Question About the conflicts between simhub and simtools
Discussion in 'New users start here - FAQ' started by wp8051, Aug 1, 2019.
  1. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    Excuse me, do you use SIMHUB software?
    I really like this software and want to use it, but I found that in some games, mainly CODEMASTER racing games, such as DRIT series, F1 series, when using SIMHUB, the seat can not move unless re-played The patch can move normally.
    I guess because CODEMASTER's racing game has only one UDP output channel, which can only be used by one of SIMHUB or SIMTOOLS. If one of them is given, the other one cannot be used. I don't know if my guess is correct.
    Like in a game like AC, the two software can run perfectly at the same time.
    So I would like to ask, is it only that I have encountered such a problem, or you are the same, but is there any solution? Let these two softwares work perfectly in all supported games at the same time?
    Thank you very much for your attention and reply.
  2. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    I think Simhub has a UDP pass through option. Does enabling that help at all?
    153,824Coins
    +11,151 / 57 / -2
    The issue is port conflict and you can port forward in SimHub in the Games tab.
  4. wp8051
    China
    224Coins
    Thank you for your reply, but I still don't know what to do. Can you give me some detailed operational advice? thank you very much.
  5. wp8051
    China
    224Coins
    If someone successfully runs both SIMHUB and SIMTOOLS in a CODEMASTER game like F1 2018 or DRIT RALLY, please let me know how to set it up, thank you very much.
    I really want to use the SIMHUB software, which is very convenient and simple. But SIMTOOLS is more important to me, and now I can't live without it.
  6. wp8051
    China
    224Coins
  7. wp8051
    China
    224Coins
    I have studied it myself. With UDP relay, now F1 2018 can run SIMHUB and SIMTOOLS at the same time, but I still can't make DRIT series. The UDP output of DRIT series seems to be different from F1 series.
  8. wp8051
    China
    224Coins
    I am done, so happy, now both the F1 series and the DRIT series can run SIMHUB and SIMTOOLS at the same time.
  9. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Can you please share the final solution, I am having a similar issue.
    trying to run F1-2019 simtools & simhub together.
    i have setup upd relai inside simhub.
    when i have F1 setup as legacy the simtools works but not the simhub dash
    if i use f1 setup 2019 the simhub dash works and my rig go's amok for 2 seconds and stops
  10. wp8051
    China
    224Coins
    You can try to install the latest version of SIMHUB, the UDP setting in the latest version has become easier.
    I don't have F1 2019, I only have F1 2018, but I think they are the same.
  11. nornesnaj
    Netherlands, Zelhem
    125Coins
    I already use the latest version. Please SHARE all the settings for F1 AND SIMHUB .
  12. wp8051
    China
    224Coins
    I have n’t played this game for a long time, I hope this information is helpful to you.
      48.2 KB
      852
      59.2 KB
      750
      596.3 KB
      771
  13. nornesnaj
    Netherlands, Zelhem
    125Coins
    oWith F1-2018 its working thanks
  14. jing
    jing Just like rally
    76Coins
    Hello, I encountered the same problem as you, DR2.0 can not run two software at the same time, I read your communication and made some settings and the result still failed
  15. wp8051
    China
    224Coins
    First download the latest version of SIMHUB, then find the DR2 game settings in SIMHUB, turn off UDP forwarding, or reload DR2 settings.
    Re-patch the GAME MANAGER, so it is basically OK. If you are not assured, you can find the hardware configuration file of DR2 and check whether the UDP port and IP address are set correctly.
