Question Ricmotech RS1 to 2dof seat mover with traction loss
Discussion in 'DIY Motion Simulator Projects' started by Stephen Robotham, Mar 12, 2018.
  1. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Well i guess since no one responded i will just go ahead and get it and hope for the best.
  2. Nick Moxley
    You can always refund it after the first few hours through steam.
  3. Stephen Robotham
    jamaica
    130Coins
    I actually did get it and just tried it for the first time last night and its pretty good. My only issue is I cant get any road detail in simvibe. Does this work for anyone else?
  4. Stephen Robotham
    jamaica
    130Coins
    Hey, what's the issue if you don't have a battery connected. I have been running my sim without it for about 3 years now with no issues that I can tell.
    153,764Coins
    +11,149 / 57 / -2
    As per my quote, the Sabertooth 32s are designed to handle regenerative current, "the auxiliary power outputs can be configured to allow the Sabertooth 2x32 to operate from a power supply without a parallel battery": https://www.dimensionengineering.com/products/sabertooth2x32
    The 60s are designed differently, "the regenerative topology means that your batteries get recharged whenever you command your robot to slow down or reverse.": https://www.dimensionengineering.com/products/sabertooth2x60
  6. Stephen Robotham
    jamaica
    130Coins
    Thanks for your reply, I read and understood all of that, what i'm trying to determine is if there is a draw back to not having any batteries in the system, because I don't and haven't had any issues so far, but would prefer to avoid a issue in the future if it could cause one.
    153,764Coins
    +11,149 / 57 / -2
    Are you using Sabertooth 32? If so no battery is required.
  8. Stephen Robotham
    jamaica
    130Coins
    Good day all, its been a long time since my last post due to work keeping me away from my simrig. I am trying to make more time for sim racing and was wondering if there was a way to add abs effects to the pedals? I have 4 transducers at each corner right now, but would love to add a second sound card and another shaker at the pedals, but i dont see an option for abs.
  9. Stephen Robotham
    jamaica
    130Coins
    Please any help would be greatly appreciated. I would like to add abs or brake lock up to my pedals. Is this possible? If so, how?
