knaufinator
BeamNG.drive plugin 2.0.3.0
Simtools game plugin for BeamNG.drive
  1. knaufinator
    knaufinator Active Member
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    This is the source of your issue, it needs to maintain the file name, its referenced in a hardcoded way within beamNG , I dont know what you copied over, but you should prolly revert that file back... then we need to figure out why you dont have motionsim.lua
    motionsim.lua defines what data is sent over UDP
    both my laptop and desktop install of beamng has that file.
    do you have an old version?... did you disable updates? find me the version of your BeamNG install actually lets make this a known.
  2. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    3DOF, Motion platform
    I use it with the most updated version of steam, before i tried today he had to update beamng:).
    I put the file main.lua back, but still no tractionloss.
    I could't find the C:\Program Files (x86)\Steam\steamapps\common\BeamNG.drive\lua\vehicle motionsim.lua on C:
    For me it's E:\Steam\steamapps\common\BeamNG.drive\lua\vehicle main.lua I think.
    I go try sunday if i can find it somewhere els on my system.
    Thans so far.
  3. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    I'm pretty confident that this is the source of the issue still, we need to figure out why we have different files.... I will look later today to see what that file is u are referring to.
  4. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    Main.lua is not the same file/ concept, it does appear to seed the motionSim.lua as it even references it in mine... could you email me your main.lua,.. it appears that Main.lua is what updates motionsim.lua,.. so if I can see your main.lua,.. we can see if it is also trying to seed it,.. or something else... - PM me: https://www.xsimulator.net/community/faq/private-messaging.85/
  5. De Baas
    De Baas New Member
    Alkmaar
    302Coins
    So i did find the file motionsim.lua. I replaced both of youre files and i can confirm this is a fix for the tractioloss! Works perfectly. Thanks for youre effort.
  6. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    Hazaa! I will work then to package this in a release... I will need a few beta testers ideally...
  7. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    fyi. my back now hurts....this is a violent game,,,,
    153,728Coins
    Self inflicted ;)
  9. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    knaufinator updated BeamNG.drive plugin with a new update entry:
    BeamNG.Drive Simtools Plugin update - Traction loss, Roll Rate, Pitch Rate added
    Read the rest of this update entry...
  10. ART FLY
    ART FLY Gettin' High on DIY :) Gold Contributor
    Bavarian State Theater, Decoration Stock Manager
    BAVARiA
    421Coins
    Sounds great.
    Thanx for the work and time you put into this!
    Already to try it,
    Greetings from BAVARiA
    Yours
    ART FLY
  11. shaman
    shaman 2dof sim Gold Contributor
    Moscow
    - 984Coins
    Hi
    BeamNG.drive does not work plugin
    unhandled exception has occurred in your application
    what's the problem?
    thanks
      94.5 KB
      448
  12. knaufinator
    Simulation Engineer
    akron,ohio
    1,925Coins
    AC motor, 6DOF
    not sure, that is not an error I have seen before in context to this plugin.
    More information is needed in order to continue. hit the details button and copy the entire text details of what it is having an issue with. This may assist in leading to the correct culprit...
    The plugin modifies 1 BeamNG text/script file, and that modification should not cause this issue. (that I am aware of...)
  13. John yang
    John yang New Member
    37Coins
    Hi guys,
    My plugin could not work correctly.The beamng output data cannot be read properly.When I enter the game,my seat just shakes. Not working properly.Thanks in advance.
    153,728Coins
    Please post pictures of all of your settings, including the Tuning Center while the game is running, as more context is needed for members to be able to offer advice.
  15. John yang
    37Coins
    Here are some of my settings.Can you spot any problems with those?
  16. noorbeast
    153,728Coins
    What are your Interface Settings and does Output Testing work as expected?
    Because from your Axis Assignment it does not look like SimTools is properly configured and that needs to be successfully done before messing with any plugin.
  17. John yang
    37Coins
    It should be Interface settings?It is right?
  18. noorbeast
    153,728Coins
    What code and hardware are you using?
    153,728Coins
    That is a configuration preset for SimTools, but what code and hardware is being used for the rig control, is it an Arduino or something else? Best to start your own build thread and detail everything, as sorting this out does not belong in a plugin thread.
  20. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    A little explaination for the rig:
    He is using my PLC hardware with 4 servo motors(a typical square 3 dof platform). The interface config is meant to send 6 dofs data seprately into the PLC(via serial RS485), and the PLC will assign the duty for each actuator.
    His platform can run Assetto Corsa perfectly so the settings are not likely be the reason for the problem.
    We also have changed the unicode lanuage to English(USA), but the shakes remains.
    PS: in most games such as Dirt Rally 2, changing the unicode lanuage could solve the ramdom shake.
    So I guess this plugin has some incompatible issues with system running in Chinese.
