Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    Do you mean you are experiencing disconnects in things like crashes?
    If so dropping the Main Level % to something like 97% may help.
    However, if you still get disconnects then it is likely usb interference and/or PSU related.
    You can use clip on ferrite magnets and good cable management to help with interference: https://www.ebay.com/sch/i.html?LH_...sacat=&_sadis=&_sop=12&_udhi=&_udlo=&_fosrp=1
    To test for PSU related issues temporarily try a car battery, as that will handle current spikes much better than PSUs.
    152,541Coins
    +11,085 / 56 / -2
    So you only have a problem with Codemaster games, is that correct?
    152,541Coins
    +11,085 / 56 / -2
    The patch path is different for Codemaster games, dependent on Windows being 32 or 64 bit: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
  4. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Good morning, sir,
    I'm getting a weird reaction from SimTools V2.4 Pro.
    When loading Game Manager and Game Engine at Windows 8.1 startup, Game Manager and Game Engine do not recognize the license and the 2 applications are in Demo version after 2 Pop-Up windows are displayed.
    I close Game Manager Demo and Game Engine Demo.
    Then I launch Game Manager then Game Engine by shortcuts present on my desktop.
    By doing so, I have again the recognized license and I have Game Manager Pro and Game Engine Pro.
    Note :
    Is it normal to have 2 SimTools directories?
    C:\Program Files (x86)\SimTools and C:\Program Files (x86)\SimTools V2
    Previously I had SimTools V1.3 which was uninstalled to try SimTools V2 Demo
    Then after purchasing the license, I uninstalled SimTools V2 Demo before installing and registering SimTools V2.4.
    Texte original en Français
    Bonjour,
    J'ai une réaction bizarre de SimTools V2.4 Pro
    Lors du chargement de Game Manager et Game Engine au démarrage de de Windows 8.1, Game Manager et Game Engine ne reconnaisse pas la licence et les 2 applications sont en version Démo après l'affichage de 2 fenêtres Pop-Up.
    Je ferme Game Manager Démo et Game Engine Démo.
    Ensuite je lance Game Manager puis Game Engine par des raccourcis présent sur mon bureau.
    En procédant ainsi, j'ai à nouveau la licence reconnue et j'ai Game Manager Pro et Game Engine Pro
    Remarque :
    Est-ce normal d’avoir 2 répertoires SimTools ?
    C:\Program Files (x86)\SimTools et C:\Program Files (x86)\SimTools V2
    Auparavant j’avais SimTools V1.3 qui a été désinstallé pour essayer SimTools V2 Démo
    Ensuite après l’achat de la licence, j’ai désinstallé SimTools V2 Démo avant d’installer et d’enregister SimTools V2.4
    152,541Coins
    +11,085 / 56 / -2
    Has SimTools been registered: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
  6. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Thank you for taking an interest in my license recognition problem when running Windows 8.1 at startup.
    A) In order to deal with the simplest problem to check, can you tell me if it's normal to have 2 SimTools directories?
    I notice that in the 2 directories Game Manager and Game Enigine do not have the same size or the same version
    Product Version V2.4 for Game Manager and Game Engine in C:\Program Files (x86)\SimTools
    Product version V2.31 for Game Manager and Game Engine in C:\Program Files (x86)\SimTools V2
    If I launch Game Manager and then Game Engine through shortcuts on my desktop, SimTools recognizes my license and opens Game Manager Pro and Game Engine Pro.
    This means that the "Registration" has been done correctly.
    Game Manager and Game Engine desktop links are executed in "Administrator" mode
    Texte original en Français :
    Merci de s’intéresser à mon problème de reconnaissance de la licence lors de l’exécution au démarrage de Windows 8.1.
    A) Afin de traiter le problème le plus simple à vérifier, pouvez-vous me dire si c'est normal d’avoir 2 répertoires SimTools ?
    Je remarque que dans les 2 répertoires Game Manager et Game Enigine n’ont pas la même taille ni la même version
    Version de produit V2.4 pour Game Manager et Game Engine dans C:\Program Files (x86)\SimTools
    Version de produit V2.31 pour Game Manager et Game Engine dans C:\Program Files (x86)\SimTools V2
    B) Si je lance Game Manager puis Game Engine par des raccourcis présents sur mon bureau, SimTools reconnaît ma licence et ouvre Game Manager Pro et Game Engine Pro
    Cela signifie que la "Registration" a été correctement faite.
    Game Manager et Game Engine les liens du bureau sont exécutés en mode « Administrateur »
    152,541Coins
    +11,085 / 56 / -2
    Did you use the SimTools Registration tool and use the Check License button as directed?
