also simulate a 2DOF simulator: https://www.xsimulator.net/community/faq/simulating-a-2dof-simulator.278/
  15. Andrei14
    Andrei14 New Member
    183Coins
    In the SimCalc Math Reference sheet, we have the formula for linear speed.
    I don't understand the value 0.10472. Can someone explain what it represents?
    Thanks!
  16. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    I am sure @Tim McGuire would be happy to explain the underlying SimCalc assumptions, when he has a free moment.
