DIY Arduino Buttonbox
Discussion in 'DIY peripherals' started by TOPMO3, Mar 28, 2016.
  1. clabit
    clabit New Member
    29Coins
    I am attaching the project and sketch
  2. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    443Coins
  3. clabit
    clabit New Member
    29Coins
  4. tutoveenee
    tutoveenee New Member
    51Coins
    Hello everyone. First of all thank a fellow forum member ((JonBakhol)). For all the help you have given me during my project. Thanks to him, I have learned a little more about how the Arduino world works.
    But "Jon" is also human and although we have done many tests, I still have the problem.
    I have a 32 button keypad. Here I leave the drawing.
    https://i.imgur.com/NWP6FwY.png
    And I have loaded on my pro micro board ((leonardo)). This sketch
    Code:
    //BUTTON BOX
    //USE w ProMicro
    //Tested in WIN10 + Assetto Corsa
    //AMSTUDIO
    //20.8.17
    #include <Keypad.h>
    #include <Joystick.h>
    #define ENABLE_PULLUPS
    #define NUMROTARIES 4
    #define NUMBUTTONS 32
    #define NUMROWS 8
    #define NUMCOLS 4
    byte buttons[NUMROWS][NUMCOLS] = {
      {0,1,2,3},
      {4,5,6,7},
      {8,9,10,11},
      {12,13,14,15},
      {16,17,18,19},
      {20,21,22,23},
      {24,25,26,27},
      {28,29,30,31},
    struct rotariesdef {
      byte pin1;
      byte pin2;
      int ccwchar;
      int cwchar;
      volatile unsigned char state;
    rotariesdef rotaries[NUMROTARIES] {
      {0,1,32,33,0},
      {2,3,34,35,0},
      {4,5,36,37,0},
      {6,7,38,39,0},
    #define DIR_CCW 0x10
    #define DIR_CW 0x20
    #define R_START 0x0
    #ifdef HALF_STEP
    #define R_CCW_BEGIN 0x1
    #define R_CW_BEGIN 0x2
    #define R_START_M 0x3
    #define R_CW_BEGIN_M 0x4
    #define R_CCW_BEGIN_M 0x5
    const unsigned char ttable[6][4] = {
      // R_START (00)
      {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
      // R_CCW_BEGIN
      {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
      // R_CW_BEGIN
      {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
      // R_START_M (11)
      {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
      // R_CW_BEGIN_M
      {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
      // R_CCW_BEGIN_M
      {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
    #else
    #define R_CW_FINAL 0x1
    #define R_CW_NEXT 0x3
    #define R_CCW_BEGIN 0x4
    #define R_CCW_FINAL 0x5
    #define R_CCW_NEXT 0x6
    const unsigned char ttable[7][4] = {
      // R_START
      {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
      // R_CW_FINAL
      {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
      // R_CW_BEGIN
      {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
      // R_CW_NEXT
      {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
      // R_CCW_BEGIN
      {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
      // R_CCW_FINAL
      {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
      // R_CCW_NEXT
      {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
    #endif
    byte rowPins[NUMROWS] = {21,20,19,18,15,14,16,10};
    byte colPins[NUMCOLS] = {9,8,7,6};
    Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
    Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
      JOYSTICK_TYPE_JOYSTICK, 32, 0,
      false, false, false, false, false, false,
      false, false, false, false, false);
    void setup() {
      Joystick.begin();
      rotary_init();}
    void loop() {
      CheckAllEncoders();
      CheckAllButtons();
    void CheckAllButtons(void) {
          if (buttbx.getKeys())
           for (int i=0; i<LIST_MAX; i++)
               if ( buttbx.key[i].stateChanged )
                switch (buttbx.key[i].kstate) {
                        case PRESSED:
                        case HOLD:
                                  Joystick.setButton(buttbx.key[i].kchar, 1);
                                  break;
                        case RELEASED:
                        case IDLE:
                                  Joystick.setButton(buttbx.key[i].kchar, 0);
                                  break;
    void rotary_init() {
      for (int i=0;i<NUMROTARIES;i++) {
        pinMode(rotaries[i].pin1, INPUT);
        pinMode(rotaries[i].pin2, INPUT);
        #ifdef ENABLE_PULLUPS
          digitalWrite(rotaries[i].pin1, HIGH);
          digitalWrite(rotaries[i].pin2, HIGH);
        #endif
    unsigned char rotary_process(int _i) {
       unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
      rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
      return (rotaries[_i].state & 0x30);
    void CheckAllEncoders(void) {
        unsigned char result = rotary_process(i);
        if (result == DIR_CCW) {
          Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
        if (result == DIR_CW) {
          Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
    The buttons all work. Windows recognizes the board as a gaming device. Everything is correct, but the buttons do not work well. There are buttons that activate, its corresponding button number, but there are others that activate 2 buttons, other buttons activate 3 buttons. I have reviewed everything and it seems to be fine, the cables correspond to the drawing. There are no cables that are touching each other and make a false connection.
