value1
Microsoft Flight Simulator X / Lockheed Martin Prepar3D Plugin 2.0.2.0
SimTools plugin for Microsoft Flight Simulator X and Lockheed Martin Prepar3D
  1. noorbeast
    151,480Coins
    +11,041 / 56 / -2
    Please hit the Details tab in the error message and post the full thing, perhaps @value1 can then work out what is going on.
  2. Kashif Saeed
    Kashif Saeed New Member
    49Coins
    2DOF, 3DOF, 6DOF
    hey @noorbeast
    i have installed SimConnect.msi again and restarted my laptop and my error is gone now.:)
    Now, P3D providing the data but there is still no data of FSX.:(
    @value1 , will you please help me to resolve this issue.
    TIA
  3. Kashif Saeed
    49Coins
    2DOF, 3DOF, 6DOF
    hey @noorbeast, @value1
    I am facing a problem regarding YAW motion.
    After approaching the YAW value to 180, sintools shifting the value to -180 and decreasing accordingly .
    Please help me in this matter.
    Waiting for your kind response.
    TIA.
  4. Thomas Käfer
    Thomas Käfer New Member Gold Contributor
    - 63Coins
    Hi all,
    I have installed Prepar3D V5 and tried the last plugin for simtools I have found here. Simtools says that the game is patched and I can choose the profile. But when I run Prepare3D V5 nothing happens with the simulator.
    Is the plugin compatible with V5? Does anyone have a working plugin / profile for this?
    Thanks in advance
    Thomas
  5. Thomas Käfer
    - 63Coins
    In the meantime I have got in working, but it is not perfect, because the cockpit does not stay in a side position (Roll) when you are flying a u-turn. It swipes sideways but then it moves back to center although the plane is still doing the curve.
    Do you have an actual plugin for simtools for Prepare3D or do you know how to make the cockpit stay in the tilt position?
    151,480Coins
    +11,041 / 56 / -2
    Are you using traditional pitch/roll/yaw or the optional angular velocities of Extra1-3, which should do what you want.
  7. Thomas Käfer
    - 63Coins
    Hi, I changed it to extra1-3, but it was not a big step forward. Pitch seems to be ok, but roll does not really wor properly. Do you have a screenshot for a 4DOF with nthe recommended settings?
    151,480Coins
    +11,041 / 56 / -2
  9. Thomas Käfer
    - 63Coins
    Ok thx, I will try this.
