MY own 2 dof diy
Discussion in 'DIY Motion Simulator Projects' started by absyfadhel1, Apr 17, 2020.
  1. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    is this setting right? becuase nothing move until now
    and i tryied what you said but nothing good
  2. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    no sorry you misunderstand leave simtools settings as they are and in windows go to
    Documents\My Games\DiRT Rally 2.0\hardwaresettings and look for file called
    hardware_settings_config.xml open in note pad and look for the line
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="127.0.0.1" port="4123" delay="1" />
  3. Daguru
    Kitchen installer
    Wales uk
    460Coins
    Motion platform
    hope this helps
    151,596Coins
    +11,043 / 56 / -2
    Keep your Interface Settings as Serial.
  5. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    i have diy license but i cant download plugin , what the problme?
  6. RaceRay
    Hamburg, Germany
    23,876Coins
  7. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    151,596Coins
    +11,043 / 56 / -2
    SimTools (software) and Xsimulator.net (community and community developed plugins) are two different entities: https://www.xsimulator.net/community/faq/simtools-and-xsimulator-partnership-explained.275/
    SimTools provides free DIY licenses for eligible members, and Xsimulator.net has forum activity coins, to encourage genuine community participation, which can be used to purchase plugin access, or if you don't want to participate in the community you can just buy a membership package: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
  9. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    oh yes unfortuantly i thought if i get diy license i will be able to download plugin... nvm i will try to charge my pypal
  10. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    i recently upgrade my pc and i formated it so now i reinstalled the simtools and when i try to regestir the license its say no activitation remenning .. help
    151,596Coins
    +11,043 / 56 / -2
    You will have to take that up via the SimTools page: https://simtools.us/contact-us/
  12. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    so i need to purchase 25 euro for download only one plugin!?.. i know if i purchase i will download unlimited for 2 years but i only want one plugin... there is any way to purshae only xs coin?
  13. noorbeast
    151,596Coins
    +11,043 / 56 / -2
  14. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    iam bored from searching for microsoft flight simulator 2020 plugin for simtools...where can i found it or it's not released yet?
    151,596Coins
    +11,043 / 56 / -2
  16. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    After few month of testing 2dof with wiper motor until now i cant enjoy it becuase the motor cant take the wieght, i add a spring in back to help but its just cant pull up its go hot and the fan i put in the ardiuno box go slow becuase of wieght.
    I need someone to tell me what kind of motor can i use to take wieght? In my country there is few store for this and i dont know what to use . Help
    151,596Coins
    +11,043 / 56 / -2
  18. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    Yes but in my country there is no one sale wormgear motor so i must use diffrent motor but i dont know what to use...and ordring worm gear online the shiping over 260$
  19. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    Hi...i have 12v wiper motor and i try everything to make it work fine but unfortuantly i could'nt do that....i tryed to make the motor in the front but no enught power to move ...i try to make it in the back but it was the same ...i add a spring in the diffrent position (motor in front =spring in back and like that) but nothing change the motor cant take weight i bought about 6 diffrent motor but i lost my money on nothing...help
    Note: i already used (simcalc) software please dont tell to use because i used it before..
    I use 2 computer powersupply connected together does it matter to use pc powersupply or this type of powersupply?
    I use 2x of this
    You think if i use this type i will get more strong motor?
    Hope you help me guys
    This is a photo of my setup...i already change alot but its same i kept the seat only but nothing change i thought if i use the seat only i will loos weight but nothing change
  20. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    Note: this photo is old...i already change the position of the rod to make it stright like simcalc advice
