  1. dutiti
    dutiti New Member Gold Contributor
    - 230Coins
    Yes
    I tested the S100 and S000, S025 commands on another pc and it works, it comes from my pc, I must have missed a driver somewhere, I tested the 4 port usb card it didn't change anything .
  2. dutiti
    - 230Coins
    A very big thank you to Zed for your help, now with this code everything works perfectly:
    Code:
    #define FALSE 0
    #define TRUE 1
    #define BRAKEVCC 0
    #define CW   1
    #define CCW  2
    #define BRAKEGND 3
    #define CS_THRESHOLD 100
    #define BOTH 0
    #define LEFT 1
    #define RIGHT 2
    int inApin[2] = {7, 4};  // INA: Clockwise output
    int inBpin[2] = {8, 9}; // INB: Counter-clockwise output
    int pwmpin[2] = {5, 6}; // PWM output
    int cspin[2] = {2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13;
    // pwmMode - sets the PWM frequency, valid options as follows:
    // pwmMode = 0 will use 980Hz PWM, default mode which will work with all fan types, will cause coil whine if using a MM.
    // pwmMode = 1 will use 4kHz PWM, might reduce coil whine for blowers, use heatsinks on the MM - check MM temp at a low fan speed.
    // pwmMode = 2 will use 8kHz PWM, might be OK for blowers with active cooling on the MM - check MM temp at a low fan speed.
    // pwmMode = 3 will use 31kHz PWM, use with caution - not for blowers with MM as it will cause very high temps. Check MM temp at a low fan speed.
    // server fans - should be able to use pwmMode = 2 or 3.  If you are using the PWM control on the server fan, leave this at default 0.
    // if you have blowers with a monster moto, try pwmMode = 1 or 2 and check whether your monster moto temp at low speeds.
    int pwmMode = 1;        // value of 0, 1, 2 or 3 - modes 2 and 3 will overheat a Monster Moto if used with blowers
    // This just works with one variable from the Game Dash.
    int Speed ;
    int SpeedGameDash = 0;
    int bufferArray[4];
    int whichFan = BOTH;
    void setup()
       Serial.begin(9600);
       // initialize digital pins as outputs
       for (int i=0; i<2; i++)
          pinMode(inApin[i], OUTPUT);
          pinMode(inBpin[i], OUTPUT);
          pinMode(pwmpin[i], OUTPUT);
          digitalWrite(inApin[i], LOW);
          digitalWrite(inBpin[i], LOW);
       // disable timer0's interrupt handler - this will disable Arduino's time keeping functions such as delay()
       TIMSK0 &= B11111110;
       if (pwmMode == 1)
          // Set pins 5 & 6 to Phase-correct PWM of 3.9 kHz (prescale factor of 8)
          TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00); // phase-correct PWM
          TCCR0B = _BV(CS01);  // prescaler of 8, gives frequency 61kHz/8/2 = 3.9kHz
       else if (pwmMode == 2)
          // Set pins 5 & 6 to Fast PWM of 7.8 kHz (prescale factor of 8)
          TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM01) | _BV(WGM00); // fast PWM
          TCCR0B = _BV(CS01);  // prescaler of 8, gives frequency 61kHz/8 = 7.8kHz
       else if (pwmMode == 3)
          // Set pins 5 & 6 to Phase-correct PWM of 31.25 kHz (prescale factor of 1)
          TCCR0B = _BV(CS00); // prescaler of 1, gives frequency 61kHz/1/2 = 31.25kHz
       else
          // Set pins 5 & 6 to Fast PWM of 980Hz (prescale factor of 64)
          TCCR0B = _BV(CS01) | _BV(CS00);  // prescaler of 64, gives frequency 61kHz/64 = 980Hz
    void loop(){
    ReadDataNEW();
    if (whichFan == BOTH){
      motorGo(0, CW, SpeedGameDash);      //Motor1
      motorGo(1, CW, SpeedGameDash);      //Motor2
      if (SpeedGameDash == 0) motorOff(0);
      if (SpeedGameDash == 0) motorOff(1);
    if (whichFan == LEFT){
    if (whichFan == RIGHT){
    void motorOff(int motor)
    // Initialize braked
    analogWrite(pwmpin[motor], Speed);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t Speed)
    if (motor <= 1)
       if (direct <=4)
         // Set inA[motor]
         if (direct <=1)
           digitalWrite(inApin[motor], HIGH);
         else
           digitalWrite(inApin[motor], LOW);
         // Set inB[motor]
         if ((direct==0)||(direct==2))
           digitalWrite(inBpin[motor], HIGH);
         else
           digitalWrite(inBpin[motor], LOW);
    void ReadDataNEW(){
      // We need 4 characters - the command followed by three digits
      bool haveCommand = FALSE;
      bool haveStart = FALSE;
      while (haveCommand == FALSE){     // can't exit until have a full valid cddd command
                                        // where c is a valid char and ddd is a valid 3
                                        // character representation of three digits
        // Valid command always starts with an S (legacy for both fans), L (left fan), or R (right fan)
        while (haveStart == FALSE){
          while (Serial.available() == 0); // spin and wait for data
          bufferArray[0] = Serial.read(); // have data, read it
          if (bufferArray[0] == 'S'){  //S
            whichFan = BOTH;
            haveStart = TRUE;
          else if (bufferArray[0] == 'L'){   //L
            whichFan = LEFT;
            haveStart = TRUE;
          else if (bufferArray[0] == 'R'){   //R
            whichFan = RIGHT;
            haveStart = TRUE;
        // Now need the numbers - will just read three and throw them away if any don't qualify
        // if we unsynchronize, it will fail valid digits and go back to waiting for command char
        for (int i = 1; i < 4; i++){       // read and label each byte.
