Showroom FK-Seat to 2DOF with wipers, IBT-2
Discussion in 'DIY Motion Simulator Projects' started by dieser, Mar 21, 2020.
  1. Rifly
    Rifly Member
    freelance photographer
    Latvia
    232Coins
    I had a bad thought seeing how my glued veneer flexes and this is glued saw dust, so I think it will most likely brake on impact... I hope not but be aware of possibility :nerd
    153,740Coins
    If there is flex then it will be negatively impacting on the quality of the motion cues.
  3. dieser
    dieser Member
    372Coins
    do both of you mean the motorbrackets or the u-joint mount?
    both are 3mm thick steel.
    seemed ok with 12v motors before...
    i will take a look on them and maybe searching for another solution...
    thanks!
  4. Rifly
    Rifly Member
    Latvia
    232Coins
    Noorbeast was about brackets and I am talking about material, Im not sure how long it withstand push/pull without cracking, I know for you it's seat mover so there is less stress, but monitor condition of platform. - cracks
    There is usually lots of flex with wood/plywood e.t.c Wood makes noise before cracking but yours might just crack since motors are strong.
  5. dieser
    dieser Member
    372Coins
    @noorbeast @Rifly
    i already thought about changing materials in the future to aluminium profiles like this:
    4A1281FF-CAF2-43BC-85DD-2AACA4F2ED92.jpeg A61CFCC7-729C-4F53-B981-8F67F7D9B2FD.jpeg
    (found it on the internet. source:
    http://projectable.me/my-sim-racing-motion-rig-version-2/
    i have no experience with aluminium profiles, but many people using it to build racing rigs...
    but also a flexible material...
    is it a better option for the forces of a motionsim?
  6. mimi67
    mimi67 New Member Gold Contributor
    france
    176Coins
    hello
    you should reinforce all your brackets and supports, because it will twist when it moves, I have 5 mm steel brackets and I doubled them ...
  7. Rifly
    Rifly Member
    Latvia
    232Coins
    To be honest those profiles are stiff :) I - myself - will go with steel welds since its cheaper for me, I've made couple versions of what I have now (wood) and learned a lot so Im sure it will be same with you too, plus looking at your work I can see that you like precision so Im sure you will make perfect rig for yourself :cheers
  8. dieser
    dieser Member
    372Coins
    cheers buddy! :cheers
  9. dieser
    dieser Member
    372Coins
    of course you guys were right and there is to much flex in the build... :rolleyes:
    uncomfortable and unprecise to drive.
    i will change the frame again!
    ordered 40/40 aluminium item profiles now to build a rig and plan to mount the motors on brackets like this
    : 2A6AC234-D565-4EFD-9515-129FABC70BFD.jpeg
    ( found on this forum. build by @Santrovitsch )
    will 5mm aluminium do the job here?
    or should i use steel?
    while i disambled everything i also considered to set the motor position under my knees like f.e. dofreality does.
    is there any advantage doing this?
    greets
    dieser
    153,740Coins
  11. Rifly
    Rifly Member
    Latvia
    232Coins
    Glad to hear you are making progress, and at the same time a bit sad that our predictions about flex came true. Stiff motor mounts and joints without flex are fine. But now even with all that mentioned, My rig jumps :D so I had to add some weight to prevent it :D
