PT-Actuators 3DOF system?
Discussion in 'Commercial Simulators and Peripherie' started by LukeBrown, Jul 1, 2019.
  1. Zeroselect
    Zeroselect Member Gold Contributor
    Maryland, USA
    111Coins
    4DOF
    Watching that video just gave me the biggest :grin thinking how its going to be having a motion rig.
  2. Thanos
    Electronics Engineer
    2,901Coins
  3. Zeroselect
    Maryland, USA
    111Coins
    4DOF
    Looking at buying a kit from PT-actuator.com. I am not much of a DIY/Maker type (not enough time in my life).
    Doesn't the PT-Actuator kit already come with the required hardware (aasd-15a)?
  4. Thanos
    2,901Coins
    Sure, look here:
    http://www.pt-actuator.com/proshow.asp?strID=174
    The actuators on PT-ACTUATOR are 150mm stroke (FSX-100 are 100mm stroke).
    It includes servomotors and drives ( AASD-15A) as well my AMC-AASD15A servo controller that makes it compatible with simtools.
  5. Zeroselect
    Maryland, USA
    111Coins
    4DOF
    Sweet!
    You're going to be inundated with question once I get my setup. :grin
  6. Thanos
    2,901Coins
    You can seek answers or ask questions here:
    https://discord.gg/bx4PxYR
    153,027Coins
    +11,116 / 56 / -2
    No I am suggesting adding traction loss and perhaps a G-Seat + harness tensioner to the motion rig for a more complete and realistic experience.
    Personally I do consider a traditional 3 actuator design is better, as with 4 sometimes one actuator will not be in contact with the ground, which can't happen with 3.
  8. djbart82
    djbart82 New Member
    Operador
    28029, Madrid
    210Coins
    3DOF, Motion platform
    good night Luke
    I am going to mount a system like yours but with the SFX100, can you pass me the configuration file that you have please?
    Thanks greetings
  9. djbart82
    djbart82 New Member
    Operador
    28029, Madrid
    210Coins
    good
    this configuration is correct, currently I have the sfx100 with three servos, one front and two rear and this configuration I do not notice it natural
    when accelerating leans forward, when I brake back, it should be the other way around
    another thing that I notice and I don't know where to change in the simtool is the brsquedad when changing gears, I would like it to feel less abrupt
    could you help me please
    thanks
    153,027Coins
    +11,116 / 56 / -2
    In SimTools Axis Assignments the Dir box being checked orange or not determines which way and axis moves, so try reversing how yours are set for surge: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  11. Chris0711
    Chris0711 New Member
    59Coins
    Hi together,
    I followed the discussion 3 vs 4 actuators in different forums. With the PT actuators, I think we have a strong system . So 2 actuators in the rear, one in front of the pedals should be powerful enough.
    Has some of you testet both types and has good arguments for 4 actuators?
    My plan is, to combine a 3 post platform with a traction loss at front and rear and a seatmover for simulating the G forces.
    Best regards,
    Chris
  12. Thanos
    2,901Coins
    I would suggest placing TL only on the rear, and the front single actuator would be the rotation point for the TL... better balance while rotating a 3 legged rig.
    Also did you see this promotion on PT-actuator site? If you use iRacing would be great opportunity...
    Thanos
  13. Chris0711
    59Coins
    Wow, thar is really a good offer.
    For the TL System, i have more questions, but I think I find a better thread for this
    Have you tested both systems? 4 legged and 3 legged? I just wonder, if there is any reason for the 4th leg, else the better weight management. I understand the argument of simulating the suspension movement. But simulating a single wheel movement (lika a curb...) would lead to one actuator loosing ground contact? Or am I wrong?
    I just want to make sure to get the best immersion, if it's better to have 4 actuators, I will save money a bit longer ;)
    Thanks,
    Chris
  14. r3df0x
    r3df0x n00by Racer Gold Contributor
    IT technician
    Canada
    235Coins
    2DOF, SCN6
    Watch Out! is not 150mm or 100mm stroke but only 80mm
    Too bad!
  15. Thanos
    2,901Coins
    Yes, its a special offer for iRacing as it says... and 80mm is still a lot for 3 actuator platform which has more range than a 4 actuator platform... Its a trade-off between stability or range. ;)
  16. nikwilliamson
    nikwilliamson New Member
    UX Designer
    Orlando, FL
    112Coins
    Hey. It looks like it's been updated, and is now 100mm stroke? @Thanos can you confirm?
  17. Thanos
    2,901Coins
    Hey, I'm not sure myself either. It's from PT-Actuator, maybe you can contact them to ask? Despite PT-Actuator using my AMC controllers, I have little or no say to the actuator hardware they make!
    Thanos
  18. r3df0x
    IT technician
    Canada
    235Coins
    2DOF, SCN6
    @Thanos Does it make a difference to you if we buy your AMC Controller on your Tindie page or from PT-Actuator?
  19. Thanos
    2,901Coins
    No its the same thing. The only difference is that PT-ACTUATOR adds a really cool metal enclosure to it... ;)
  20. Shao
    Shao New Member
    140Coins
    2DOF, 3DOF, Motion platform, 4DOF, 6DOF
    Hi, buddy, it's so upset to hear about this, what's the motion kit you bring from us ? we checked the sales rocord a moment ago, all orders are been sent within 3-5days, no more delay, no lost parts, no dispute, and, we are really great honor to hear that you are saying quick message response, day , night, it's my working style, definitely, and, we are also provide service in a short time , too. So, what kind of service do you need ? i can't see the service items that you are asking for by here, thanks. Shao.
