value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. value1
    14,243Coins
    "Try and Fly all products for free for a whole month!
    In view of last months response, we are pleased to announce our upcoming Free For All event, starting April 19th, where you are welcome to try any and all our products (except campaigns) for free and without limitation for one month. This unlimited access to all our suite of products, including our top fighter jets, such as the F-16C, F/A-18C and A-10C Warthog will help take your mind off things for a while, giving you the opportunity to try something new, and to own it for 50% or less than the normal price. "
    https://www.digitalcombatsimulator.com/en/news/2020-04-17_FT_MONTH/
  2. RaceRay
    Hamburg, Germany
    23,884Coins
    Nice. I will give it a try:)
  3. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    Question for the experts
    I am using this plugin since long time and one thing I can't figure out is this..
    specially with the F16 at lower speeds and even more when the gear is down (flight controls gains are adjusted and reduced when gear is lowered) my motion platform becomes quite unresponsive and I can't feel all the little movements and changes in pitch roll and heave.
    Is there any way to adjust the forces based on speed for example? or even based on gear state (up or down)?
    How would I need to modify the export.lua to make this? If at all possible...
    Thanks a lot
  4. CdnSimRacer
    CdnSimRacer New Member
    17Coins
    Motion platform
    looking for some help. I just downloaded DCS, patched the game. I have simtools pro and the game connects and goes blue/game running but tuning center does not get any game data input...
    Not sure why.
    153,938Coins
    +11,158 / 57 / -2
    Try temporarily turning off your firewall and anti-virus, test and see if they are messing with communications.
  6. margolle
    margolle Member
    104Coins
    hello .( i am french sorry for translation )
    my probleme is plug in no mouving .
    imposible to move .
    my simulator is good for many game ( project cars , IL2 BOS , raceroom etc etc )
    the patch DCS is here (picture)
    tuning center never move
    please help me destination plugin DCS.png destination plugin DCS 2.png destination plugin DCS 3.png
    153,938Coins
    +11,158 / 57 / -2
    Please try temporarily turning off your firewall and anti-virus, test and see if they are messing with communications, as the Tuning Center is not receiving data.
  8. margolle
    margolle Member
    104Coins
    hi . probleme is resolved .
    the probleme is bad destination patch .
    my game instaled to G: , my patche instaled to G: = no moving
    my game instaled to G: , my patche instaled to C:( saved game / DCS) = moving
    tank you all
  9. Jonathan Petter
    Jonathan Petter New Member Gold Contributor
    - 447Coins
    i am also having issues, game version 2.5.6, English, I see the game patched correctly via the Export.lua in the scripts folder, but nothing in the tuning screen nor any actuator movement. please help! thank you!
  10. Jonathan Petter
    - 447Coins
    Figured it out, theres a new directory export.lua needs to be in
    C:\Users\User\Saved Games\DCS\Scripts
    Thats why its not working
  11. Kaneda
    Kaneda New Member
    84Coins
    Hi margolle, do you know if you have speed information with the plugin ? (gamedash)
    thanks
    153,938Coins
    +11,158 / 57 / -2
    The plugin summary states this with respect to GameDash:
    DashApp Data:
    Additional values for instruments are feasible, yet not implemented.
  13. MrDemon
    MrDemon New Member
    - 84Coins
    Hello. I have installed you plugin to User/savegame/DCS
    I have regional settings in English.
    My problem is strange data from tuning center. Roll and pitch. I tried to adjust the roll and pitch, but the data is more than a thousand degrees. Trying to set up a sway - my platform is behaving quite incorrectly. IL2 works fine. What can i do wrong?
    PS 2dof
    153,938Coins
    +11,158 / 57 / -2
    Please post pictures of all of your settings, including the Tuning Center while DCS is running.
  15. MrDemon
    MrDemon New Member
    - 84Coins
    DCS is not running, but this is captured min/maxes
  16. Leandro Kemp
    Brasil
    - 10Coins
    Hello.
    Did it stop working after the game was updated?
    Can someone confirm this for me, please.
    Do you already have a solution to work again?
    Tank You
  17. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    815Coins
    Works fine for me.
  18. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    I have used SimTools with DCS for several years. Thank you all you clever chaps for your work
    Does anyone know if it possible to access Roll Rate in DCS? In IL-2 Battle of Stalingrad I use Roll Rate, not Roll, and it works perfectly - great feel when banking and no issues going over the top of a roll. Smooth as can be. And good feel if I goof a landing and bounce and tilt a bit from side to side.
    I have tried using Roll with the Generic 2D Advanced setting and turning on the anti-rollover option, but I still get horrible motions going over the top of a roll.
    Grateful for any suggestions.
  19. MarkusB
    4,215Coins
    Hi @hugso ,
    you should try @Dirty 's "Experimental DCS Plugin":
    https://www.xsimulator.net/community/threads/experimental-dcs-plugin-ready-for-testing.13560/
    This one uses roll & pitch rate instead of roll & pitch angles.
  20. hugso
    hugso Active Member
    Glos UK
    611Coins
