AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. Thanos
    Electronics Engineer
    2,854Coins
    Now watch how good the spike filter works handling crashes, while allowing the highest details and vibration while racing:
    For 4DOF PT-ACTUATOR platform (spike level 1800):
    And a longer version from CV (PT Motion Owners Club group):
    For DIY 6DOF platform, 450mm stroke actuators and various spike levels for comparison:
    It sure is a game changer!!! Off to adapt the spike filter on more of my controllers... :cheers
  2. Thanos
    2,854Coins
    Talking about jolts and vibrations, you can go completely opposite way, have all the road details unfiltered from the game (100% intensity in simtools) and still survive crashes like a boss:
    Just see the amount of vibration detail running over the curb on this "camera on board" clip. Bonus: Crashing with Spike Filter is like the crash motion cue is erased before it even reaches the actuators!!
    Thanos
  3. Thanos
    2,854Coins
    Realistic Level D cockpit, requires realistic, almost 270 degrees peripheral screens. The frame is ready for mounting...
  4. hartsa90
    hartsa90 Member
    Finland
    111Coins
    Hi Thanos,
    I tried to order the board from tindie, but there is no delivery options to Finland.
    I was hoping to build a sfx-100 system using your board.
    Hopefully deliveries will be possible in the future??
    -Hartsa
  5. Thanos
    2,854Coins
    I have a notice on the Tindie Page about it. I suspended international shipping for now, as I cannot visit the Post office in person and its required to fill out customs forms etc. I mentioned instructions for alternative source for the AMC-AASD15A controller from PT-Actuator factory in China. Contact Mr Shao there and he will be glad to help, he can ship anywhere in the world and the controller includes metal enclosure in the price ;)
    http://www.pt-actuator.com/a/products/p5/45.html
    Or for a bit extra dollars you can get it with the 7th servo connector on it:
    http://www.pt-actuator.com/a/products/p5/119.html
    Thanos
  6. Thanos
    2,854Coins
    Mike's 6DOF platform with AASD-15A servomotors is almost complete, screen is mounted and calibrated and cockpit instruments are installed in the nose section... All this while in self-isolation. Stay safe from the Coronavirus!!!
    • Like Like x 6
  7. Smokinfour
    Smokinfour New Member Gold Contributor
    86Coins
    4DOF
    I have a quick question about wiring the Park and E-stop buttons. Is the park button a on / off button or a momentary button? Also it looks like it jump tie the 2 center poles on the board together correct?
  8. Thanos
    2,854Coins
    Thank you Jeff! Amazing setup and presentation video!
  9. JAD
    JAD Active Member
    Australia
    1,446Coins
    Hi @Thanos
    Im in the market now for 80ST-M02430
    Ive noticed the adverts are showing 2 versions of the drivers.
    Is there something different about these that makes one better than the other?
  10. Thanos
    2,854Coins
  11. JAD
    JAD Active Member
    Australia
    1,446Coins
    Trouble is that seller is +33% more cost.
    I appreciate that a recommended seller by you has value but Im willing to take a chance on another seller to save 33%
    Do you think the this one would be viable?
    https://www.aliexpress.com/item/4000793515498.html?spm=a2g0o.cart.0.0.46b13c00wmbniv&mp=1
    edit-
    I noticed that one driver has modbus support and the cheaper one does not.
    Do we need modbus support for your controller?
  12. cfischer
    Colorado
    2,752Coins
    You want the drive on top. Its an aasd15a.
    The one on the bottom is a different drive. It would probably work too but you run the risk its not plug and play. The pinouts for these drives change from brand to brand.
    We only have that crappy low resolution image to go by so there is indeed a risk. You could tell the vendor that you need the drive to say aasd15a on it or ask for a close up photo of the label. Dont expect much help from the cheapest deal on the net.
    No need for modbus support. Thanos uses step and dir, among other things.
  13. JAD
    JAD Active Member
    Australia
    1,446Coins
    It might be one of those too good to be true prices.
    I'll think I'll leave it and wait for a sale to come up somewhere.
    Cheers
  14. JAD
    JAD Active Member
    Australia
    1,446Coins
    I see now looking at them more closely that we want the ones with the heatsink on the side.
    edit-
    Both sellers are representing that they are AASDA-15A and I noticed other sellers also doing the same with both images.
    It looks like there are 2 varieties of AASDA-15A but it makes sense the ones with heatsink on the side are the better pick.
  15. Gadget999
    12,001Coins
    do those 750w motors come with a gearbox ?
  16. Thanos
    2,854Coins
    Yes, I think the cheaper one has smaller heatsink with a fan.
  17. Thanos
    2,854Coins
    No, but you can find matching gearboxes with a little search:
    -750W AC Servo Motor Drive Kits NEMA32 80mm, AASD-15A: https://www.aliexpress.com/item/32973113245.html
    -Matching 50:1 planetary gearbox: https://www.aliexpress.com/item/32835293950.html
    -Or 100:1 matching planetary gearbox for more power for larger 6DOF: https://www.aliexpress.com/item/32962968884.html
    or if you need more power use 1000watt:
    -80ST-M04025 1000W 4N servo motor 2500rpm - driver AASD-20A https://fr.aliexpress.com/item/32843516422.html
    -Matching 50:1 angle planetary gearbox: https://fr.aliexpress.com/item/33006989534.html
  18. Thanos
    2,854Coins
    Victor shared a few videos of his new 4DOF +TL +Surge rig in action. Worth watching:
    And some good little derby race for max fun factor:
  19. JAD
    JAD Active Member
    Australia
    1,446Coins
    Alright, I know Im spending too many hours hunting for best price, but this is sport for me.
    I have to pull the trigger because its taking me away from my desk work too much.
    After hours of searching, the best deal for the proper drive is this one below.
    Gotta screen shot these things because prices in links keep changing. This is only good for the rest of this week. Works out AU$2165 inc delivery +tax
    I'm only searching for the drives with the white sticker across the top of them. And the heatsink has some type of componentt fixed to the flat face of the heatsick. These seem to be the correct version.
    https://www.aliexpress.com/item/32921259103.html?spm=a2g0o.detail.1000060.3.27ea22abToQG1r&gps-id=pcDetailBottomMoreThisSeller&scm=1007.14977.161855.0&scm_id=1007.14977.161855.0&scm-url=1007.14977.161855.0&pvid=8b67ac7c-8dfb-468b-ade7-b98d1f9e7886&_t=gps-id:pcDetailBottomMoreThisSeller,scm-url:1007.14977.161855.0,pvid:8b67ac7c-8dfb-468b-ade7-b98d1f9e7886,tpp_buckets:668#0#170098#3_668#808#5965#460_668#888#3325#8_668#2717#7563#570
    Now I just got to convince myself this is as good as it gets.
  20. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,778Coins
    Hi JAD
    Youre motor is a 90st size a nema32 gearbox wont fit.
    It isnt a big problem because planetary gearboxes are made in all ST sizes.
    ST 90 means the motor got a square flange of 90mm, if you look with planetary gearbox 90mm on ali you will find them
    This count for all ST sizes just put the number in mm after gearbox.
    But be carefull there are different input bores.
    sorry for the bad english
    Regards AD
