Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. Metaverum
    Metaverum Member Gold Contributor
    146Coins
    2DOF, 3DOF
    I would like to ask for some clarification on some general things related to building motion platforms. I wasn't sure where to ask but I will be building a miniature 2DOF simulator for my first project, so I guess this will work.
    I have some questions related to the mechanical construction of motion platforms, mainly connecting various components together.
    I will post three 2DOF motion platforms, where each have a varying motor position and rod connection. All these platforms are from the talented people of this community.
    As you can see in all 3 images, I am puzzled as to how the motor position is chosen in motion platforms. You can see that image 1 has the motors positioned a little forward with the U-joint behind, image 2 has the motors positioned all the way back, and image 3 has them positioned quite far away and the rods don't even connect vertically. However, these are all working systems. How do you decide on this?
    For one, I am assuming the u-joint has to be right below the center of gravity, or at least below the player? And further on, how do you decide on how to connect the rods, so that they will be able to rotate the platform to every possible extent (as required by the simulation). How do you also choose what type of rods to use to make sure that they do not break under pressure and use?
    I am foreign to all these concepts and this is my first ever question to this community. I hope to be able to build many cool simulators with the help and support of all of you. Can't wait to share my own work!
    Thanks. :)
      106.5 KB
      1,152
      332.5 KB
      1,089
      565.7 KB
      1,207
    153,710Coins
    All simulators are a compromise of some sort, and many design and other considerations come into play, from aesthetics and cost to parts availability and physics.
    Th U-Joint should be placed as close to the seat as possible and the rig should be balanced with you and all peripherals attached: https://www.xsimulator.net/community/faq/universal-joint-placement.108/
    If using wormdrive boxes a very slight positive weight balance bias preloading the gearboxes helps minimise the inherent backlash: https://www.xsimulator.net/community/faq/wormdrive-backlash.293/
    SimCal lets you play with some of the possible design Vs physics trade offs that are inherent in any rig: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    There are also other design/experiential considerations, such as seat shaker Vs full frames: https://www.xsimulator.net/community/faq/full-frame-vs-seat-shaker-designs-which-is-better.213/
    The designs you have posted are commonly referred to as a full frame knee design, a compact (rear motor) seat shaker design, and a shoulder mount seat shaker design. All have their pros and cons.
  3. Metaverum
    146Coins
    2DOF, 3DOF
    Thank you for the links, very informative! I'm looking forward to trying out SimCal, as my main project is quite a complex design. I wanted to build a miniature 2DOF initially just to get started. So, regarding the bolting position of the rods, the u-joint FAQ page says the following:
    "You also need to balance the rig to determine where it bolts to the seat base".
    I understand that this is doable for miniature designs, or perhaps even actual one-person simulator designs, but let's say a larger design like the following, how can you figure out the center of gravity?? I believe this is a couple of hundred kilograms and not something you can easily figure out with a round pipe.
    153,710Coins
    Where are design is such that the load may vary it has to be powerful enough to compensate for all possible variables in load and distribution.
  5. Metaverum
    146Coins
    2DOF, 3DOF
    Is it safe to assume simply the geometrical center as center of gravity and then install powerful motors to keep the structure from breaking under load?
  6. Marksman
    Marksman New Member
    - 19Coins
    Motor.jpg Hey there;
    I´m actually thinking about the best way to connect the shaft with the "lever" to move our upper element.
    Do you have any hints for shaft-to-collar connection ? So far its planned like you can see in the pictures. The only missing part is the connection between motor and the rest.
    We also have an own thread, go visit us there if u want to stay updated! cya
    Motor 2.jpg 59684
    thanks for your help guys
    153,710Coins
  8. coolfish206
    coolfish206 New Member
    39Coins
  9. 427Cobra
    427Cobra There is no substitute for cubic inches
    Sweden
    557Coins
    Thanks for sharing your project, very useful information, and I'm impressed about the craftsmanship.
    What u-joint are you using, from a car driveshaft or steering column? The size looks perfect.
  10. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    I used a toyota 4x4 rear driveline
  11. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
  12. 427Cobra
    Sweden
    557Coins
  13. ghidossi
    ghidossi Member
    - 12Coins
    3DOF, Arduino
    hi, do you choose a 2dof cause it's enough for what you do or cause make a 3 or 4 dof is very complicate ?
  14. Zef
    Zef New Member
    Electrical Engineer
    Gothenburg, Sweden
    149Coins
    2DOF, DC motor
    Very nice and inspiring project! How did you solve cooling fins for your JRK?
  15. Dominik Mičuta
    Dominik Mičuta New Member
    Slovakia
    80Coins
    3DOF, Motion platform
    What was the price of the project?
  16. Deleted member 37105
    Congratulations on your editing, it's really beautiful. Is the engine temperature high during a game? Do you know the life of your motors? (number of hours played before changing them)
  17. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    How is the rotating part you made fixed with the shaft of the motor?
    What machinery, equipment or tools need to be used to achieve it? Can it be done by hand?
  18. wp8051
    China
    224Coins
    Also, is the output shaft of your motor unilateral or bilateral?
    How is the connection between the potentiometer and the motor shaft? I saw the coupling, but I don't know how the coupling is fixed to the motor shaft.
  19. Erwan960
    3,832Coins
    It's a keyed shaft.
    These parts were laser cut.
    not reversible thanks to the 50: 1 or 60: 1 reduction gear
    I drilled in the center of the output shaft and I fixed a threaded rod inside, 6mm in diameter, on which I put the flexible coupling.
  20. wp8051
    China
    224Coins
    Hello, thank you very much for your reply.
    I'm in China now, and I found a similar reducer shaft on the shopping website here.
    This shaft contains gaskets, circlips, and flat keys.
    If I process the rotating part according to the drawings you provided, and then buy a shaft of a reducer with a suitable size, can they be installed together?
    There are pictures of the kind of shaft I found in the attachment. There are many different models. Fortunately, there are threaded holes on the end of the shaft.
      150.2 KB
      573
      73.8 KB
      595
      63.4 KB
      568
      233.1 KB
      586
