  1. giorgionrg
    giorgionrg New Member
    Technician
    92Coins
    Attached the wiring diagram and the .ino code used.
    Is it normal, with this config, that the motor start to move when I power on the system?
    Thanks.
  2. giorgionrg
    Technician
    92Coins
    At the end I solved it by increasing the DEADZONE value. Now it's setted to 10 and when I turn on the motor are stopped.
    The next step is the AssettoCorsa plugin creation.
    I'll update you.
    Bye :thumbs
  3. Marcos73
    Marcos73 Member
    100Coins
    Hello.
    I am unable to run the engines with the SCM3.
    The potentiometers appear on the graph but the motors are not started.
    What is the correct pinout to configure the motors?
    It is?
    Or is?
    I'm using this Arduino code.
    Please help, thanks.
    Olá.
    Não estou conseguindo fazer funcionar os motores com o SCM3.
    Os potenciômetros aparecem no gráfico mas os motores não são acionados.
    Qual a pinagem correta para configurar os motores?
    Esta?
    Ou esta?
    Estou usando este código Arduino.
    Por favor ajudem, obrigado.
    152,283Coins
    +11,068 / 56 / -2
  5. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Set the green line right in the middle. And then play with the program but read the link above from Noorbeast first
  6. Marcos73
    Marcos73 Member
    100Coins
  7. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    It takes time. you have to read a lot. Set the green line righ in the middle with the potentiometer. Then set all parameters low as per the instructions. Max limit and clip input set to 250. then click sine
    (Do not touch the potentiometer)
    If the switch next to the motor you have selected is ( OFF) then you have reached the limits.
    I hope this will help.
  8. Marcos73
    Marcos73 Member
    100Coins
    Thanks Tom, I was successful, in fact I had used an Arduino pinout that was not correct. And after testing all the pinouts I found here, I found the correct one. Hugs and good luck! :)
    152,283Coins
    +11,068 / 56 / -2
  10. Marcos73
    Marcos73 Member
    100Coins
    Hello. Following your guidelines and RufusDufus ttps://www.xsimulator.net/community/threads/smc3-arduino-3dof-motor-driver-and-windows-utilities , but I believe that there is still no success. The engines did not stop. I still don't understand how SMC3 works!
    Does the SMC3 define the working angles of the engines?
    If so, what happens is that you are not able to stop at 90 °, setting the maximum engine limit.
    When using the potentiometers, they stop, but still pass the 90 ° I need.
    And I changed all the parameters.
    Please help.
    Follow video.
    Thank you.
    Olá. Seguindo suas orientações e o RufusDufus, mas acredito que ainda não há sucesso. Os motores não pararam. Não entendi ainda como funciona o SMC3!
    O SMC3 define os ângulos de trabalho dos motores?
    Se sim, o que acontece é que não está conseguindo parar em 90 °, definindo o limite máximo de motores.
    Quando usar os potenciômetros, eles param, mas ainda assim passam os 90 ° que preciso.
    E mexi em todos os parâmetros.
    Por favor ajudem.
    Segue vídeo.
    Obrigado.
    152,283Coins
    +11,068 / 56 / -2
    The SMC3 configuration is explained here: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    You need to have a pot connected to the motor, which gives position.
    152,283Coins
    +11,068 / 56 / -2
    Sorry but there is not enough detail and context to understand what you need help with, can you please be more specific.
  13. noorbeast
    152,283Coins
    +11,068 / 56 / -2
    What motor drivers are you using?
    Please post pictures of all of your settings and hardware.
    152,283Coins
    +11,068 / 56 / -2
    152,283Coins
    +11,068 / 56 / -2
  16. noorbeast
    152,283Coins
    +11,068 / 56 / -2
  17. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Hi had these pics which I always use,you can figure it out from there,simple.
    This one below is to double the current capcity. Double moto monster connection.jpg
    This is to connect two motors to one motomonster below:
    This one below is todouble the current capacity of the two channels on the one board:
    And lastly this is the pin outs to use when you connect your motomonstor boards:
  18. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    Yes that wiring is correct.
  19. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    328Coins
    Does moto monster support 24v?
    And what is the safe fuse rating for each MM out?
  20. Llewelyn
    Llewelyn Member
    IT consultant
    south africa
    108Coins
    No it is for 12v,not to sure what the amperage rating is on the motomonstor,find the rating and get a fuse accordingly.
