Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. THOMAZ AMARAL
    THOMAZ AMARAL thom
    ADM
    BRAZIL
    123Coins
    Please sir, I Have A Question! If The Engines You Used Are 24 V, How Can You Use A 12 V Power? Does Not Influence The Power Or Speed Of Engines? I Am Setting Up The Same Project! With 24v Motors, But I Found That The Monster Moto Only Accepts 16v! Would You Help Me?
  2. RacingMat
    21,082Coins
    Indeed, half voltage will induce half top speed.
    The strength (torque) depends on intensity that your power supply unit can supply. Please share your motor specifications. :)
  3. THOMAZ AMARAL
    THOMAZ AMARAL thom
    ADM
    BRAZIL
    123Coins
    obrigado por responder! Estou usando motores bosch de 24 V como a imagem em anexo! Eu tenho um 24v com 20 ampères, mas comprarei um 12v com 30 ampères, porque já perdi 4 ibt2 bridge! agora eu já comprei monster moto , eu acredito que ele funcionará com a fonte de 12v 30 amp! mas acho que vai ficar um pouco fraco! Estou acompanhando o projeto tutorial!
    153,914Coins
    +11,156 / 57 / -2
  5. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,100Coins
    Hi can U share your smc3 utility tool settings for wiper motor?
  6. RacingMat
    21,082Coins
    This topic isn't about smc3
    as the arduino code has no PID to setup, it's straightforward
    no need of smc3 ;)
  7. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    Great project. One issue im having is locating the .ino sketch i followed the link to xsim and i dont find it there either . Please assist
    153,914Coins
    +11,156 / 57 / -2
  9. RacingMat
    21,082Coins
  10. RacingMat
    21,082Coins
    I would bet that you haven't setup a default profile @UserBas
    The Simtools documentation states that it's mandatory to have a Default profile configured in Axis Assignments
    if not Output Testing will not work...
    This is how SimTools expects axis to be configured: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  11. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
  12. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
  13. UserBas
    UserBas New Member
    Apprentice Engineer
    Châteauroux, FRANCE
    62Coins
    Thanks you @RacingMat for your response,
    I can assure you that I created a Default profile before configure the LFS one. I just saw that, in the picture I sent you, this is LFS but my Default is the almost the same one ;).
    I tried to uninstall the 2.5.1 Version to try with the 2.4 and something changes. In fact, when I move the Roll cursor in "Axis Testing/DOF Output", the Axis1a follow a bit this movement, but only on SIMTOOLS. My motors are not moving at all.
    Furthermore, now in game, there is no movements in "Virtual Axis" anymore (I received those informations in the version 2.5.1). But I think this is the next step, isn't it ?
    I'm a bit lost right now, I probably missed something important...
    I created some codes to test my motors and they are working pretty nicely.
  14. RacingMat
    21,082Coins
    this one: https://www.xsimulator.net/communit...-and-2-pins-direction-hbridge-motomonster.67/
    and @UserBas : did you follow all the steps before "trying with a game step" described in this post?
    in particular:
  15. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
  16. RacingMat
    21,082Coins
  17. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    I have read through it but I just got even more confused. But maybe I was exhausted. I'll try again later today
  18. UserBas
    UserBas New Member
    Apprentice Engineer
    Châteauroux, FRANCE
    62Coins
    @RacingMat,
    That's a bit weird... I tried this manually so many times without success, but this time, it works :confused:.
    I tried various parameters and those results came up :
    . R5EL5E : 5E (Hexa) = 94 (Dec) = 379 (Potentiometer's Value (P's V)), with Tol = 20 the range (nonfunctional) must be [379 - 399] (Am I right ?)
    The issue : The nonfunctional range is [0 - 450]. I noted a little impulsion around 395 (P's V), it looks like the changement of the rotation direction.
    . R7FL7F : Functional
    . R9EL9E : 9E = 158 = 637
    Normally the nonfunctional range is : [617 - 657]
    My test : [570 - 605]
    And more...
    That can be an issue concerning the code ? :think(It affect both motors)
    I tried the "Output Testing" one more time and my engines started immediately. They are not working as I thought. When every parameters are 0, they are working (Is that a configuration problem ?). When I move Roll and Pitch in negative position, they are working very weirdly. In fact, sometimes they start by themselves and change their rotation direction...
    I continue trying to configure and I'm less desperate than before thanks to your advice.
  19. RacingMat
    21,082Coins
    1/ Have you followed the steps in the post previously indicated? at what step are you currently?
    with pot not coupled
    with pot coupled
    with serial monitor
    with a game...
    2/ Sorry, it's not specific enough to give you help:
    "When every parameters are 0, they are working" does that mean there are turning without stopping, etc...
    It's too vague
    Shoot a video! https://streamable.com/ allow you to post video without any registration
    3/ A really great number of people is using it and for a long time, so it's certainly not... sorry
    It always end with wiring configuration, computer port setup, Simtools serial setup... things like this. :)
    Keep up! you'll succeed
  20. Abram Manoge
    Abram Manoge Member
    Web developer
    South Africa
    319Coins
    How much weight can these wiper motors handle. im sorry im not very good with electrical stuff?
    Also do you know what car they are from?
