DD-Wheel with Hoverboard Motor
Discussion in 'Direct Drive Wheels' started by Benu, Jan 21, 2019.
  1. Benu
    Benu Member
    1,295Coins
    :thumbs
    Is that a motor bike handle bar attached to the hoverboard motor?
  2. Chris_Beeves
    2,157Coins
    Yes it is.
    3D printed most parts except for the aluminum clip ons. I think I will have to beef it up a bit. The power of this motor is way more than my old DC rig.
  3. Feisty
    Feisty New Member
    169Coins
    AC motor
    Thats really cool!
  4. Chris_Beeves
    2,157Coins
    Thanks!
    Here is a short presentation;
  5. marccohn
    marccohn New Member
    301Coins
    Benu and danove_b,
    Just purchased B-G431B-ESC1 for this project. Looks like the most successful solution. So far all my microprocessor board programming has been arduino, so I will have to come up to speed on STM programming.
    I have a couple of questions on integration options. Please check that my understanding is correct
    Option 1: Use vjoy to connect pc directly to ESC board.
    --Pros:
    ---- no additional microprocessor board needed
    ---- ESC firmware available from danove_b?
    --Cons:
    ---- Need to write a vJoy feeder program depending on simulator used
    ---- Not proven to work on any sim other than rFactor2
    Option 2: use STM32 Discovery to connect PC to ESC board (as decribed in post 304)
    --Pros:
    ---- vJoy not required -- one less piece of code to develop/manage
    ---- proven to work with multiple sims (iracing is my preference)?
    ---- firware available from Benu?
    --Cons:
    ---- Additional cost of discoveryboard and additional complexity of multi board solution
    I guess there is another option -- use leonardo board running AI-wave firmware to control ESC board
    -- Pros:
    ---- Firmware available from AI-wave
    -- Cons:
    ---- Development/support of AI-wave not active.
    ---- no proven successful projects
    Please help me decide which way to go forward.
  6. marccohn
    marccohn New Member
    301Coins
    OK, started to wire everything together and hit my first snag.
    Im trying to set up an FFB wheel and can't get through the first step of connect encoder to Leonardo with FFB firmware and setting up in wheelConfig. I never get the wheel status box at the bottom of the WheelConfig GUI. I know encoder works because I tested it with a simple sketch on Uno, and I even got encoder output to work fine with the EMC firmware. Wheel Config just doesn't seem to respond to any encoder movements when i have the FFB firmware loaded on Leonardo.
    Please let me know your thoughts.
  7. Granberget
    Granberget New Member
    58Coins
    Did you use AI Wave firmware?
    Then connect A/B to pin 0/1.
    I have an encoder with index, but that didn't work for me. So I simply connected pin 6 to GND and "boot" the wheel in the following order:
    1. Connect the USB to leonardo board
    2. Open Wheel config
    3. Disconnect pin 6 from GND
    4. Manually rotate the wheel a bit left and right
    5. Connect pin 6 to GND
    This was a huge trial and error process to get it working, haven't really found any good documentation on this.
    • Optimistic Optimistic x 1
  8. Granberget
    58Coins
    Thought I should share my version of encoder mounting to the hoverboard wheel, hopefully this can help someone!
    It's an AMT103 rotary encoder, a really cheap encoder with 2048ppr and 8 index-pulses per revolution.
    I 3d-printed a mount that fits on the original hoverboard base, to which i mounted a 5mm carbon fibre rod with bearings. On the rod there's a rubber wheel that rolls against the hoverboard wheel.
    There's also 4 small springs, to help the rubber wheel to press firmly against the hoverboard wheel.
    Took a few iterations to get it working, but now I have an encoder with 0 backlash.
  9. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    I have a kind of working solution of vJoy, but I know that it doesn't support all sims out there. For example did I have a strange lag with the steering input from AMS2 when I tried it. Depending a bit of what sim you are planning to use, I would go for Option 2 at the moment. You seem to have some programming skill, so if you are interested, download the vJoy driver/SDK. It has a working sample project where you can easily code some input values, and also monitor the different ffb effects. I could share my feeder, but it's kind of messy with a lot of not used test code etc. The small amount of comments are in Swedish... You can also look at this project: https://github.com/njz3/vJoyIOFeederWithFFB Haven't tried it by myself, so no guarantee if it's good or not..
