Icy7CE
  1. noorbeast
    153,830Coins
    +11,151 / 57 / -2
  2. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
  3. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    Hi all
    is there a key to this ?
    I can’t find “roll rate “ or pitch rate “
    Are these the extras ? If so which is which ?
    Motion data: Roll, pitch, yaw, heave, sway, surge, roll rate, pitch rate, yaw rate
  4. Icy7CE
    Icy7CE Active Member
    USA
    2,896Coins
    The extra outputs are listed in order: extra 1 is roll rate, extra 2 is pitch rate, extra 3 is yaw rate.
  5. Adrianstealth
    director
    england
    160Coins
    SCN6, 4DOF
    ok brill big thanks
    just getting back use to it again after not being setup for few years , thanks for the plug-in
  6. gianlu320
    gianlu320 Member
    Crawley
    542Coins
    Hi all
    I am downloading the new fs2020 update.
    The changelog states
    Simconnect:
    exposed rotationaccelerationbody_x/y/z simvars
    May be this is helpful to the developers of this plugin?
  7. Dirty
    All the way up front.
    7,971Coins
    Can you provide a link to the change log? Which version are we talking about? I would like to take a look at it in context. I am downloading the latest update and will look at the values.
    Rotational accelerations are certainly interesting. Usefulness depends on the filtering.
  8. gianlu320
    gianlu320 Member
    Crawley
    542Coins
  9. Dirty
    7,971Coins
  10. Dirty
    7,971Coins
    They are also super handy to do pilot position offset corrections (Mover does those and I do too in my software).
  11. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,838Coins
    DC motor, 6DOF
    Do we have what we need ?
  12. Dirty
    7,971Coins
    We don't! I just checked.
    Still showing longitudinal acceleration with parking brake set. But at least it looks like the SDK is not carved in stone and they are willing to develop it. Let's hope for the next update.
  13. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,294Coins
    Have some of you saw that with this plugin active you may encounter from time to time some little pause in the game. And when you stop the plugin, theses little pauses go away?
    On my end I used the old simvars and earlier plugin (modified it of course to my taste) , and I no longer have these chop.
    Just polling you guys.
  14. margolle
    margolle Member
    104Coins
    Hi.
    I am French and I speak English very poorly.
    on MSFS2020 I downloaded the plug-in, the seat moves, it's ok.
    I would like to know what the axes correspond to for adjustment,
    I found two:
    -pitch = up / down gravity.
    -roll = right / left gravity.
    what the others correspond to (extra 1,2,3 etc.)
    can you send me a picture of your settings please.
  15. margolle
    margolle Member
    104Coins
    when I fly, head down, my seat completely to the right and then to the left.
    on another game when I am flying upside down, sitting and centered. is there a solution?
  16. noorbeast
    153,830Coins
    +11,151 / 57 / -2
  17. MarkusB
    4,215Coins
    If I understand your problem correctly, there are two solutions:
    1. Use the roll and pitch rates instead of the roll and pitch angles. The rates are provided with the Extra1,2,3 values. (I don‘t have in mind which is which, but I know it is written somewhere.)
    2. Configure „Anti roll-over“ in the Game Engine‘s Axis Assignment.
  18. margolle
    margolle Member
    104Coins
    hello
    my youtube video :https://youtu.be/9nw6QEL6_G8
    roll =brutal shake
    pitch no brutal shake
    I have the same problem with DCS.
    no problem with IL2 BOS
    thank you for your help, (make sentences easy to translate please)
    thank you.
  19. margolle
    margolle Member
    104Coins
    I deactivate all, I will test 100% extra 1
    then extra 2 one after the other
  20. margolle
    margolle Member
    104Coins
    after many test (2DOF)
    Simtools name = effect
    Pitch = earthly gravity movement (front/rear)
    Surge =earthly gravity movement (front/rear)
    Roll = earthly gravity movement (D/G) "brutal shake"
    Sway = earthly gravity movement (D/G) "NO brutal shake":thumbs
    Extra1 =centrifugal effect(D/G)
    Extra2 =centrifugal effect (front/rear)
    Extra3 =centrifugal effect (yaw D/G)
    Yaw = ????? the seat move extrem right or extrem left , i'm not understande ?????
    Heave = no effect
    how well configurat all ? how many % axis by axis ?
