NEW PROJECT!! 2 DOF Sabertooth 2x60 24v motors
Discussion in 'DIY Motion Simulator Projects' started by Manes, Mar 14, 2021.
  1. noorbeast
    152,027Coins
    +11,062 / 56 / -2
    I will be looking forward to the updates and pictures :thumbs
  2. Manes
    Manes Member
    179Coins
    Today I delete Sim Tools , SCM3 , arduino etc.... and reinstall all and apparently works good. Only one motor is a bit jitter.
    The chasis I can´t finish yet, but i will have in this days. Too much work and no time!!!
  3. Manes
    Manes Member
    179Coins
    Advances: Chasis. The fisics of the sim are regulable. Maybe the center is too high. What do you think?? IMG_20210322_195025_699.jpg IMG_20210322_194154_072.jpg IMG_20210322_195014_471.jpg
  4. Manes
    Manes Member
    179Coins
    IMG_20210323_170935_894.jpg paint!
  5. Manes
    Manes Member
    179Coins
    Advances: the motors fixed on chasis. Chasis painted.
    In a few days I Will have ready the sim.
    IMG_20210328_132416_591.jpg IMG_20210328_142443_859.jpg IMG_20210328_151504_909.jpg IMG_20210328_151523_238.jpg
  6. Manes
    Manes Member
    179Coins
  7. early_m
    early_m Active Member
    Chelmsford
    820Coins
    Where did you get the u joint from?
  8. Manes
    Manes Member
    179Coins
    It was for a friend
  9. Manes
    Manes Member
    179Coins
    First test:
    No good news. The motors have not strength. The voltage go down to 10 V when I apply weight. I think i need other power supply. When I can search a good power supply to my Sim?? IMG_20210401_131815_387.jpg IMG_20210401_131831_759.jpg IMG_20210401_131841_398.jpg
    152,027Coins
    +11,062 / 56 / -2
    You can try searching the likes of Amazon and Ebay for 24V LED PSUs.
  11. Manes
    Manes Member
    179Coins
    I am testing the sim with this power supply but I have problems to connect LFS to SimTools. Game Engime with Game Manager are cnnect, LFS is patched, I can mve the sm wwith the test outputs, but not rrn wwth LFS. Can you heelp me plase??
    152,027Coins
    +11,062 / 56 / -2
  13. Manes
    Manes Member
    179Coins
    I run the LFS before....
  14. Manes
    Manes Member
    179Coins
    The LFS is running with the sim :) where can I search a post with how install the patchs? I can´t now install patch to iracing, rfactor2.... is difficult for the languae....
    152,027Coins
    +11,062 / 56 / -2
  16. Manes
    Manes Member
    179Coins
    With LFS runs good the platform. I not have the copkit. The Rfactor or iracing not run
    152,027Coins
    +11,062 / 56 / -2
    Do you have a licensed version of SimTools and if so is SimTools registered?
    Did Rfactor and iracing patch OK, and if have you done a proper motion profile for each of them?
  18. Manes
    Manes Member
    179Coins
    Motion Sim ready. I check today with Rfactor 2 . The movements are very strong. I need test some configurations. Later I IMG_20210403_104907_176.jpg upload one video
  19. Manes
    Manes Member
    179Coins
    Tests with Rfactor2 and Dirt 2.0
    Movements todo much strong. I dont fell the brake, aceleration, gears.... Only movements left to the right
    152,027Coins
    +11,062 / 56 / -2
    Thanks for sharing your rig in action :thumbs
    Just an observation, sway seems to be reversed in the settings, as it should lean away from a corner. Set roll opposite of sway. Surge needs tweaking to be more pronounced in braking and acceleration, once that is sorted you can also set a bigger Min than Max value in the Tuning Center for simulating gearshifts.
    See the tips here on how to refine your motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