  8. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Yes
  9. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    152,541Coins
    +11,085 / 56 / -2
    No you should not have multiple SimTools installs.
    Totally uninstall SimTools, taking the option to remove all files, then reinstall.
  11. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Thank you for this information,
    Historical:
    a) As before I installed and used SimTools V1.3 and at the same time a second SimTools V2 Demo version.
    b) After purchasing the license, I had uninstalled the SimTools Manager and SimTools Enigine program completely from Windows 8.1.
    c) After uninstalling Windows I had not checked by the explorer the total disappearance of SimTools on the hard disk of the PC (I don't know where to check the total disappearance of SimTools traces)
    d) Then I simply installed and registered SimTools 2.4
    My 6 Questions:
    Q1) Which SimTools configuration files can I save and replace after reinstallation and registration?
    Q1a) "C:\Users\Name\AppData\Local\SimTools" can be saved to replace the blank directory after "Uninstallation / Installation / Registration"?
    Q1b) Are there other files to backup that I haven't found?
    Q2) Can you take a screenshot and address them as text of all directories and files that should no longer be present after uninstalling Windows 8.1?
    Q3) After uninstalling Windows, if there are any files left, can I manually remove them or do you recommend a freeware program to do this task?
    Q4) After uninstalling Windows and reinstalling SimTools V2.4 then use the same key that I received after installation ?
    Q5) This SimTools registration key allows how many Uninstall / Install operations ?
    Q6) Is it normal to have 2 license files in "C: \ Users \ Name \ AppData \ Local\SimTools_Licence"?
    One file for Game Manager and the second for Game Engine?
    Texte Original en Français
    Merci de pour cette information,
    Historique:
    a) Comme auparavant j'ai installé et utilisé SimTools V1.3 et en même temps une seconde version SimTools V2 Démo
    b) Après l'achat de la licence , j'avais désinstallé totalement par Windows 8.1 le programme SimTools Manager et SimTools Enigine
    c) Après la désinstallation Windows je n'avais pas vérifié par l'explorateur la disparition totale de SimTools sur le disque dur du PC (je ne sais pas ou vérifier la disparition totalement des traces de SimTools)
    d) Ensuite j'avais simplement installé et Registrer SimTools 2.4
    Mes 6 Questions:
    Q1) Quels sont les fichiers de configurations SimTools que je puis-je sauvegarder et que je remplace après la réinstallation et la registration ?
    Q1a) "C:\Users\Name\AppData\Local\SimTools" peut-il être sauvegardé pour remplacer le répertoire vierge après " Désinstallation / Installation / Registration " ?
    Q1b) Y-a t-il d'autres fichiers à sauvegarder que je n'ai pas trouvé ?
    Q2) Pouvez- vous par copie d'écran et leur adresse en tant que texte de tous les répertoires et fichiers qui ne doivent plus être présent après la désinstallation Windows 8.1 ?
    Q3) Après la désinstallation Windows, s'il reste des puis-je les supprimer manuellement ou conseillez-vous un logiciel freeware pour effectuer cette tâche ?
    Q4) Après la désinstallation Windows et la réinstallation de SimTools V2.4 puis utiliser la même clé que j'ai reçue après l’installation ?
    Q5) Cette clé de registration SimTools permet combien de désinstallation / Installation ?
    Q6) Est-ce normal d'avoir dans "C:\Users\Name\AppData\Local \SimTools_Licence" 2 fichiers de licence ?
    Un fichier pour Game Manager et le second pour Game Engine ?
  12. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Good morning, sir,
    I'll keep you informed of my progress and any questions I don't have answered.
    I did not uninstall SimTools V2.4 because I had no answers to questions Q4 and Q5
    My unsuccessful actions:
    1) I installed the latest . .NET Framework : https://www.microsoft.com/net/download
    2) I deleted the second directory C:\Program Files (x86)\SimTools. It must have been from when I tried SimTools V2 Demo with LFS.
    3) Cleaning of Internet Explorer, Windows Explorer, System and Registry
    Observation after these 3 actions :
    Strange reaction of SimTools V2.4, sometimes I have Game Manager and Game Engine in PRO, sometimes one or the other in PRO, sometimes and most often when the internet is cut, I have both in DEMO.
    About my questions, I found in a closed post the answers to my first questions Q1, Q2 and Q3.
    https://www.xsimulator.net/community/threads/simtools-2-0-question-and-answer.8175/page-29
    Excuse me, can I have answers to my questions Q4, Q5 and especially Q6.
