Fixed seat upgrade 2DOF dynamic seat
Discussion in 'DIY Motion Simulator Projects' started by czgui, Apr 2, 2020.
  1. czgui
    czgui Member
    - 110Coins
    The final picture, the line is fixed with a rubber strip, which is very convenient.
    [​IMG][​IMG][​IMG]
  2. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    nice job ..can you tell me the name of the power supply and the motor ... i use car wipermotor with pc power supply butits not good it cant hold the weight
  3. czgui
    czgui Member
    - 110Coins
    The previous power supply has been eliminated, and now I use this power supply: HP 750W60A server power supply.
    The electrode uses a "12V200W" turbo worm geared motor with a speed of 1800, a reduction ratio of 30, and 60 rpm.
    If 40 revolutions per minute, there is more torque.
    I'm outside, go back and take pictures for you.
  4. czgui
    czgui Member
    - 110Coins
  5. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    what is the name of the motor....how much can the motor take weight.. it can get around 200kg?!
  6. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    is this good? 12v 200w 120rpm
    it can take weight? for person chair with steering wheel and pedels ?
  7. czgui
    czgui Member
    - 110Coins
    [QUOTE =“ absyfadhel1,post:197001,member:27614”]what is the name of the motor....how much can the motor take weight.. it can get around 200kg?![/ QUOTE]
    200W motor should be able to bear 200kg weight. Mainly depends on the motor output radius and the reduction ratio, which will affect the motor torque.
  8. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    what you advise me to take to apply my project if i chose 200w 12v 60 rpm with about 60:1 ost good if not what is the best ratio recution for the 200kg build and thanx