    That is why I ask for help, to see if someone else can help me. Greetings to all and thanks.
  5. rt45433
    rt45433 New Member
    291Coins
    Hi there, I have been having a play with the project and have a basic understanding of this. I have 3d printed a flight sim cessna trim wheel that uses one rotary encoder. Would anyone be kind enough to put together the sketch for one rotary encoder used on a pro micro and show up as a game controller in windows. I am happy to gift £10 for anyone time on this via paypal to say thank you.
  6. dixion
    dixion New Member
    61Coins
    DC motor, Arduino
    Hi, can anyone help me with this code using Arduino IDE for ESP32 development board.
    Code:
    #include <ESP32Encoder.h>     // https://github.com/madhephaestus/ESP32Encoder/
    #include <Keypad.h>           // https://github.com/Chris--A/Keypad
    #include <BleGamepad.h>       // https://github.com/MagnusThome/ESP32-BLE-Gamepad
    BleGamepad bleGamepad("RaceKeys", "Arduino", 100);
    ////////////////////// BUTTON MATRIX //////////////////////
    #define ROWS 4
    #define COLS 4
    uint8_t rowPins[ROWS] = {27, 25, 12, 32};
    uint8_t colPins[COLS] = {17, 16, 00, 02};
    uint8_t keymap[ROWS][COLS] = {
      {0,1,2,3},
      {4,5,6,7},
      {8,9,10,11},
      {12,13,14,15}
    Keypad customKeypad = Keypad( makeKeymap(keymap), rowPins, colPins, ROWS, COLS);
    //////////// ROTARY ENCODERS (WITH PUSH SWITCHES) ////////////
    #define MAXENC 5
    uint8_t uppPin[MAXENC] = {36, 22, 39, 34, 19};
    uint8_t dwnPin[MAXENC] = {26, 21, 35, 14, 23};
    uint8_t prsPin[MAXENC] = {18, 15, 33, 13, 05};
    uint8_t encoderUpp[MAXENC] = {16,19,22,25,28};
    uint8_t encoderDwn[MAXENC] = {17,20,23,26,29};
    uint8_t encoderPrs[MAXENC] = {18,21,24,27,30};
    ESP32Encoder encoder[MAXENC];
    unsigned long holdoff[MAXENC] = {0,0,0,0,0};
    int32_t prevenccntr[MAXENC] = {0,0,0,0,0};
    bool prevprs[MAXENC] = {0,0,0,0,0};
    #define HOLDOFFTIME 150   // TO PREVENT MULTIPLE ROTATE "CLICKS" WITH CHEAP ENCODERS WHEN ONLY ONE CLICK IS INTENDED
    void setup() {
      Serial.begin(115200);
      for (uint8_t i=0; i<MAXENC; i++) {
        encoder[i].clearCount();
        encoder[i].attachSingleEdge(dwnPin[i], uppPin[i]);
        pinMode(prsPin[i], INPUT_PULLUP);
      customKeypad.addEventListener(keypadEvent);
      //customKeypad.setHoldTime(1);
      bleGamepad.begin();
      Serial.println("Booted!");
    void loop() {
      unsigned long now = millis();
      // -- ROTARY ENCODERS : ROTATION -- //
        int32_t cntr = encoder[i].getCount();
        if (cntr!=prevenccntr[i]) {
          if (!holdoff[i]) {
            if (cntr>prevenccntr[i]) { sendKey(encoderUpp[i]); }
            if (cntr<prevenccntr[i]) { sendKey(encoderDwn[i]); }
            holdoff[i] = now;
            if (holdoff[i]==0) holdoff[i] = 1;  // SAFEGUARD WRAP AROUND OF millis() (WHICH IS TO 0) SINCE holdoff[i]==0 HAS A SPECIAL MEANING ABOVE
          else if (now-holdoff[i] > HOLDOFFTIME) {
            prevenccntr[i] = encoder[i].getCount();
            holdoff[i] = 0;
      // -- ROTARY ENCODERS : PUSH SWITCH -- //
        bool pressed = !digitalRead(prsPin[i]);
        if (pressed != prevprs[i]) {
          if (pressed) {  // PRESSED
            pressKey(encoderPrs[i]);
          else {          // RELEASED
            releaseKey(encoderPrs[i]);
          prevprs[i] = !prevprs[i];
      customKeypad.getKey();    // READ BUTTON MATRIX (EVENT CALLBACK SETUP)
      delay(10);
    void keypadEvent(KeypadEvent key){
      uint8_t keystate = customKeypad.getState();
