[in progress] 6DOF compact and small footprint
Discussion in 'DIY Motion Simulator Projects' started by Rens, Sep 5, 2020.
  1. Rens
    Rens Member
    517Coins
    You are right about that, but because of it I will probably use smaller levers too. I received quote from sunrise motors $100 each, with shipping to netherlands total of $255 for shipping. Gearbox and shaft are included.
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    Nice to start with.
    If you got the feefer you allways can go better!
    Mag ik vragen waar je woont.
    Ad Den Bosch
  3. Thanos
    Electronics Engineer
    2,854Coins
    Funny, because I can run six of these 750watt servos on single phase 110v 15A fuse without any problems. You see these servomotors are really efficient and the 750watt rating is the max peak draw at 300% of its torque rating...
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    I didnt know that.
    I had in mine mind 2.4NM at 3000 rpm rated power
  5. Thanos
    2,854Coins
    Yes, the 2.4Nm torque is at 100% torque on these servomotors, they can deliver up to 7.2Nm on peak torque (300%). And they can deliver same torque depending on the load, across any RPM speed they are commanded to have. From 0RPM up to 3000RPM.
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,784Coins
    Do they have soft current limiting?
  7. Thanos
    2,854Coins
    Yes, you can limit max RPM and Max torque levels if you want to ensure it won't go over a specified power rating.
  8. Rens
    Rens Member
    517Coins
    @adgun Gelderland (ten oost van Arnhem vlakbij de Duitse grens).
    I am now shopping for potentiometer and motor driver. The motor draws 24v at 220w. I read about the benefits of an Hall effect sensor and am considering it over the regular potentiometer method. However from the wikipedia page I do not understand what they mean with:
    "Hall effect sensors provide much lower measuring accuracy than fluxgate magnetometers or magnetoresistance-based sensors. Moreover, Hall effect sensors drift significantly, requiring compensation."
    Perhaps one of you more experienced guys know what this means? @noorbeast, @Thanos, @T R Para, @accelero, @adgun, @Gadget999
    When I google for "Hall effect sensors" there isn't any good sites nearby that sell these, only found two really and they both sell the exact same one for decent price. It also appeared to me that 180 degree vs 360 degree price didn't matter so I guess I can go for the 360 continuous, might become useful for other projects too.
    The Hall effect sensors I am considering:
    https://www.digikey.com/product-detail/en/tt-electronics-bi/6127V1A360L-5FS/987-1393-ND/2620662
    The motor drivers I am considering are:
    1) Cytron 10A 5-30 V Dual Channel DC Motor Driver - https://www.robotshop.com/nl/nl/cytron-10a-5-30-v-dual-channel-dc-motor-driver.html
    30A peak (10 sec)
    2) 50A Dual-Channel H Bridge Motor Driver Module Robot Chassis Servo Geekcreit - https://banggood.app.link/2qVY6NLoC9
    I am leaning towards the Cytron, because of the many good reviews on it. However I will probably need to attach an heatsink on top of it no? If so, how do I go about this, do you use special glue (thermal paste) and just glue it on top?
    EDIT: To answer my own question, I read this from the Cytron manual: "Fully NMOS H-Bridge for better efficiency and no heat sink is required." so that's great :)
    I currently own an Arduino Uno, which according to @Thanos can only output 8-bit on the PWM pins. Did some research on this and came across a PWM extension for Arduino which allows 12-bit:
    PCA9685 16-channel 12-bit PWM - https://banggood.app.link/hWcL7gcpC9
    This would mean I could drive all motors with just 1 Arduino and with 12-bit instead of 8-bit?
    Upon doing some more digging I came across this article which makes it possible to generate a 16-bit PWM: https://www.teachmemicro.com/generate-arduino-16-bit-pwm/ (only on pin 9 and 10 as per my understanding).
    And if you own an Arduino Due, you can call: analogWriteResolution(12); (https://www.arduino.cc/reference/en/language/functions/zero-due-mkr-family/analogwriteresolution/)
    Please note: I just did some research and have no experience with any of the above whatsoever. I only did one project with Arduino before. But I figured it might be worth sharing here. :nerd
    Regarding the connection of the sensor, I wanted to mount it on the back side of the shaft. So I requested if it's possible for them to add a 8mm diameter and 20mm length extension to the shaft, so it's easy to connect it with the use of a 6.35mm and 8mm coupler. :thumbs
  9. Mike Melga
    Mike Melga Member
    IT
    662Coins
    @Rens
    Hi.
    These are the hall sensors I am buying. They were recommended by someone here.
    https://uk.farnell.com/bi-technolog...sensor-hall-0-2v-20v-to-10v-180deg/dp/2319661
    The drivers I bought are these:
    https://www.robotshop.com/uk/cytron-13a-dc-motor-driver---grove-compatible.html
    Cytron MD13S
    These are the ones from the DOFReality kits.
    Did you request that shaft change?
    I didn't request anything...but probably should have :p
    What do you think?
    Just one question to satisfy my curiosity: you have an avatar picture of a Transtecno motor. Transtecno also makes very good motors and they are produced in Italy (I only knew this recently). Why haven't you choose their motors?
  10. Rens
    Rens Member
    517Coins
    Hi @Mike Melga , yes I have seen those, I have purchased the same one but 360 and FS (flat surface for better connection with the coupler).
    I actually already purchase those MD13S myself (after being in contact with Cytron they recommended me that one over the other). I didn't know DOFReality uses these! They also told me to use a Shunt Regulator since I am not planning on using any batteries.
