Experimental DCS Plugin ready for testing
Discussion in 'Digital Combat Simulators (DCS)' started by Dirty, Jun 28, 2019.
  1. Bastiuscha
    Bastiuscha Active Member
    750Coins
    Thanks a lot, for this nice plugin! Will be a vibration support someday?
  2. Dirty
    All the way up front.
    7,971Coins
    I would love to add GameDash or GameVibe support! :)
    I am a bit busy right now, so I don't want to open up a new "construction site" in my hobby :) but if there's someone out there who has done that before and can sketch out to me roughly what I would have to do, I'd happily do the programming and testing. I just don't wanna stumble in the dark for weeks without knowing whether I am even going in the right direction.
    PM me if anyone wants to help :)
  3. Dirty
    7,971Coins
    ...or even better:
    If anyone can show me source code of other plugins supporting GameDash and/or GameVibe, I guess I could adapt it with minimal effort. :thumbs
    Dirty :)
    153,830Coins
    +11,151 / 57 / -2
    @yobuddy should be able to give advice.
  5. yobuddy
    51,534Coins
    Hi @Dirty,
    PM be buddy and I will send you some examples!
    Its really not to hard at all.
    Take care,
  6. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    @Dirty,@yobuddy
    Thanyou for looking at this. Gamevibe support for DCS will be great.
  7. Bastiuscha
    750Coins
    Hey friends! I would like to test the dcs world "beta". Is there a way to install the plugin on beta? Because the auto plugininstaller only install on the normal dcs version.
  8. Dirty
    7,971Coins
    Oh yes, there is! Once you have DCS patched for motion...
    1. Go to "<UserFolder>/SavedGames/DCS/Scripts/Hooks" and find the file "SimTools_DCS_Exp_Hook_v008". Rightclick --> Copy.
    2. Go to <UserFolder>/SavedGames/DCS.openbeta/Scripts/Hooks" and rightclick --> Paste.
    If there is no "Hooks" folder (which is most certainly the case on a fresh install), just create it.
    You can also copy the entire "Hooks" folder over if you want to migrate all other add-ons in there as well.
    That's it :) Just don't run the openbeta and stable version at the same time!
    Cheers,... Dirty :)
  9. Bastiuscha
    750Coins
    Much thanks my friend. But in my case, the file was in the simulation folder itself. Not in the "saved games" folder. But thanks al lot! :):) With your instructions, i was able to find the solution quickly.
  10. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Is there any progress regarding the DCS gamevibe?
  11. Mikko Leino
    Mikko Leino New Member Gold Contributor
    Aircraft Maintenance Engineer
    Finland
    185Coins
    4DOF
    This plugin is great and very realistic, once tweaked for your own sim. Sadly, after updating I seem to have lost yaw completely. The second I start flying, it jerks to 57.XXXX and stays there no matter what.¨
    Any ideas? Thanks.
  12. Dirty
    7,971Coins
    Hey :)
    Plenty of ideas! I'm sure we will find out why that happens. Can you make a screenshot or a quick video?
  13. MarkusB
    4,215Coins
    Hi All,
    I don't manage to get the DCS Experimental Plugin v0.08 running.
    According to the message below, the patch has been installed correctly:
    Now the PlugIn shows up correctly in Game Manager:
    I have set up a motion profile in Game Engine:
    When starting DCS via Steam, Game Engine seems to regognize the game, because the buttons "Axis Asignment" and "Interface Settings" turn blue as expected:
    The Tuning Center shows the DCS-specific Extra1-3 labels "OpenData1", "OpenData2", and "OpenData3".
    But: When flying, all Tuning Center values remain zero and I don't get any motion.
    The "non-experimental" DCS PlugIn works correctly, and so do the P3D and NL2 PlugIns. Also output testing in Game Engine works without any problems.
    I also uninstalled the other DCS PlugIn, but this did not solve the issue.
    Any ideas what I am doing wrong?
    Best regards,
    Markus
  14. Dirty
    7,971Coins
    Did you fully restart DCS (not just a mission reload)?
  15. MarkusB
    4,215Coins
    Yes, I fully restarted DCS.
  16. Dirty
    7,971Coins
    I will PM you. I would like to find out why this is, because I want to prevent others from running into the same trouble.
    Dirty :)
  17. MarkusB
    4,215Coins
    @Dirty, thanks a lot for your immediate help! Now that I get motion values into the Tuning Center, my rig is moving with your plugin. Fantastic! Within the next days I hope to find some time for tuning my configuration and for remembering how to fly this TF-51.
    @All: My problem was caused by an old "Export.lua" file that belonged to the original DCS plugin:
    After renaming this file, everything works perfectly.
    Thanks again and greetings to Bavaria. :cheers
  18. WLuser
    WLuser New Member Gold Contributor
    - 159Coins
    hello.
    i cant seem to find the export.lua file...i patched the simtools but that only seem to add a dll
  19. WLuser
    - 159Coins
    nevermind. i got it.. i thought patching was simply drag drop into updated...i also had to patch in game manager
  20. WLuser
    - 159Coins
    thank you for this great plugin!
