do-it-yourself static 2dof dynamic conversion
Discussion in 'DIY Motion Simulator Projects' started by pfm21, Jun 17, 2020.
  1. noorbeast
    151,479Coins
    +11,041 / 56 / -2
  2. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
  3. pfm21
    374Coins
    151,479Coins
    +11,041 / 56 / -2
  5. pfm21
    374Coins
    why are 25.1 and not 60?
  6. pfm21
    374Coins
    but you then changed the laps box? so these are not strong enough?
    151,479Coins
    +11,041 / 56 / -2
    Yes I changed the gearboxes to 60:1s on my compact rig.
    I started with 25:1s, don't get me wrong they will move a properly designed compact design rig OK, but got a bit warm with heavier users and as I mention could easily be back driven, the latter was an issue for my particular use.
  8. pfm21
    374Coins
    ok so I can take them safely?
    151,479Coins
    +11,041 / 56 / -2
    Yes 25:1s will work on a compact design, but give them the maximum design leverage you can, use sensible CTC for levers, as torque is more important than speed on a compact rig, and minimize the mass where possible.
  10. pfm21
    374Coins
    but if i also wanted to add the third motor for the traction loss can i use this scheme by connecting only the 3 motor? thanks
  11. pfm21
    374Coins
    I would like to do something like this because it is a great job
      232.3 KB
      360
      319.5 KB
      360
  12. pfm21
    374Coins
    thanks to @diegocom for the excellent work he has shown
  13. pfm21
    374Coins
  14. pfm21
    374Coins
    somebody help me. I have problems with the motors or when I try to push them down they deactivate and do not return to the central position. making the motors move in hand with Smc3 do their job. also in the central position they jump a bit. who gives me some indication to solve? in fact when seated, if you lean too far forward with your body weight, they do not return to the center. I am attaching the videos to better understand
  15. pfm21
    374Coins
    this is my 3dof with traction loss. help me fof my problem. thanks
  16. pfm21
    374Coins
    when I press hard on the engine he disconnects and doesn't return to the position anyways. I see the yellow line which should be the engine. come posso risolvere
    151,479Coins
    +11,041 / 56 / -2
    Are you pushing past the SMC3 boundary limits, as it will disable if you do that.
  18. pfm21
    374Coins
    but you say it's normal? i also tried without opening smc3 and it does the same thing. I'm afraid what happens when I put on the seat and sit on it.
  19. pfm21
    374Coins
    nothing to do I tried with the seat on and as soon as the weight of the body shifts and I risk falling and the kotori do not manage to rest in the center position. maybe the distance of the motors from the center is wrong and they don't make it?
    151,479Coins
    +11,041 / 56 / -2
    I suspect part of the issue is that you look to have a compact design with limited design leverage, which requires lots of torque, but are using what looks to be very long CTC levers.
    What is the gear ratio?
