DIY Pendular Rudder Pedals
Discussion in 'DIY peripherals' started by Historiker, Mar 4, 2019.
  1. sinuos
    sinuos New Member
    73Coins
    Can you share the pedals stl files??Look very nice
  2. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    Here are some of them. I had to manipulate many of the files to work with my Simply 3D program.
    I am not sure what may be missing or some files are extra but let me know if you have any questions.
  3. roggan
    roggan New Member
    Gothenburg, Sweden
    562Coins
    First off all realy nice project by Historiker this is more like a real pedal setup!
    I am building my own simpit for flying, I have licens and fly Diamond HK-36 Super Dimona but I wan't to fly home also.
    T R Para how did you do the right pedal? I can't figure out how to mirror it.
  4. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    I use the slicer Simplify3D. It has a mirror function called "mirror mesh".
    **I exported this out as a binary and an ascii file.
    Hopefully this will work..
    I think I can PM the file if you are low on coins. :thumbs
  5. Historiker
    9,208Coins
    He has plenty of coins ;)
  6. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    You da Man !
  7. roggan
    roggan New Member
    Gothenburg, Sweden
    562Coins
    Tanks Historiker generous of you!
    Simplify3D is new to me I normaly use Cura to slice.
    I am lerning Fusion 360 but i did get Solidworks from my job but it is little hard :) but fun.
    What sim are you using?
    Excuse my bad spelling;-)
  8. erocfx
    erocfx New Member
    87Coins
    This is a great project! I think I might try to build a set. I think I have all the info from this thread. Is there a BOM for all the mechanical parts?
  9. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    I do not have a BOM.. A majority of the metal materials are listed on page 2 and 3. The levers are cut from a single piece of 12"x 24" x .125" aluminum plate. The Base plate is made from 10" x 10" x .25" aluminum plate. The frame is made from 2020 T Slot Aluminum Extrusion. A list of some of the bearings are...
    4 total 12mm x 28mm x 8mm Bearings for pedals
    2 total 12mm x 32mm x 10mm bearing upper L arm
    2 total 8mm x 22mm x 7 mm Skate Board bearings .
    As Historiker mentioned to me it is not a step by step construction thread but there is enough information here to build the project. And we are both here to help answer any questions. I would start by cutting the levers out of .125" or 3mm aluminum,start printing the necessary plastic parts and you should start seeing exactly how the build goes..
    Hope this helps..:)
  10. Historiker
    9,208Coins
    What he said :)
  11. erocfx
    erocfx New Member
    87Coins
    Yes, that's a big help. I am going to start printing and cutting. Thanks for the help!
  12. erocfx
    erocfx New Member
    87Coins
    What size are the bolts for the pedals and the L levers?
  13. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    Pedal bolts are approximately 150mm long and are 12mm bolts. I used nuts that have the nylon shakeproof ends...
    on the L levers I used 12mm threaded rod with again shake proof nuts on each side. The rod looks to be 94mm long. Cut to length with a dremel cutoff wheel. I most likely did not have the proper length of bolt.
  14. erocfx
    erocfx New Member
    87Coins
    What are the 8mm x 22mm x 7 mm Skate Board bearings for?
  15. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    They fit in the pendulum plastic mounting housing on the back of the main assembly
  16. erocfx
    erocfx New Member
    87Coins
    How does the bolt or rod that holds the spring on attach?[​IMG]
  17. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    There is a hole in the end of the rack.. Tap it for 1/4 - 20 threaded rod. Two jam nuts adjust for spring tension ..the 1/4-20 rod is about 3.75" long.. But cut to suit.... The spring is a compression type. I got them at a hardware store.
  18. erocfx
    erocfx New Member
    87Coins
    Is there a wiring diagram? How do the hall effect sensors hook up to the arduino?
  19. T R Para
    Cincinnati, Oh
    2,443Coins
    AC motor, 6DOF
    Do you have a sketch for the arduino? I cannot remember which one I used (maybe this one) .. The A(0), A(1) A(2) etc. are the analog inputs. You will need a Leonardo or Pro micro board as these have the proper USB connection needed..
  20. erocfx
    erocfx New Member
    87Coins
