SimTools v2 - Game Vibe v2.0
A telemetry driven re-configurable transducer system for SimTools.
  1. valvestart
    valvestart New Member
    128Coins
    Many thanks for the information, I really hope there will be an upgrade to support Grand Prix Legends, I know many are rediscovering this unique game
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    gamevibe dont offer support for this specific game.
  3. valvestart
    128Coins
    Thanks, I take this occasion to highlight that a relevant game as GPL should be considered for forthcoming update. Afaik at the moment there is no way to get a proper rumble feedback on this game.
  4. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Help, after reinstalling windows and re-installing everything, I have this problem, I don't have game data.
    151,479Coins
    +11,041 / 56 / -2
    Just checking, do you have a Pro SimTools license.
    If so can you please post pictures of all of your settings.
  6. Bastiuscha
    Bastiuscha Active Member
    750Coins
    DCS plugin don‘t support game vibe.
  7. Pastrana
    Pastrana Member
    Argentina
    165Coins
    If I have a PRO license, it happens in all games, nothing changes. Gamevibe1, gamevibe2, etc. always come out
  8. Pastrana
    Pastrana Member
    Argentina
    165Coins
    151,479Coins
    +11,041 / 56 / -2
    The games you have shown pictures of, DCS and Aerofly, do not currently have GaameVibe support. So test with LFS then configure for games that do have GameVibe support.
  10. Pastrana
    Pastrana Member
    Argentina
    165Coins
    If indeed it was the games that do not have gamevibe. There is no one to make a gamevibe plugin for DCS?
    151,479Coins
    +11,041 / 56 / -2
  12. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    I just installed Gamevibe today.
    When flying in War Thunder my Hotas controls stop working?
    When I turn my amp off the controls work?
    What am I doing wrong?
    I run dirt rally and Iracing with Simvibe with no issues.
  13. Bastiuscha
    750Coins
    That sounds like USB problems. did you check different usb ports?
  14. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    I can try a different usb tonight
    I tried iracing after War Thunder with simvibe and had no issues.
  15. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    I just swapped all 3 USB’s, the throttle the joystick and the rudders into a different USB powered PCI card and I have the same issue where when game vibe is running I lose the hotas controls? When I turn the amp off I have control of my Hotas controls again
  16. yobuddy
    50,753Coins
    This sounds like a possible grounding issue?
    What does you GameVibe setup look like buddy?
    Take care,
  17. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    @yobuddy - Sorry for late reply.
    I have 2 soundcards setup for simvibe. I have successfully added these to gamevibe and they both work in the soundcard setup.
    However in the gamevibe creator setup only soundcard 1 will work? What have I done wrong?
    I have also setup the gamevibe tuning.
    I am unsure what ip address to add, so I added the IP I have fir the game engine. Is this correct?
    I have no issues using simvibe with my racing games.
    I have no issues with my warthog Hotas setup when using the Next level racing V3 seat mover with their platform manager tactile feedback.
    For some reason my Hotas controls stop responding with gamevibe?
  18. yobuddy
    50,753Coins
    If you using GameVibe of the same PC as Game Manger / Game Engine, then the IP should be 127.0.0.1.
    You select sound card 2 radio button click turn on and nothing?
    I only ask because the same code is used to test and configure sound.
    So it makes little sense to me why it would worn in one spot and not the next is all.
    Chat soon,
  19. djkc
    djkc Member
    Australia
    94Coins
    3DOF, SCN5
    Thanks. Ill change the IP tomorrow
  20. ERGUN OZYURT
    ERGUN OZYURT erguno
    Turkey
    - 246Coins
    2DOF, 3DOF
    Hi, I am using game vibe with many games, no problem. But today I tried to play Dirt 4, got an exception(s) from vibe and after ok the exception message, vibe is closing. When the dirt 4 is open, vibe always in an exception and closing. The message(s) is "RI_VibrationID.cfg file not found? Game Vibe will now exit." , "Rr_VibrationID.cfg file not found? Game Vibe will now exit." and total 7 error messages windows like this.
    I unisntalled and re installed Game Vibe a lot of times, but no luck. And idea ?
