value1
FlatOut 2 Plugin 2.0.0.0
SimTools game plugin for FlatOut 2
  1. yobuddy
    51,524Coins
    Being that this is a memory hook plugin (that breaks with most update) its better to stick with a older game.
    Or it just gets broken all the time with updates.
    (flat-out has no real telemetry API is the problem)
    Take care,
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    I see... TKS
  3. oren ben jacob
    oren ben jacob New Member Gold Contributor
    - 39Coins
    I own the full game (from GOG) and the plugin just doesn't work.. any idea why ? thanks in advance.
  4. oren ben jacob
    - 39Coins
    I didn't find a way to edit my message so I will just add that I have also the Steam version, and the demo.. all doesn't seem to work :(
    153,728Coins
    You need to provide way more information.
    Is there telemetry data in the Tuning Center?
    Did the game patch ok and does the game show as connected (top right colored box) in Game Manager when Flatout 2 is running?
  6. oren ben jacob
    - 39Coins
    It does show as connected and it seem to be patched ok yes. I started a game, drived a bit and minimized the game and see numbers are running in the tunig center dame data input.. here's pictures I took:
    153,728Coins
    It is working fine, but you need to refine your motion profile, in particular capture Max/Min values in the Tuning Center, as the defaults are way too big, see here for tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  8. KydDynoMyte
    KydDynoMyte Fool's Gold Contributor
    RTP, NC
    40Coins
    The motion profile defaults might not be too bad. Using only forces (pitch & roll) in axis assignments that the plugin doesn't provide seems to be the problem here.
    153,728Coins
    Following the tips in the link provided will correct both the Axis Allocations and Tuning Center values, as both are way off.
