budget DIY 2DOF Wiper 24V Fiat seicento Seat
Discussion in 'DIY Motion Simulator Projects' started by tadeusz, Sep 5, 2020.
  1. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Thank's Noorbest
    Why on the Sim Tools website
    is " SimTools Registration Update"?
    link :
    https://simtools.us/downloads-links/
    On my licence I have Sim Tools 2.0 inscription
    Sim Tools 2.0 work extra very linearly and perfect
    I try Sim Tools all version.
    Any other version (outside of sim tools 2.0) work as in the video link
    there is nonlinearity and vibration
    Filters in game engines are not working
    I have a licence for Sim Tools 2.0 but it do not work with DCS Plugin.
    and this licence do not work correctly with Sim Tools other versions (outside of sim tools 2.0).
    Best regards
  2. tadeusz
    tadeusz New Member
    34Coins
    Hi
    All hope is in You.
    This is very important to me as I will be using ST for flight simulators.
    I have ST2.0 (DIY) license
    ST 2.0 works linearly, I might say perfectly.
    With every other version of the ST I have problems like in the movies
    shaking non-linear work
    Sim Tools 2.0
    Sim Tools 2.5.1 and others
    Best Regards
    153,914Coins
    +11,156 / 57 / -2
  4. yobuddy
    51,538Coins
  5. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Thanks alot for your answer Yobuddy
    The oldest version I used was sim Tools 2.0
    Sim Tools 2.5.1 is not linery- a lot of shake
    especially Amount of axis to use in -100% to 1
    in 1 to 100% is OK
    I move the slider slowly and the motor shake
    The same effect is for both engines
    This symptom is not present in ST 2.0
    Look in 4 film "Sim Tools 2.5.1."
    I cannot understand why the difference between ST 2.0 and ST 2.5.1.?
    Also, most filters do not work in ST2.5.1
    Could it be related to my DIY license?
    Best regards
    153,914Coins
    +11,156 / 57 / -2
    It is not related to your license.
    When switching between versions you could try a clean install, either via the SimTools installer or manually by uninstalling SimTools then manually deleting any SimTools folders in AppData, then reinstall v2.5.1
  7. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Yes I did lik you sugest.
    The only thing left of the old version is the license
    I uninstalled version 2.0
    and deleted all files in the folder
    C: \ Users \ User \ AppData \ Local \ SimTools
    best regards
    153,914Coins
    +11,156 / 57 / -2
    Did that resolve the issue?
    If not then @yobuddy will need to investigate a bit further.
  9. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Thanks to for Yobuddy and Noorbeast :thumbs:thumbs
    For helping me solve my problem hug:
    Yobuddy -you are the best
    All problems are gone after change in system local.
    It is very important !!!
    Again thank you very much
    best regards
  10. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Can you link? Or what turn of the potentiometer you have
  11. tadeusz
    tadeusz New Member
    34Coins
    hi
    potenciometer turn about 150 degrees
    max 180