    Yes I did ask them for that change, I thought it would be easier to connect the sensor through a coupler that way :)
    The avatar is indeed from a Transtecno motor, and I did look it up but couldn't really find much. That picture is from a YouTube video from someone that either had a H3 or H6 from DOFReality. I think those are the motors they used in the early days? (I don't know).
    Below you can find a list of all items that I have purchase so far:
    Motors:
    - 80ZYT165-2420-30RV25-63B14+customized shaft
    Motor driver:
    - https://www.cytron.io/p-13amp-6v-30v-dc-motor-driver
    Shunt regulator:
    - https://www.cytron.io/p-26.4v-2.8ohm-15w-shunt-regulator
    Sensor:
    - https://www.digikey.com/product-detail/en/tt-electronics-bi/6127V1A360L-5FS/987-1393-ND/2620662
    Couplers:
    - https://www.123-3d.nl/123-3D-Flexibele-motor-koppeling-6-35-mm-8-mm-i2471-t3045.html
    Cabling:
    - https://droneshop.nl/krimpkous-assortiment-kit-150-stuks
    - https://droneshop.nl/10-awg-siliconen-kabel
    I purchase 10 awg to 20 awg, so that I have enough cables in stock. I bought only 1 meter for all, just for testing things, after I know exactly how I am going to wire things I will probably have to purchase some more wire, and perhaps some connectors, not sure yet.
    The above are things I require to start testing with code and such, since I am not using SMC3 or any other ready to go code, and will try to write my own. I have been researching other codes and will have to see how they did it and learn from it. I still have difficulty understanding the PID (code wise). What code are you planning on using?
  11. Rens
    Rens Member
    517Coins
    ps. I haven't decided on PSU yet... I have been in contact with 2 parties regarding this. I rather spend some good money to get a good PSU with good protection than a cheap one. Cost wise I am at 1024 EUR right now. My goal was to stay below 1500 EUR, which seems to be playing out well. Just have to build the frame out of wood and purchase levers or create them myself and some gas struts and push rods and nuts and bolts :p
  12. Mike Melga
    Mike Melga Member
    IT
    662Coins
    @Rens
    It's good to have someone building the same hardware based project. That way we can share ideas :)
    I did not know of that shunt regulator. Will I need only just one or one for each motor?
    You sensors look nice. I have read in here somewhere that the 360º sensors were tougher to configure. Don't know if that's true. Those do seem easier to fit due to the flat surface.
    The PSU's I am buying are these:
    Meanwell LRS-350-24
    https://www.meanwell.com/productPdf.aspx?i=459
    Meanwell is one of the best PSU manufactures.
    I will also be using this:
    https://www.ebay.co.uk/itm/1-channel-24v-relay-module-board-shield-for-arduino-with-optocoupleryu/392847826326?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    connected to a mushroom-type button as an emergency stop button if things begin to shake out of control :)
    As for software...I will stick to SMC3. I do not have the knowledge or skill to look further.
    You have to understand that I am building my first rig. I have zero previous knowledge of these kind of motors, software, hardware...
    I set myself a goal to build one with 2DOF and traction loss and build my own direct drive wheel.
    The last time I played with a wheel was like in 1999 when I played Sierra's Grand Prix Legends. It was a Thrustmaster wheel with a 15-pin gameport connection :)
    So...everything is new to me :D
  13. Rens
    Rens Member
    517Coins
    This is my first project to, figured I just go for 6dof instantly and see where it goes from there.
    I also have no experience in any of all of this. Just been researching a lot and learn as I go.
    I don't think it matters what sensor it is as long as it has the range that your lever needs to make.
    I think it's easier to have 360 so you have more margin, but I will configure min/max of potentiometer in my code. I already have some code in place, and have tried with a custom H-bridge, but really have to wait till my MD13S arrives along with the hall sensors so I can really start playing with the code and do testing/debugging.
    Where do you put that relay in your circuit? Is 10A relay enough? I am not an expert in electricity really...
    I thought I needed 6 relays, each for 1 motor so I can cut the power to the motor driver.
    I also want to use a single PSU for 6 motors, to keep things compact/clean. (not sure if this is possible either).
    I don't even have any wheel, pedals, shifter etc. yet. Just the VR headset really :)
    Yes I believe so, I ordered 6, 1 for each motor. You can see circuit below. The "Optional additional protection" (fuse/diode) is not required btw.
  14. Mike Melga
    Mike Melga Member
    IT
    662Coins
    @Rens
    I really don't know if 10A is enough. I again copied the function of the DOF Reality systems:
    (minute 13:45)
  15. Rens
    Rens Member
    517Coins
    Ok, I guess you will just have to try it out, if you see fire or smell something you will know ;):p
  16. Mike Melga
    Mike Melga Member
    IT
    662Coins
  17. Rens
    Rens Member
    517Coins
  18. Gadget999
    12,007Coins
    I use three of these motor drivers 100A and have not missed a beat !
    https://images.app.goo.gl/a8ifyw1HdsSZGXYaA
    Some arduino compatible boards have 13 bit resolution that over 8 thousand steps !
  19. Gadget999
    12,007Coins
    Iirc simtools can only output 255 steps of resolution !
    So a high resolution board may be wasted
    • Disagree Disagree x 1
  20. SeatTime
    I'm currently using a 'Output Bit Range' of 16bit from Simtools.
