Linear actuator with AC servomotor (beam design)
Discussion in 'Motor actuators and drivers' started by dureiken, Dec 21, 2019.
  1. dureiken
    dureiken Active Member
    1,248Coins
    Like that ?
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Yes, perfect!! This will help a lot to reduce the risk of damage during testing and emergency shutt off :) Try to give enough travel space into the damper. The forces are huge and the small dampers are not as hard as they seem - my experience
    Wickie
  3. dureiken
    1,248Coins
    Thanks to @thefost and @Peacemaker105, I changed design once again, really love this one, which seems to be strong !
    [​IMG] [​IMG]
    And I will try a new link method with collar (OD of nut is 36 and ID of alu tube is 36)
    It makes me win 30mm on stroke VS the previous design (I lost 12mm with DIam40 IGUS bearing)
    Don't hesitate to make advices :)
    • Like Like x 5
  4. dureiken
    1,248Coins
    I went to a local shop and realize that 5mm rod is very ... unstable :p
    So I made a new try with 10mm (tube or rod) and I discouple base and top rods.
    I had to go to OD120/ID112 tube for pulleys and belt to be ok.
  5. dureiken
    1,248Coins
    after a lot of discussions on discord with @Thanos @SilentChill @thefost @MagicMunkyNuts @Peacemaker105 @pmvcda (thanks to them), I choose to go with beam design which seems to me a lot easier to build. And tubular/cylinder design seems to be not very silent as it seems.
    [​IMG] [​IMG]
    Orange parts are PETG, white ones are IGUS filament and the bearing is a IGUS J https://www.igus.ee/product/66.
    And maybe because I already received all the beams :p
    Final stroke is 530mm, for 500mm used in rig.
    • Optimistic Optimistic x 1
  6. dureiken
    1,248Coins
  7. dureiken
    1,248Coins
    First actuator finished :
    5b9086b5-65f6-4229-bfcd-31abcce92d26.PNG 20200419_222558.jpg 20200419_222602.jpg 20200419_222610.jpg 20200419_222613.jpg
  8. dureiken
    1,248Coins
    Hi
    just a little update, I finally built my 6 actuators, seems fine :) need to test them now
    In chrono line, all majors steps :
    20200425_103259.jpg 20200425_104147.jpg 20200425_111124.jpg 20200425_111813.jpg 20200425_113313.jpg 20200425_120117.jpg 20200425_120145.jpg 20200425_154304.jpg 20200425_171843.jpg 20200425_201055.jpg 20200425_201116.jpg
    That's all :)
  9. Gadget999
    12,035Coins
    what is the spec of your motors ?
  10. Sebj
    Sebj Active Member
    Canada
    492Coins
    And roughly how much cost per actuator to build?
    Beautiful work
  11. dureiken
    1,248Coins
    thanks
    for the cost, no idea, in this way I can't lie to my wife :p
    • Funny Funny x 2
  12. Sebj
    Sebj Active Member
    Canada
    492Coins
    Was curious vs buying servo motors
    I never tell the wife
  13. dureiken
    1,248Coins
    New test :
    really smoother when not on main controller page, I stay on menu
  14. Mehmetbaran187
    Mehmetbaran187 New Member
    Turkey
    470Coins
    Wow
    Such a clean job you did.
    I was wondering about your motors ? Can you give us some specs please.
    What is the lead screw size ?
    All orange parts are 3D printed right ? Can you please share?
    Thank you.
