Wickie´s 6DOF Sim
Discussion in 'DIY Motion Simulator Projects' started by PeterW, Aug 3, 2019.
  1. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi @Adrian Culda
    I dont know the version Number, but its this great firmware that came initially from insectatech
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi @BDZ
    Yes, I still use my original Keda 6364 motors in my sim - and I am super happy with them now.
    The other motors I had ordered for testing (a turnigy 6364, 190 kv and a 6374, 140kv arrived, but didnt test them so far.
    Wickie
  3. BDZ
    BDZ New Member
    166Coins
    good to hear looking forward to your update.
    the reason I asked if you had received is because I ordered mine back in April and I am still waiting. so frustrating I've had the actuators their ready to have the motor put in for months but this has really held me up.
  4. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    hi mates
    this is not the larger update I promised, but something I really want to share with you!! This is my new sub-project I started due to the great work of @Historiker with his rudder pedals project. I felt in love with the design of his pedals and decided to print one myself. My Prusa-printer did an extraordinary good job and now I can hold the pedals in my hand - it feels like holding the hand of a girlfriend when I was young.... soooo nice
    Wickie
    • Like Like x 11
  5. Dirty
    All the way up front.
    7,956Coins
    Nice!
    Which material did you print with?
    Also, do you have a link to the project that,.... well.... "inspired" you :D
  6. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Dirty,
    I used the original Prusa-PETG and I think its the same that you used for your universal joints. Yes - I follwed your recommendation .
    Here is the link to the pedal-thread that inspired me for my new sub-project: https://www.xsimulator.net/community/threads/diy-pendular-rudder-pedals.13130/
    But mechanically I will make it little different and with force feedback.
    Wickie
  7. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi all!
    Long time passed since the last update....
    I was buisy with renewing my floor and painting my home.....lot, lot of work!
    So time to share some modifications of my sim, I made some months ago.
    This was adding a car dashboard (?) and seat belts.
    The dashboard is made of 6mm plywood.
    The 5 parts are toothed and glued together to improve stability.
    The cover is made of a thin layer fleece (I think it was 5mm) and synthetic lather as top cover. The haptic is like in a luxury- car :).
    The seat belts are from OMP. I love the quality and can highly reccomend them.
    Wickie
    • Winner Winner x 5
  8. SilentChill
    20,594Coins
    Man, your rig is soo sexy :D
  9. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi mates!
    Just a small teaser about my nearly finished rudder pedal and flight equipment project I made the last weeks...... :grin
    I hope I will find some time for a detailed documenation about this in the comming christmas holidays.....
    Wickie
  10. Dirty
    7,956Coins
    Nice! Is that powder coating?
  11. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Dirty,
    yes it is powder coating. Since this summer I have access to a makerspace nearby Munich (www.maker-space.de).
    Yes....makers dreams came true.. :). They have all the machines you would need to build everything. From water-jet-cutting to powder coating, WIG- welding, lathe, CNC-milling, all kind of wood-working, electronic making and measure stuff, sewing, and so on......
    BUT! Its not cheap to make the trainings to get access to the sometimes complex machines. I am in the lucky situation that I need this also for my job and dont have to pay for this.
    Wickie
  12. Narkki
    Narkki New Member
    - 7Coins
    Nice looking platform @PeterW .
    I have a question about actuator rotation in yaw, how do you compensate for the difference in real rotation and the reading of encoder?
  13. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi
    I am not 100% sure that I understand you correctly.
    Do you mean, that the piston rod is not fixed in rotation? If yes, this is not a problem at all. Its not noticeable and has not to be compensated :)
    Wickie
  14. Narkki
    Narkki New Member
    - 7Coins
    Yes I ment that, in spesific I mean that full rotation of motor is not always same as full linear movement that one full rotation should make, when the piston is rotating because of the fixed joints in lower and upper end of actuator.
  15. twinking
    twinking New Member
    71Coins
    Hi Peter,
    I really love your clean actuator design. But there are things i don't understand.
    1. What kind of "anti wobble" solution are you using? Is there just a bearing at the end of your ballscrew? Or is it a peace of plastic?
    2. What kind of guide do you use in the tube (between the piece holding the ballbearing nut and the tube) and what kind of guide to you use between the pushrod and the endpiece of your actuator?
    Would like to here from you. By the way, is there a reason your cad model isn't online anymore?
    Greetings
    Fabian
  16. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi Fabian!
    My upper ballscrew guide is made from plastic (POM). Its solid and with only little tolerance to the aluminium pipe. Also all the other parts you asked for are made from POM and run directly on the raw aluminium with little grease.
    Last weekend I dismanteled one actuator to check for wear, but inside everything looked like new - after lot of runtime.
    Regarding my CAD- files. I am helping everybody with specific questions, but decided not to make my whole work public. Hope you will understand this.
    Wickie
  17. twinking
    twinking New Member
    71Coins
    Thank you for your reply. Regarding the CAD files i was just curious. I am also building linear actuators at the moment using aluminum square tubes and POM. It's the first time im working with POM and I start to realy love it! I was not sure if POM will last for a long time in use, but i'm glad to here you made the experience it does :).
  18. Dirty
    7,956Coins
    Hey :)
    are you printing POM or are you milling it from a solid block?
  19. twinking
    twinking New Member
    71Coins
    Hey, I'm milling it with my selfmade CNC :). Didn't even know it is possible to print it.
  20. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi all!
    Again after long time of silence I want to show you some of my insights regarding noise reduction.
    During my upgrade from 1605 ballscrews to 1610 ballscrews, I tryed and implemented some noise reduction measures at the piston-rod:
    a) I added two stripes of 2mm thin vibration damping mat to the inside of my piston-rod. I found the two stripes are enough and more doesnt perform much better.
    It is important to have a clean surface for good adhesion!
    b) I added two noise foam pieces between my inner and outer piston-rod.
    Assebly is a littl tricky, but worth the work.
    So finally I had the following improvements:
    Left piston-rod => no measures
    Middle piston-rod => measure a)
    Right piston-rod => measure a) and b
    (edit: I dont know why there is a delay between video and sound! - This is the original file from my mobile-phone)
    Wickie
    • Like Like x 5
