Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. iLLuac4
    iLLuac4 Active Member
    896Coins
    Hi. I have tried today all options and the plugin does not cooperate with SimHub and SimTools at the same time no matter what I do. It works only with SimTools.
    Will there be an update for dx12? Hope so.
  2. Andreawrc83
    Andreawrc83 Andywrc Gold Contributor
    commerciante
    italia
    73Coins
    Are there news for dx12 plugin of f1 2019? I need it :( Please is also not possible to have plugin? Dashboard don't go good with the legacy mod.
  3. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Dumb question, but how do I run the game in DX11 mode? I can't seem to find that option anywhere.
  4. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    not tested by me but go into steam and F1 2019 properties, in the launch options type -force-d3d11
  5. Andreawrc83
    commerciante
    italia
    73Coins
    You must open the game with steam, in f1 2019 you click play and you can see one window where you can select dx11 mode
  6. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    Motion platform, 4DOF
    i now use FlyPt for F1-2019 with dasboard. works fine
  7. Andreawrc83
    commerciante
    italia
    73Coins
    Thanks, i must only download flypt or i must download any file for f1 2019 dx12?
  8. nornesnaj
    Netherlands, Zelhem
    125Coins
    you only need to download the latest FLYPT there are some example files in the download.
    i use a pt actuator set so only had to change the so called sorce from iracing to F1-2019.
  9. Andreawrc83
    commerciante
    italia
    73Coins
    Ok thanks a lot... :thumbs
  10. Andreawrc83
    commerciante
    italia
    73Coins
    I have 2dof, are in the example one file in 2dof? So i can use that...
    Hello.. i use 2dof with rotating actuators. I must use together simtool and flypt oder only flypt? I install it and i tried and tried again and I was finally able to move my seat, but in the prolonged movements to the right and left comes at the end of the race of actuators. Someone can help me or someone have an example of 2dof mover to give me?
  11. nornesnaj
    Netherlands, Zelhem
    125Coins
    Hi i dont know if there is a example for 2dof.
    i would advice to go to the flypt tread and start the first chapters there is good info.
    you can use its either way with or without simtools
  12. Andreawrc83
    commerciante
    italia
    73Coins
    Ok thenks :thumbs
  13. bruno1210
    bruno1210 schumi06
    103Coins
    If I understand correctly with the FlyPT software you are playing in dx12 at f1 2019 + simtools ?
  14. Andreawrc83
    commerciante
    italia
    73Coins
    Yes, you can play f1 2019 dx12 with flypt software, without simtools!!! hug:
  15. Andreawrc83
    commerciante
    italia
    73Coins
    I don't understand why nobody say us that's possible...
  16. bruno1210
    bruno1210 schumi06
    103Coins
    or found a tutorial to install all with f1 2019 or another game because I understood for the telemetry interface just a little help for the axes thank you
  17. Andreawrc83
    commerciante
    italia
    73Coins
  18. bruno1210
    bruno1210 schumi06
    103Coins
  19. bruno1210
    bruno1210 schumi06
    103Coins
    I don't understand how to configure the surge and sway effects and on everything tested can you help with an example file for f1 2019 thanks
  20. Andreawrc83
    commerciante
    italia
    73Coins
    Hello.. in flypt there are some example. Not for my sim, i've 2 dof and i didn't find an example for me.
    I'm at work, in the afternoon i send you what i do :thumbs