          while (Serial.available() == 0); // spin and wait for 3 characters to arrive
          bufferArray[i] = Serial.read();  // store as they come in
        // Check the numbers for validity
        if (isDigit(bufferArray[1]) && isDigit(bufferArray[2]) && isDigit(bufferArray[3])){
          // all are numbers - have a full cddd command
          haveCommand = TRUE;   // otherwise start over looking for a new and valid command
      // Now turn that into a number and clip to 255 - rely on Game Dash for proper scaling
      SpeedGameDash = ((bufferArray[1]-48)*100) + ((bufferArray[2]-48)*10) + ((bufferArray[3]-48)*1);
      //Serial.println(SpeedGameDash);
      if (SpeedGameDash > 255){
        SpeedGameDash = 255;
    void ReadDataOLD(){
      if (Serial.available() == 4)  {    //if 4 bytes available in the Serial buffer...
            int i;
            for (i=0; i<4; i=i+1) {       // read and label each byte.
               SpeedGameDash = ((bufferArray[1]-48)*100) + ((bufferArray[2]-48)*10) + // Take values 1-3.
               //Serial.print("You have set the Speed to a Value of:");
    [/QUOTE]
  3. Zed
    USA
    5,845Coins
    Well, another wow! It was a longshot that it would fix things but I’m glad it did! Excellent!
    What dutiti is talking about is a few of us are wanting to get “windiness” to work where we combine canopy position with RPM and airspeed to give the wind a bit more fidelity and have it follow other cues. Since we were looking into the plugin and working with the telemetry, I though about controlling the fans individually and rewrote parts of the Arduino fan code to add R and L to the existing S command. S commands still work and set both fans, but if any plugins add the capability for differential wind, it’s in there. Where I was going is in aircraft you can slip and crab too and not have wind always on the centerline. Mixing slip indicator angle into the wind speed and controlling the fans individually lets you mimic lots of aircraft situations.
    But while I was in the code I reworked the USB communications to include error checking to prevent bad commands and stay synchronized. I found I had to issue commands multiple times in the Arduino monitor program when testing but now it works every time. Apparently it fixed whatever was happening in dutiti's rig too.
    @dutiti - thanks for testing that and glad it fixed your issue!
    Here is where we were discussing windiness: https://www.xsimulator.net/community/threads/new-output-possibilities-for-dcs.10181/
    And if anyone is interested, I swapped for a new fan on the market that is a bit more expensive but they work like a champ and the fan noise is way lower. No separate power supply or Monster Moto needed. Dual ball bearings. No squeals or tics as with the bilge fans: https://www.xsimulator.net/community/threads/wind-simulator-fans.14124/
  4. Zed
    USA
    5,845Coins
  5. Wmacky
    Wmacky New Member
    21Coins
    I assume the zip file was deleted?
    153,716Coins
  7. Wmacky
    Wmacky New Member
    21Coins
    Thanks.
    Yeah, I see It's are being sold commercially now with kit. Ah well, Time to polish up my design skills ( OR grab an alternative from Thingverse.)
  8. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    I love the idea. I could use server fans. Can I use the Dash with DIY licence?
    153,716Coins
  10. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    well, $30 its superb price for all these features. Other softwares like simexperience = more than "twice price"
  11. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Hi Everyone.
    Would you be able to tell me what im doing wrong? Fan will not move and no voltage on the MM output.
  12. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    False alarm. MM was sending low values on A1B1. I have measured A2 B2. Connected fan and all works!!
    Version Alpha completed.
    Well done guys
  13. Trigen
    Trigen Active Member
    2,891Coins
    Could this be adapted to running motors in Torque mode for G helmet and other G systems?
    153,716Coins
    You can use SimTools motion features for G-Systems, its companion app GameDash is for associated peripherals such as wind simulation.
  15. cfischer
    Colorado
    2,807Coins
    You can use this code as is (im pretty sure) to move a motor in torque mode.
    But it would probably be better to simplify another sketch with more than one motor output and a better motor drive.
  16. Chipless
    Chipless Member
    146Coins
    Did you manage to find an alternative on Thingverse? If not, where did you see the commercial kit offering?
  17. Wmacky
    Wmacky New Member
    21Coins
    I did! As a matter of fact I had put this on the back burner until last week. I finished it all up, and printed a nice case I found on Thingverse. I velcroed it on top of the 20Amp flat Power supply, and It worked great. One of the forum members here made me a nice design for Seaflow air straighteners, and I have added those as well. To bad the other poster offered all those files publicly and ripped them away when he thought he could make a dollar off what he learned here. Bad Karma! Here's the case I found. https://www.thingiverse.com/thing:4428319
  18. Zed
    USA
    5,845Coins
    Here's that straightener for the SeaFlo fans... Wmacky used a bit of tape to tighten up the connection. Slips over the outside of the SeaFlo exit opening.
    @Wmacky - Hopefully the ID of the honeycomb exit area is correct now and matches the ID of the SeaFlow.
  19. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Hey guys. Will this software work with this motor shield?
    153,716Coins
    It would be easier to use SimHub, as that directly supports the Adafruit shield and will even write the code to the Arduino for you.
