Hexapod racing sim
Discussion in 'Commercial Simulators and Peripherie' started by Petertje, May 11, 2020.
  1. hannibal
    hannibal Active Member
    4,490Coins
    just do it.
    the amount of work and time for DIY is going to be like buying Thanos..
  2. Petertje
    Petertje “Engineering changes the world.” —Isaac Asimov
    Mechanical engineer / battery specialist
    The Netherlands
    447Coins
    Yeah, Its stable, works right out of the box and I like the industrial VFD drives with servo motors since they are bulletproof and powerful. I made some calculations and DC is not even that much cheaper when you consider the power supplies.
  3. BDZ
    BDZ New Member
    166Coins
    any updates on this absolute beast?
  4. Petertje
    The Netherlands
    447Coins
    ah yes, so busy I forgot to keep you all in the loop, sorry for that!
    • We finished the frame with adjustable footrest "ferrary style".
    • Made a control box to contain the VFD drives and thanos. (for those who are paying attention: VFD drives will be mounted with the cooling fins up so picture is wrong)
    • Made a button box for park, on/offline and emergency switch
    • Put the whole thing on a checkered flag floor
    • Finished screen mounts and control interfaces
    Sending it out now to the powercoat factory, in a couple of weeks it should be finished!
    thumbnail_IMG_3256.jpg thumbnail_85852946-30A2-42C3-BDED-276E0A1E9767.jpg IMG_3421.jpg IMG_3420.jpg
    • Like Like x 8
  5. plotto
    plotto New Member
    - 14Coins
    This is a great build. Planning on something similar.
    Are you able to share drawings for your actuators?
  6. Petertje
    The Netherlands
    447Coins
    I will, first will update them to implement lessons learned.
  7. Petertje
    The Netherlands
    447Coins
    Finally all the stuff back from the powdercoat company, doing some subassemblies first and will hopefully have it all working this weekend!
    • Winner Winner x 3
  8. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
    Fantastic job!!!! I like !!! :thumbs
  9. Will974
    Reunion Island
    953Coins
    I have a question on one detail of the conception of your linear actuator. I can observe that you don't use slide rode to fix the piston rotation due to the fact that you use u-joint at the bottom and the top of the actuator. So, the piston can rotate if needed . However, i don't understand why the lower part of the piston next to the nut is not guided ? Is there no risk of vibration at high speed ? Wouldn't the guide also improve the positioning of the piston?
  10. Petertje
    The Netherlands
    447Coins
    Indeed I dont need to lock against rotation: the u-joints lock the position. Ans since no switches or string pots are used the position doesnt matter/
    When using linear bearings the play is minimal. The piston (rod) is thick walled hardened steel. Not much movement there. There is no noticeable vibration.
    Furthermore, when the rod is extended, that bearing wouldnt be in contact anymore anyway.
  11. Will974
    Reunion Island
    953Coins
    "Furthermore, when the rod is extended, that bearing wouldnt be in contact anymore anyway."
    What do you mean ?
    Usually, the piston is guide on two points :
    1-At the upper part of the actuator (Linear bearing or self-lubricated ring )
    2-The lower part of the piston ( Not exist for you ) --> and that's what caught my curiosity... :)
    But saw your video, it seems to work very well, with this particular conception :thumbs
  12. Petertje
    The Netherlands
    447Coins
    i'm not sure what you mean. Can you post a sketch of how its should be according to you?
  13. Will974
    Reunion Island
    953Coins
    Look at photos attached. The piston is guided only at one place. Usually the piston is guided in two places at the same time unlike the fact that rotation is fixed by the two u-joint but not you. Can you explain me your decision to choose to not guide the piston at this place please ? Are you sure that there won't be problem when the rig will be loading ?
  14. Petertje
    The Netherlands
    447Coins
    Ah I see what you mean. I'm using a long linear ball guiding on a hardened axle with very little play. Works perfectly: no sideways movement and/or vibration is present.
  15. Petertje
    The Netherlands
    447Coins
    Put it all together, quite happy with the result!
    xs14.jpg xs13.jpg xs12.jpg xs11.jpg xs10.jpg xs9.jpg xs8.jpg xs7.jpg xs6.jpg xs5.jpg xs4.jpg xs3.jpg xs2.jpg xs1.jpg
    • Winner Winner x 7
  16. Dschadu
    Dschadu Active Member
    1,935Coins
    A super clean build, wow! Looks absolutely amazing.
  17. Will974
    Reunion Island
    953Coins
    Wahou ! The result is awesome !!! Congratulation hug:
    Now we wait for a video of your rig in action !!! :)
  18. Will974
    Reunion Island
    953Coins
    Do you build yourself the stand for the triple screen ?
  19. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,748Coins
  20. Thanos
    Electronics Engineer
    2,798Coins
    This is 007 in the "serial-production"... lol
    What are you talking about? o_O