      if (keystate==PRESSED)  { pressKey(key); }
      if (keystate==RELEASED) { releaseKey(key); }
    void sendKey(uint8_t key) {
        uint32_t gamepadbutton = pow(2,key);      // CONVERT TO THE BINARY MAPPING GAMEPAD KEYS USE
        Serial.print("pulse\t");
        Serial.println(key);
        if(bleGamepad.isConnected()) {
          bleGamepad.press(gamepadbutton);
          delay(150);
          bleGamepad.release(gamepadbutton);
    void pressKey(uint8_t key) {
        Serial.print("hold\t");
    void releaseKey(uint8_t key) {
        Serial.print("release\t");
  7. dixion
    dixion New Member
    61Coins
    DC motor, Arduino
  8. Angelo Spano
    Angelo Spano New Member
    3Coins
    sorry ... it is possible to insert 2 potentiometers in the project, thanks for the reply
  9. Angelo Spano
    3Coins
    I would like to ask if there is anyone who is able to modify the code by adding another potentiometer, unfortunately I am new to arduino ... I have tried but I have not succeeded. thanks to those who want to help me.
  10. Nesquik
    Nesquik New Member
    18Coins
    Hey, friends, I have a poor experience with an Arduino as well as with micro-electronics in general. I made my button-box by this guide successfully, but I would like to use a button with a 5v indicator so I've been trying to connect It to VCC and GND of my Pro Micro to give the button additional voltage, but as soon as It happened the box became working incorrectly and windows assign a few button positions to one physical button of the box. How I could fix It?
  11. dillario
    dillario New Member
    17Coins
    Hello. I am new here and need your help . I downloaded the Buttonbox Sketch from Amstudio. I wanted to ask if anyone can help me change it so that I can connect 2 Hall sensors? Need that for the clutch on the steering wheel. Thank you
  12. Paulinho_mi02
    Paulinho_mi02 New Member
    18Coins
    I tested as a keyboard on XBOX One and the rotating ones worked perfectly in the Dash console menu, but unfortunately the rotating did not work perfectly in the game, I testedf1 2021. I tried to use the rotarys in fuel adjustment and brake and differential bias but the rotarys worked late and with failures. It seems that the game does not communicate properly with the rotating as well as the Dash console menu. Did you take the ps4 test?
  13. tina540
    tina540 New Member
    - 44Coins
    Hi guys, here is the drawing of my button box, I wanted to know if the wiring is good and which library and other I must install on the arduino so that it works with my diagram. thank you
  14. tina540
    tina540 New Member
    - 44Coins
    I don't know if my photo is uploaded
  15. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    New
    Could someone give me a hand... I want to load this code on an Arduino micro and it gives me this error
  16. noorbeast
    153,746Coins
    Try using #include instead.
  17. evolaco
    evolaco Member
    Spain
    694Coins
    Is that code in Spanish? have you translated it? Those orders and libraries seem to be translated from English to Spanish.
  18. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    They are the ones I copied from page 10 that the creator put.. I don't understand why it gives me this error
  19. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    Could you give me a hand... because I get this error like the word joystick has something wrong... I want to load the code into my arduino just as you put it in voice Captura de pantalla 2023-10-28 214605.png
    153,746Coins
    The code on page 10 is in English, the code you posted is not.
