  1. Krzysztof Dej
    Krzysztof Dej Active Member
    Poland
    1,110Coins
    Any suggestion about smc3 settings?
  2. Krzysztof Dej
    Poland
    1,110Coins
    Any one can share some thoughts about my diagrams what I need to improve?
  3. Pedro Felizardo
    Pedro Felizardo New Member
    18Coins
  4. Chris_Beeves
    2,085Coins
    Hey guys!
    I'm having trouble finding where in the arduino code I should set the PWM frequency for motor 1&2?
    I find it mentioned in many places, but can't figure out which one to edit. I want it at 5KHz.
    Or do you only change it through the windows utility?
    152,553Coins
    +11,087 / 56 / -2
    Fpwm in SMC3Utils - The frequency of the selected Motor PWM. Note Motors 1 and 2 are tied together and will always have the same PWM frequency: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
  6. Chris_Beeves
    2,085Coins
    Yeah, that I did get, I just didn't find anywhere in the code to write it.
    So the answer would be; "You do it in the Windows utils?"
    Just so I don't get it wrong..
    152,553Coins
    +11,087 / 56 / -2
    Correct: "You do it in the Windows utils".
    The only thing that needs to be changed in the code is the Mode, if you happen to be using hardware that requires Mode2.
  8. Martin.Berger
    Martin.Berger Member
    216Coins
    Hi @all
    I Changed my whole setup:
    Motiondynsmics Motors 25:1 Gears ibt2 Boards.
    Today i gave it a try.
    Same strange results:
    Motor 1 goes one direction. Green Line goes up and up until 255. Suddenly Motor 2 gets full speed like a turn over. Then both stopp.
    Any suggestions?
    Thanks Martin
    152,553Coins
    +11,087 / 56 / -2
  10. Martin.Berger
    216Coins
    Hi.
    I make some Fotos today.
    Yes, it is in mode2.
    Code says: #Mode2
    Is this correct?
    Do i have to change anything else?
    Thanks Martin
    152,553Coins
    +11,087 / 56 / -2
  12. Lucas Wollering
    Lucas Wollering New Member
    Student
    87Coins
    Did you manage to solve the problem? I have the same...
  13. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    hi all,
    just bench testing one motor and got the below:
    Does that look fine to you guys?
  14. Krzysztof Dej
    Poland
    1,110Coins
    For me everything it's ok
  15. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    Hi All,
    I run SimTools and SMC3Utility at same machine. It is not working.
    When I run Output Testing. Nothing happen to my motor, and SMC3 Utility blue line no change.
    Is this project still need to use 2 computer?
    I have done below.
    At the same computer i run Game Engine with below setup
  16. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    No you do not need to use 2 computers.
    Make sure you are not running SMC3 and SimTools at the same time, as that will create a port conflict.
    In SimTools you need to have the Default profile configured for Output Testing to work.
    Also make sure that your computer is set to use English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
  17. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    @noorbeast Thanks for your Fast reply
    What you mean by Default Profile?? You mean this?
    My region Settings
    I run Game Engine individually, the motor still no running.
  18. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    When started Game Engine, the Arduino Tx Rx light are off.
    152,553Coins
    +11,087 / 56 / -2
    In Axis Assignment the Default profile needs to be configured.
  20. mhchong
    mhchong EK99
    freelancer
    malaysia
    - 120Coins
    Im able to do test in SimTools 1.3, after change the interface setting and arduino file to match with SimTools1.3.
    When using SimTools2.5.1 demo version, with latest interface settings and arduino file. Im not able to connect to arduino, When click 'Turn On' button in game engine output testing, arduino Rx Tx light is still remain OFF.
    SimTools 1.3 would prompt error if port incorrect, but SimTools2.5.1 demo no.