  10. marccohn
    marccohn New Member
    301Coins
    Good news, got my encoder working with Wheel Config. Needed to add pull up resistors on the A and B signal. Not sure why AI-WAVE firmware needs the pull up resistors while not needed when I use a simple encoder reading sketch. Was even able to "drive" a few laps with no FFB and the accuracy over existing potentiometer solution in thrustmaster wheel was amazing.
    Anyway, baby steps, and on to FFB. Working to set up odrive motor driver to read the PWM signals from the Leonardo running AI-Wave firmware. Not seeing any signal on the PWM pins. 10 or 11 with any combination of settings. I don't have a scope, but I wrote a sketch for the Uno to read out the PWM signal for trouble shooting. This works when I send a PWM signal from another Arduino, but I get nothing when I run AI-Wave firmware. Feels like i tried every combination of PWM setting in Wheel Config, and every test mode in Wheel Check without any signal.
    Any help on getting a signal from AI-Wave firmware would be appreciated.
  11. Sieben
    Sieben Active Member
    2,241Coins
    Why use aiwave? Bugged a lot. Sometimes you have to wait till ffb appear... Also put constant force up.
  12. marccohn
    marccohn New Member
    301Coins
    Chose AI-Wave because I already had the Leonardo board and I was familiar with arduino tools and IDE, but you are right about bugs, and support, so I will be transitioning project to MMOS running on an STM32 board. Stay tuned for next round of questions.
  13. Sieben
    2,241Coins
    Have heard about EMC soft?)
  14. marccohn
    marccohn New Member
    301Coins
    Yes, got things working with EMC last night!
    Successfully drove a race using the 6.5" hoverboard wheel as a steering wheel. This was my first experience with an FFB wheel, so can't compare to anything, but driving experience was so much better then the old thrustmaster wheel I was using. Had to add in a second arduino as a PWM Converter because I couldn't get the EMC output to work with the Odrive. See diagram.
    Next Steps:
    -- Tune Feedback. (Upgrade EMC utility? Vibration effect is too high, turning force too low)
    -- Install Hardstop (Don't want the wheel spinning out of control as i crank up the power)
    ---- Is 350 degrees of rotation enough? How are others dealing with this?
    -- Eliminate, (or improve performance of ) Arduino based PWM converter. Looking for a way for oDrive to accept signal direct from EMC firmware. More research to do here
    -- Mount encoder. No more c-clamps and vice grips.
    -- Mount Real Wheel
    -- Move paddle shifter from thrustmaster to FFB wheel
  15. Benu
    Benu Member
    1,295Coins
    With the B-G431B-ESC1 the setup would look like this:
    Any force feedback board able to deliver PWM 0-50-100 output should work.
  16. fzxj520
    fzxj520 Active Member
    1,341Coins
    hi Benu
    Based on your security recommendations, I eventually re-established the connection using optical isolation.
    After testing, it runs perfectly.
    The Z phase function of mmos can also be used.
    I made a detailed picture
  17. njz3
    njz3 New Member
    58Coins
    Hi
    I am the original author of this feeder + arduino stuff. The goal is to have a replacement for the Leonardo (AiWave, EMC or Mmos), with more flexibilty on the underlying mapping of axes and buttons, thanks to vJoy.
    As of today, it does need to have a analog feedback for the motor position (potentiometer), as I wrote it for arcade racing cabinet, but I envision to support encoder feedback in the short future.
    Compare to other solutions, you will definitly not get shorter delays or better handling of the ffb. It's a poor man solution, but since its free and open source, you should give it a try.
    Worth also tell you that it is possible to do a lowcost PMSM motor driver with an arduino Due and a cheap DRV8301 board (I did it myself with FOC control, this is not open source).
    Benjamin
  18. fzxj520
    1,341Coins
    Thank you very much for your suggestions. At the beginning I used the minimum force feedback test (and the time is very short), the temperature is acceptable.
    Because the size of the ESC is too small, it is difficult to install a larger heat sink, so when I tested higher force feedback, I temporarily used a fan to actively cool the ESC.
  19. Sieben
    2,241Coins
    Can the z toggle be omitted? And what to do then with mosfet gate connection on brake resistor?) Thanks.
  20. fzxj520
    1,341Coins
    Hello everyone, do you have the same problem as me?
    After switching on the 24v power supply, the Hoverboard motor will emit noise (The sound when the motor is stationary)
    Is there any way to reduce or eliminate this noise?
    A similar sound
