Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. noorbeast
    153,728Coins
  2. Patte83
    Patte83 Member
    24Coins
    Thanks mate
  3. Che Franklin
    Che Franklin im alot brighter than i look.. Gold Contributor
    Cape Cod Ma USA
    593Coins
    i did that no go..
    i now have a sabertooth 12/32 Kangaroo 2x usb ttl
    as an integration expert all this plug this into that & use this software and this software WAY WAY to many variables..
  4. BlazinH
    16,689Coins
    The sketch on this thread doesn't support the Kangaroo though. And integration isn't difficult for most people when they use supported hardware and follow the step by step instructions.
  5. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    where do you have your dip switches set to also Describe is not used with a sabertooth ..to get the right baud rate you must ground the pin 13on the ARD on power up then turn off the power reconnect pin 13 to number 13 pin on the ARD and power it up again.. then your baud rate will be 115200...ive built many of these systems ..you must also change your com port settings to 115200 in windows device manager..
  6. Che Franklin
    Cape Cod Ma USA
    593Coins
    I tried all that.
    I’m pausing all work and ordering.
    At this point my “playseat” rig is cool but after looking at the projects on web and this sight
    I’m going to get worm gear motors to rule out this “ground-Isolation” issue.
    I have found the extruded aluminum rig I want.
    I also fly, so I’m looking for maximum movement possible yet with a small foot print. I’m going to leave the 2 Dof in my sons MF studio he can use it.
    What I need is a clear setup guide.
    I’m also look at others as far as SW
    You all keep saying step by step but I must be super slow..
    I also need info when I’m working on the project not 5 days later so this will prob be my last post
    I appreciate the help that has been given
    But copy and pasting the same response over and over is not “support”
    Honestly I feel a lil ripped off with this SW
  7. SeatTime
    To be clear, the vast majority of the people who gave you support have no affiliation with Simtools, nor do they get paid for it.
  8. Che Franklin
    Cape Cod Ma USA
    593Coins
    that my friend is what I'm saying...
  9. Patte83
    Patte83 Member
    24Coins
    Sorry to be a pain :p I got one more 2x32 Sabertooth card so now i got two. I am trying to run 3 motors now with two Sabertooth chip, i got two uno aswell...
    I am so confused how make this work. So i go to DEScribe and fix the bau rate on new card. "DONE" Now i need to figure out how to connect two arduino uno to gather..
    Do i have to connect : ground on one card to the other card and A4A5 to make this work or what shall i do Please is there a guide about this? Need help :p
    153,728Coins
    Hook them up individually as per instructions on first post then configure Interface Settings in SimTools with one Arduino and Saberttooth for 2 axis and the other one for 1 axis.
  11. Patte83
    Patte83 Member
    24Coins
    so i need 2 cables i guess ?
  12. Arazok
    Arazok Member
    Computer scientist
    783Coins
    2 USB cables: for each Arduino one cable. That makes 2 COM ports and each has its on"interface" tab in Simtools.
  13. Patte83
    Patte83 Member
    24Coins
    thanks alot its working super :)
  14. Squarebob
    Squarebob Member Gold Contributor
    Georgia USA
    70Coins
    DC motor, Arduino, 4DOF
    Well after 3 days I finally persevered and got the arduino and 2x32 v3 hooked up to a little motor and 6v battery. Per step 17 of the original post, when I increase PWMmax the motor will turn but the yellow line goes up as I increase it . The green line will move if I mess with the pot. Help.
    153,728Coins
    Is the pot connected to the Motor?
    Could you please post pictures of your settings and physical hardware.
  16. Squarebob
    Georgia USA
    70Coins
    Pics as requested. Turn up PWMmax and yellow line goes up. Wiggle pot and green line moves and MOTOR 1 turns to OFF
  17. Pit
    30,510Coins
    if the pot is not connected to the motor the motor must change the spinning direction when the feedback line of the pot is crossing the middle line in edit SMC /edit.
    ps: also messed it up lol
  18. Squarebob
    Georgia USA
    70Coins
    What a dum dum oversite on my end. I will get that sorted out tomorrow and give it another shot. Thanks
  19. TSHracing
    TSHracing New Member
    Canada
    299Coins
    Hi, I'm using SMC3-SPS , I had my systm working for a while then I had to dissassemble it to do some upgrades, but it took me about 6 months to get back to it (was too busy for it), anyway I have things back in place and I need to do PID tuning, so I have to use SMC3 windows utility, I'm getting an error when launching it stating that it can not comuniate with the port, I have the ini file edited with correct port nubmer, any ideas what to check?
    153,728Coins
    Is the correct port configured in the Arduino IDE settings?
