Grand Theft Auto 5 ScriptHookVDotNet3 plugin
Discussion in 'SimTools Plugins' started by knaufinator, May 18, 2020.
  1. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    So I am updating my view on Traction loss, and invite anyone to correct me if I am wrong,... but there is not allot of information on this topic available so its just me piecing things together...
    Traction loss in most plugins is actually simple,... it is the Velocity on the y axis, that is the side to side axis of the vehicle.
    And that is what I have in the latest plugin, ... I noticed as well as others that traction loss still felt off. Maybe I can smooth that out some in the telemetry server side. put it through a kalman filter or just average it,...
    Before I was going off and calculating side slip angles and scaling that with the acceleration vector and all that fun stuff....it seems to be much simpler than that.... unless anyone else can chime in?
  2. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    I have achieved a good loss of traction movement but using the Yaw instead of the extra1
  3. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    I find this suspect, yaw should be a continuous change from 0 to 360 degree depending on what direction you are facing.
  4. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    Gentlemen, I have added a filter to the y velocity value, this helps greatly to sort the erratic behavior that I was getting on trac loss.
    I will make a new video showing this function.
    I have updated the github project both code and compiled version, only compiled one that changed was the GTAVhook dll
    i recommend for traction loss use extra_3 (min/max = -25/25 ) so far works well for me
    pitch,roll,yaw,surge,sway,heave - rotationAccelerationX(extra1),rotationAccelerationY(extra2),tractionLoss(extra3)
    153,770Coins
    +11,150 / 57 / -2
    Yaw is rotation around a central pivot point, TL pivots from somewhere around your feet they are 2 distinct and different motion effects.
  6. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    Alright dudes, I have uploaded a video showing the result of the traction loss changes, I am satisfied. I ended up adding a averaging filter to the raw data stream to smooth it out.
  7. kevinmarz
    kevinmarz Member
    346Coins
    Anyone out there...Try this plugin with Dof reality p3 set up...not getting that much movement out of tuning center..just wondering if someone with the same set up is experiencing the same results..my home D.I.Y P.of.crap get better movement...lol.hahahaha...
  8. J-1775
    J-1775 Aviator
    1,588Coins
    Definitely. Steam version with LukeRoss' VR, TM and enhanced trainer. Vive Pro and OVRIE. All working together.
    However, with all new arrivals in flightsims (DCS, IL-2, WT) I switched my gear back to flight controls...
  9. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Can you play online with those steering wheel mods? the x360ce program used for any controller can get you banned. Thanks
  10. polybasss
    Burgos Spain
    155Coins
    No, just story mode
  11. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Ok thsnks
  12. J-1775
    J-1775 Aviator
    1,588Coins
    Must confess I never played GTA V online.:think
  13. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    It is ok specially F1 races with random crazy people. I want a wheel to be more accurate on corners. You can be beaten by kids with just a keyboard lol
  14. the2jakes
    the2jakes Member Gold Contributor
    137Coins
    DC motor, Arduino, 4DOF
    Hi, great job done here ! Does it work on the Standalone version of GTA V, or only on Steam version ?
    (I run standalone version, with wheel mod, and I’d love to make my motion sim alive on it).
  15. Michael C Jenkins
    Michael C Jenkins New Member
    18Coins
    I'm trying to get the plugin that came with Manual Transmission mod to work with the NLR v3. The buttkicker is working but the motion is not, even though the diagnostic tool shows data coming in on a bunch of different graphs. I don't know enough to make sense of all of them, but I would think it should be working. I tried FH4 just to make sure the motion platform was still communicating with Platform Manager in general, and it was indeed working.
    Any advice for me?
  16. zhai1987
    zhai1987 Member
    320Coins
    2DOF, 3DOF, AC motor
    Brother, do you know why there was no feedback?
  17. zhai1987
    zhai1987 Member
    320Coins
  18. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    it will only output data while you are in a vehicle, .. but there could certainly be other things going on. ... i am just going off your screenshot... you are not in a vehicle.
  19. zhai1987
    zhai1987 Member
    320Coins
    I'm driving, but he hasn't given any feedback!
  20. zhai1987
    zhai1987 Member
    320Coins
      1. Install scripthookv
      1. Install scripthookvdotnet
    I don't know if I have installed these two incorrectly. Can you share the file?
