value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Give @yobuddy and @value1 some time, both lead busy lives.
    Did you try the proxy server?
  2. Smollett
    Smollett New Member
    Russia
    86Coins
    no. Now I am going to the championship on the community server.
  3. Ciaoarturo
    Ciaoarturo New Member
    36Coins
    Hi all. Newbie question. I have PT Actuator and things seem to test fine and the axis all respond as they should. However, when using RF2 and plug in, the movements seem off. When I hit the brake, the rig rolls to the right. But, the actuators are in the right spot and connected to the right AMC servo slots. I assume I'm doing something wrong. Ideas?
    153,986Coins
    +11,162 / 57 / -2
  5. Ciaoarturo
    36Coins
    Thanks for the assist but I managed to figure it out by trial and error. I noticed the axis assignment default assumed 3 actuators and I have 4. It had everything going a bit nuts.
    All sorted now. Cheers!
  6. lysa elec
    lysa elec LYSA ELEC
    16Coins
    I have no effects with rfactor 2 (stream) the game is recognized at startup but after no effects
    153,986Coins
    +11,162 / 57 / -2
  8. lysa elec
    lysa elec LYSA ELEC
    16Coins
    153,986Coins
    +11,162 / 57 / -2
  10. lysa elec
    lysa elec LYSA ELEC
    16Coins
    its good i desintalled and intalled the plug in the new directory
  11. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Hi everyone! I've tried to patch the game but "Game did not patch?". I run the Game Manager as administrator, but it didn't effect.
    153,986Coins
    +11,162 / 57 / -2
    You should not need to run GM as admin.
    Did you get a specific message and if so can you post a picture of, along with the patch path.
  13. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Path is ... D:\Games\Steam\SteamApps\common\rFactor 2
    153,986Coins
    +11,162 / 57 / -2
  15. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    Result is the same((
  16. boobabebe
    boobabebe New Member Gold Contributor
    46Coins
    Good morning all,
    I have a problem patching rfactor 2, it asks me to select a folder, but its not done on my other games. So I'm not used to it.
    See the captures below.
    Thank you for your comeback.
    153,986Coins
    +11,162 / 57 / -2
    For some games SimTools needs to know where a game is installed.
    Are you using Steam? If so the default install directory for game installs should be C:\Program Files (x86)\Steam\steamapps\common\ In SimTools find the RF2 folder in there.
    If you are not using Steam the file path is wherever RF2 is installed.
  18. Viktor_s
    Viktor_s New Member
    Russian Federation
    - 32Coins
    I've reinstalled the game to my SSD. As well the game has been installed to my laptop.
    The game doesn't patch.
    Maybe someone can test the actual game to patch?
  19. boobabebe
    46Coins
    I am trying your solution and the game does not want to patch. see the pictures
    Also in my rfactor 2 game folder, I don't see a simtools folder.
    Thank you for your help
    153,986Coins
    +11,162 / 57 / -2
