2Dof +Traction loss - Its Finally Starting!
Discussion in 'DIY Motion Simulator Projects' started by Ian Pace, Feb 18, 2021.
  1. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Moving along nicely :)
  2. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Looking real good.
  3. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Hit a bit of a snag over the past couple of days...
    Had a couple of faulty MMs so now i have to wait around 2 weeks for the delivery of another 5 boards (2 extra) as i cant find anything locally :( oh well!
  4. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    151,486Coins
    +11,041 / 56 / -2
    These days all MMs are clones, as they are no longer made by the OEM, so unfortunately there are a lot of quality control issues :(
  6. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Yes and it seems its gonna be a nightmare to find a good set! :(
  7. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    151,486Coins
    +11,041 / 56 / -2
  9. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    its very hard to find siutable ones that can ship to Malta at a decent price.
    So the ones i linked wont work?
    151,486Coins
    +11,041 / 56 / -2
  11. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    ahhh ok..... thanks for that!
    Will look into it further :)
  12. Stephen Robotham
    jamaica
    130Coins
    I started out with the mm, but quickly realized it wasnt worth the perceived savings with all the trouble and faulty ones you end up with and just switched to sabertooth and havent had a single issue since.
  13. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    yeah in fact, im actually thinking about it.... ill just see if these work, if not i guess that will be the next step.
  14. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    i finally have my rig moving! :)
    Just have a couple of queries with regards to simtools setup. I am setup as per below:
    Output Testing results:
    Roll +100% - Rig Tilts to left
    Pitch +100% - Rig Tilts Upwards
    Heave +100% - Rig Tilts Upwards
    Sway +100% - Rig Tilts Left
    Surge +100% - Rig Tilts Upwards
    Extra1 +100% - Rig slides Left
    I have real all ofthe documentation several times and it states that:
    " Both boxes will be either checked or unchecked for surge and pitch, while only one will be checked for sway and the opposite one will be checked for roll."
    However if i do as suggested, it seems to mess up the output testing. Should I assume that its fine as is or is there something i should look into?
    151,486Coins
    +11,041 / 56 / -2
    My guess is one of your motors is wired backwards, but it won't really matter, as long as the movement for the axis goes the right way: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
  16. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    they are all wired in the same way for sure.....
    so can you confirm that the above output testing is fine?
    151,486Coins
    +11,041 / 56 / -2
    They need to be as per the link provided, for example pitch 100% should be tilt down, so you seem to have reversed assignments.
  18. Ian Pace
    Ian Pace Member
    Gharghur - Malta
    39Coins
    Thanks its now sorted and seems to be going in the right direction (i think):)
    Roll +100% - Rig Tilts to right
    Pitch +100% - Rig Tilts downwards
    Heave +100% - Rig Tilts downwards
    Anyone of them seems off to you?
    151,486Coins
    +11,041 / 56 / -2
    That looks more like it.
  20. absyfadhel1
    absyfadhel1 Member
    bahrain
    442Coins
    output force : number (N) ... what N mean ? newtons? or what?
