How to choose potentiometer
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by DonCorleonez, Mar 15, 2016.
  1. RacingMat
    21,039Coins
    I don't know for JRK but Arduino built in ADC (analog to digital converter on Analogic pins) is optimized for 10k ohm :)
  2. Raymann
    Raymann New Member
    278Coins
    Hi
    When i understand that right ,hall pots are plug and play to ardinio?
    I have crashd my normsl pot,and wil by hall pots.
    Normaly can i replace the normal with the hall pot,or is tomthing to do?
    Sry for my bad english :-(
    151,467Coins
    +11,041 / 56 / -2
    You can use Hall sensors as a drop in replacement of pots and mounting them is simple as you don't need to gear them.
    I have used these 180 Hall sensors, Element 14 has worldwide distribution: au.element14.com/bi-technologies-tt-electronics/6127v1a180l-5fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
  4. Raymann
    Raymann New Member
    278Coins
    Thanks for the information, but one more question I have
    Need hall sensors a magnet on the shaft, or can i built them nearly to the shaft and it works?
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
  6. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Interesting mechanical angle and electrical angle 360 °.
    Mine are mechanically 360 ° but 340 ° electrical angle, so with a dead zone of 20 °
    Your potentiometers with the mechanical angle and electrical angle 360 ° were they an operating shaft 6mm and 6.35mm?
    Bonjour,
    Intéressant l'angle mécanique et l'angle électriques à 360°.
    Les miens sont des 360° mécaniquement mais des 340° pour l'angle électrique , donc avec une zone morte de 20°
    Vos potentiomètres avec l'angle mécanique et l'angle électriques à 360° ont-ils un axe de manœuvre de 6mm ou de 6,35mm ?
  7. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    I just found the answer by reading the datasheet for a pin 6mm I need the model 6124
    Bonjour,
    Je viens de trouver la réponse en lisant le datasheet, pour un axe de 6mm il me faut le modèle 6124
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    FYI: I bought that Hall effect potentiometer 3 years ago and today I had one disintegrate on my hands while cleaning! i guess the housing is plastic and with time they come apart easy
  9. Nick Moxley
    17,056Coins
    Im still on my Original set in which were LOCKED up twice (due to too Rigid of Pot mount) and required BIG BIG pliers to free up.
    They are FAR from Fragile if you ask me.
  10. baxbax
    baxbax New Member
    135Coins
    A question, about, these Hall potentiometers:
    how can I put the value in the middle when I will mount the potentiometer on the motor axe?
    Thanks in advance
  11. BlazinH
    16,661Coins
    Apply 5v from Arduino or other source. Use volt meter and twist pot until output reads 2.5v.
  12. baxbax
    baxbax New Member
    135Coins
    Thank you very much!!!
  13. Djalma Ribeiro
    Djalma Ribeiro Member
    Drone Pilot
    Cuiabá, Brazil
    168Coins
    Where do I buy this pot? Any Chinese website?
    151,467Coins
    +11,041 / 56 / -2
  15. czgui
    czgui Member
    - 110Coins
    You can go to (Taobao), the price is about 10 dollars.
  16. chavilap
    chavilap New Member Gold Contributor
    5Coins
    Hi, I recently bought these hall effect gyro sensors to replace my old Bourns 5 ohm potentiometers.
    https://www.ebay.es/itm/Hall-angle-...rand=Unbranded&_trksid=p2047675.c100012.m1985
    And now that I want to change them, a question arises: I know that I can change the polarity of the bourns, that is, I can invest as appropriate between vcc and gnd so that it goes hand in hand with its motor. But I don't know if I can do the same with these new sensors.
    I hope I have explained myself well.
  17. chavilap
    5Coins
    Sorry, I answer myself: can´t reverse vcc and gnd on hall sensor.
    I just found the answer:blush.
  18. Arihant
    Arihant New Member
    Electronic Enginner
    Mexico
    96Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    Hi, i buyed 360 deg hall sensors pot but i want connect it directly to the motor shaft without any gear, so this is my question . do i need make some adjustment in the smc3 ino file in the arduino to get the right feedback from the pots????? Or it can be adjusted with the clip limit??? Thanks in advance
    151,467Coins
    +11,041 / 56 / -2
    Use a correctly sized flexible connector to directly link the Hall Sensor and motor: https://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
    You can use the SMC3 utility to make the settings adjustment, you don't need to mess with the ino file.
  20. Zed
    USA
    5,844Coins
    Just to add, there are also Hall sensors that have separate magnets and sensors. While you need to be careful to get the magnet aligned with the sensor axis, that’s pretty easy to do with 3D printing and there is no bearing to gall and bind. Just make a mount for the magnet that fits to the rotating part and a mount for the sensor itself that is fixed in position. Besides the need for proper magnet alignment in the X-Y plane of the sensor, there is also a distance requirement between the magnet and sensor but these are all less demanding than alignment with the shafted Hall sensors. Plus, separate magnet Hall sensors need no lubrication because nothing touches or rubs. I used separate magnet Hall sensors and they have been totally trouble free with the only issue being my output arms hit early versions on my sensor mounts and broke them. That was preventable and entirely my fault. Operationally, no issues at all with the Hall sensors. Highly recommended - shafted or free.
