Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. Chipless
    Chipless Member
    152Coins
    Thank you so much for the reply. So, just to be clear: I will just hook up the speaker cables to actual speakers rather than the transducers? Are there any settings on Game Vibe that I need to change as well?
  2. yobuddy
    51,526Coins
    Yes, just set the sound card to something that has normal speakers hooked up.
    I actually wrote the app using real speakers as testing was easier.
    Let me know how it goes buddy.
    Take care,
  3. Chipless
    Chipless Member
    152Coins
    So, I hooked up the speakers from my stereo system, and I still have the same annoying crackling/snapping/clicking noise. I also noticed that I am getting the same noise within Vibe Creator whenever I move the "Percent Used" slider around within the Testing section.
  4. Chipless
    Chipless Member
    152Coins
    Wanted to clarify my post above, I do not get the clicking/snapping noise in any static position that I leave the "Percent Used" slider in, but as soon as I move it, the unpleasant sound returns, and it continues until I stop moving the slider.
  5. Chipless
    Chipless Member
    152Coins
    @yobuddy Any ideas what the problem is? Unfortunately, the noise makes things pretty unusable since it is quite noticeable at all game volume levels :( Hopefully, the information I provided is helpful for troubleshooting, but if I need to do something else to help narrow the issue down, please don't hesitate to let me know. Thanks!
  6. yobuddy
    51,526Coins
    someone else told me tonight they fix a "crackling" issue by turning on the LFE channel.
    (Seems the LFE channel was accidentally going to the shakers.)
    I bet its something with the setup. got any pics?
  7. Chipless
    Chipless Member
    152Coins
    I've tried it with all enhancements disabled (e.g. bass management disabled) as well. Same result. Am I supposed to hear what sounds like rapid mouse clicking when I slide the "Percent Used" slider in the Vibe Creator? Can someone please experiment and report back when you get a chance?
  8. yobuddy
    51,526Coins
    What do you Game Vibe settings look like?
  9. Chipless
    Chipless Member
    152Coins
  10. yobuddy
    51,526Coins
    The Settings look ok to me.
    What does the new sound card do?
    Do you have another PC just for a test?
  11. Chipless
    Chipless Member
    152Coins
    The new sound card is just an external USB sound device/external DAC, doesn't do anything other than act as a digital audio converter I'm pretty sure. It's selectable as a sound output device in Windows, which you can see in my Speaker Properties where it's listed as a "USB Audio Device". It was suggested by @noorbeast as a troubleshooting step. I've also tried it without the USB too of course. Here is the one I bought:
    Can someone please verify that they do not hear any sort of loud and rapid mouse-clicking type noise while sliding the "Percent Used" slider in Game Vibe's vibe creator? I'm almost positive it has something to do with that since the sound is almost identical to what I'm hearing in the game, and I've been able to determine it's not a problem with AMS2 given that there is no problem with a constant RPM value (e.g. when a car is idling or at redline). Thus, it is a problem with Game Vibe or Windows, or the interface between the two. FWIW, I've also tried playing music through the transducers I'm using, and then changing the music volume with the volume slider within Windows just to make sure there isn't any sort of distortion or weird noises as the volume is changed.
    It would be great if someone with the latest version of Windows 10 could verify that there are no weird noises when manipulating the "Percent Used" slider. I am running out of ideas on my own since I'm not a software programmer and can't take a look "under the hood" of Game Vibe so-to-speak.
  12. Chipless
    Chipless Member
    152Coins
    @yobuddy Any ideas based on the above? I'd really like to get this working.
  13. Dave Nichols
    Dave Nichols New Member Gold Contributor
    205Coins
    I have downloaded GameVibe. It works in that all the tests make noises and I can create vibes. But it does not work in that all the vibe names in the profile are "GameVibe#" with a big X. I'm using Assetto Corsa with the latest plugin. I've followed your mannual maticulously. What am I missing? Attached is a screenshot of Game Vibe profiler editor. GameVibe.PNG
  14. yobuddy
    51,526Coins
    The first time you try to use Game Vibe with Ac, the 'GameVibe#' will all fill in.
    Since Game Vibe is a separate app, it needs game manger to tell it what the 'GameVibe#' are.
    Give it a shot and let me know. :thumbs
    Take care,
  15. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    Thanks @yobuddy for the gamevibe program. I am using it with my flight sim.
    Just a FYI for others.. You can use Bluetooth to send out the vibes wirelessly.
    I have my little Amazon Echo Dot hooked to my subwoofer amp and then to my transducer.
    No need for an additional soundcard.
    Saves a little on the wiring from the pc to the simrig also..:):):)
  16. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    I'm trying to convert from SimXperience SimCommand/SimVibe over to game vibe to keep my motion and haptic feedback on the same software. The issue I have is I cannot get comparable control over vibrations for all sorts of triggers (most likely because I'm a newbie and GameVibe uses a different approach with a different lingo.
    Question: Is there a way to import presets from other users?
    Question: Are there people sharing their "setup" that I can use for iRacing, AMS2, etc... I'm not getting much luck at the moment with the quality of the effects. In other words, I'm not getting good vibes! :)
    153,764Coins
    +11,149 / 57 / -2
    GameVibe Hi/Low profiles can be posted, see here, but I don't recall many doing so: https://www.xsimulator.net/community/threads/gamevibe-ready-profiles.12220/#post-159160
    There files can be found here:
    "C:\Users\(your user folder)\AppData\Local\GameVibe\HiLowProfiles"
    You are likely to need to provide far more detail than 'not getting good vibes', are you following the guide here and can you please post pictures of all of your settings, along with some explanation of what effects you are looking for, that way @yobuddy and others may be able to offer advice.
  18. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Going through the process of reinstalling everything on a new PC and run into a dll missing issue with SimVibe. Anyone know a fix? I have tried to download and run the DirectX9 update but it says I am OK for that.
    Error is appearing when i click save after choosing my sound card.
    153,764Coins
    +11,149 / 57 / -2
  20. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
