Tutorial DIY 3D printed Sim Racing Hydraulic pedals SRT
Discussion in 'DIY peripherals' started by Lebois, Jan 26, 2020.
  1. Lebois
    Math teacher
    2,559Coins
    New versions for both accelerator and brake pedal for this week-end ;-)
  2. Lebois
    Math teacher
    2,559Coins
    Hi, I made a video to present the updates :
    I am now uploading all the files, and updating the descriptions.
  3. HCR Mad Bull
    HCR Mad Bull Member
    439Coins
    DC motor, AC motor
    Brilliant video, very informative and well constructed!
    When I was looking at the individual parts I wasn't sure how they all go together but the video showed all my current questions about it.
    I'm just calibrating my 3d printer so I should be printing this off pretty quickly so good timing!
    Another way to attach the master is to make slots for the nuts to slide in, or have a smaller gap and heat up the nut a lot soldering iron pressed against it, which will melt the plastic around it which should be very strong.
    Thanks for the recognition by the way!
  4. Lebois
    Math teacher
    2,559Coins
    Good idea to add the slots for the nuts. I thought it was bad because it could have been weaker, but not necessarily... I will add it later.
    There is also solutions with threads that can be inserted with an iron. But I think this solution is a bit risky, if the parts are not perfectly aligned, there is a risk to ruin a 20h print...
  5. Lebois
    Math teacher
    2,559Coins
    Now, I will have more time to focus on my other projects :
  6. HCR Mad Bull
    HCR Mad Bull Member
    439Coins
    DC motor, AC motor
    Ooooo what might this project entail? Is it a dof system?
  7. Lebois
    Math teacher
    2,559Coins
    Yeah :)
    Two goals here :
    1) convert the Open sfx 100 actuators to stepper motors that are less expensive
    2) Invert the actuators so the moving part is lighter (the actuator doesn't bear the motors anymore), and the motion can be quickier (less risk of making the all rig take off)
  8. HCR Mad Bull
    HCR Mad Bull Member
    439Coins
    DC motor, AC motor
    Good luck!
    Every time I see motion rig it seems that they put the motor on the moving part which adds a huge amount of weight which always seems like a really bad idea.
  9. Lebois
    Math teacher
    2,559Coins
    Well... mounting the motor this way allow to fix the rig to the 100x100 extruded profil, which ensure that the rig is well clamped to the actuators.
    With my inverted actuators, I will have to clamp the rig to the 30mm OD tube...
  10. Lebois
    Math teacher
    2,559Coins
    3D printed M8 rod end ?
  11. Lebois
    Math teacher
    2,559Coins
    Working on the design, what are your thoughts about it ? :)
  12. Balu
    Balu New Member
    61Coins
    Hello Lebois, thank you very much, for sharing your project. I`ve also done my own pedal set with hall sensors and load cells. Unfortunately after six months one of the 50kg load cells broke. Without reading your project I would have changed one of the load cells and hope the best for future, but now I have a new little project :D.
    To manage the brake hardness, I would mount a rubber buffer with thread between the brake calliper.
    Something like this
    Many variations of shore are available and had good experiene with load cell.
    My only apprehension is, that the Z-rotation of the lever could be too big and damage the main cylinder especially the gaskets. Maybe longholes in the lever or only a fixed main cylinder in X and Y cords could avoid that ?
    Sorry for my bad english, I am not a native speaker.
  13. yangsqr
    yangsqr Member
    - 21Coins
    My fanatec pedal uses a 90KG load cell. In use, the weight I set reaches 60kg, so do you consider using a larger load cell more than 50kg and retain some redundancy to keep load cell safe?
  14. yangsqr
    yangsqr Member
    - 21Coins
    Thank you for sharing. Due to concerns about strength, I never thought that 3D printing could be used to make pedals. After seeing your pedal, I am no longer worried.:grin
  15. Lebois
    Math teacher
    2,559Coins
    Hi @Balu ! the rubber buffer you show can't be used for that. You need a specific material that can't be compressed without changing as many time as you want... And that kind of parts is quite hard to find actually. You should look after fibroelast elastomer springs.
    Anyway, I already tried to put a spring in the brake calipper, and the brake pedal felt very sprongy :/
  16. Lebois
    Math teacher
    2,559Coins
    I am not sure what you mean ? It worries you that the lever touches the master cylindre ? The lever is quite far, and can't be put even further with the new parts I drew
  17. Balu
    Balu New Member
    61Coins
    Sorry but no vulcanized rubber is elastic until you reach the specification, after that it is viscoelatic . You have only to look into the Data sheet how much N are the maximum + your own safety factor and a construction which allow yout to distribute the pressure on the rubber. Furthermore you can put in variations of Shore.
    Here a link:
    https://www.kippwerk.de/de/de/Produ...ungselemente/Gummipuffer-Edelstahl-Typ-B.html
    Datenblatt means datasheet
    Forget about my worries it was to late today :D 2.30am in Germany.
  18. Balu
    Balu New Member
    61Coins
    In my case it was only a material fail. Project should be as cheap as possible :D
  19. Renaudeau
    Renaudeau Member
    116Coins
    Your cranksets are really well thought out. In karting to modify the attack on the brake pedal, you can modify the distance between the axis of rotation of the pedal and the axis of the master cylinder rod. Do you think that by adding adjustment holes at the level of your pedalboard there would be a real feeling according to the players?
  20. Lebois
    Math teacher
    2,559Coins
    Yes you can change screw or unscrew the M8 end joint. It acts as a preload. There is many things that can be tuned on this pedal, and I believe that you could find exactly the same feeling as the one you have on your kart.