    Texte en Français
    Bonjour,
    Je vous tiens au courant de mon avancement et des questions auxquels je n’ai pas de réponse
    Je n’ai pas désinstallé SimTools V2.4 car je n’avais pas de réponses aux questions Q4 et Q5
    Mes actions infructueuses :
    1) J’ai installez le dernier .NET Framework : https://www.microsoft.com/net/download
    2) J’ai effacé le second répertoire C:\Program Files (x86)\SimTools. Il devait dater de l’essai de SimTools V2 Démo avec LFS
    3) Nettoyage de Internet Explorer, Explorateur Windows, Système et du Registre
    Constat après ces 3 actions :
    Réaction bizarre de SimTools V2.4, parfois j’ai bien Game Manager et Game Engine en PRO, parfois l’un ou l’autre en PRO, parfois et le plus souvent quand l’internet est coupé , j’ai les 2 en DEMO.
    A propos de mes questions, j’ai trouvé dans un post fermé les réponses à mes premières questions Q1, Q2en Q3
    Excusez moi, puis-je avoir des réponses à mes questions Q4, Q5 et surtout Q6
  13. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Without answer to my questions 4, 5 and 6, I still haven't reinstalled SimTools 2.4.
    By using various software in free version to clean unwanted files and to clean the registry, I've reached for the moment a satisfactory functioning because Game Manager and Game Engine opens in PRO version with or without internet connection.
    I would nevertheless be interested in an answer to my questions 4, 5 and especially 6 (number of license files that must be present on the hard disk, at home, I have 2 license files, is this normal).
    Sans réponse à mes question 4, 5 et 6 , j’ai toujours pas réinstallé SimTools 2.4
    En utilisant divers logiciel en version free pour nettoyer les fichiers indésirable et pour nettoyer le registre, je suis arrivé pour l’instant à un fonctionnement satisfaisant car Game Manager et Game Engine s’ouvre en version PRO avec ou sans liaison internet.
    Je serais néanmoins intéressé par une réponse à mes questions 4, 5 et surtout la 6 (nombre de fichiers licence devant être présent sur le disque dur, chez moi, j’ai 2 fichiers licence, est-ce normal ?)
  14. Jaysonchou111
    Jaysonchou111 New Member
    188Coins
    Simtools 1.3 is very good. Version 2.0 is a little expensive. When will there be a discount
  15. yobuddy
    51,190Coins
    @TFOU57,
    Sorry for the delay buddy.
    Yes
    Depends on how you install it.
    The licenses is valid for one SimTools setup at a time.
    Buzz us here if you have any problems.
    https://simtools.us/contact-us/
    Yes as they could be installed on 2 PC's across the network.
    @Jaysonchou111,
    SimTools v2 is still free for DIY users.
    https://www.xsimulator.net/community/faq/request-a-free-diy-simtools-2-0-license.262/
    Take care,
  16. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    Good morning, sir,
    In order not to have password access stored on my PC, if I clean up the "Saved passwords" and "Network passwords" (the 2 areas framed in red), will this affect the Simtools v2.4 Pro license registered on the PC?
    Is it possible to use cleaning software without risk of losing the license registered on the PC?
    As a precaution, it is sufficient to save the 2 files as a backup.
    "C:\Users\Guy\AppData\Local\SimTools_License"?
    Texte original
    Bonjour,
    Afin de ne pas avoir des accès par mot de passe mémorisés sur mon PC, si je fais un nettoyage des « Mots de passe enregistrés » et des « Mots de passe réseaux » ( les 2 zones encadrées en rouge) , cela influera sur la licence Simtools v2.4 Pro enregistrée sur le PC ?
    Peut-on utiliser des logiciels de nettoyage sans risque de perdre la licence enregistrée sur le PC ?
    Par précaution, il suffit de sauvegarder au préalable les 2 fichiers sous
    « C:\Users\Guy\AppData\Local\SimTools_License » ?
  17. yobuddy
    51,190Coins
    @TFUO57,
    I use CC Cleaner all the time, no problem!
    You can't move or edit the reg files v2, but it should not affect the registration with a cleanup anyway.
    Take care buddy,
  18. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    just installed simtools ver 2.4 and game engine closes the moment i open game manager any ideas?
    152,541Coins
    +11,085 / 56 / -2
    Was it a clean fresh install, or not, and if not did you choose to remove all existing files?
  20. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    I got it working now by deleting the simtools folder in appdata >local
    is there a way i can keep my old profiles thou ? @noorbeast
    edit fixed now cheers
