My air-g-force prototype based on sfx 100
Discussion in 'DIY Motion Simulator Projects' started by wingert, Mar 12, 2021.
  1. wingert
    wingert Active Member
    684Coins
    4DOF
    have done modification with a second switched valve to vent bags faster, respectively to have in middle position both sides guaranteed vented.
  2. Gadget999
    12,072Coins
    can we see vid of it all working pls
  3. wingert
    684Coins
    4DOF
  4. Gadget999
    12,072Coins
    ok i understand what is going here - the piston volume is greater than the bag volume
    looks like it works pretty good :)
  5. Icebeat
    Icebeat New Member
    - 61Coins
    what hose diameter are you using? how about the Tube Fittings, any brand? I have a similar setup and my problem is air leaking.
  6. wingert
    684Coins
    4DOF
    hose diameter is 8mm, ordinary fittings from ebay no special brand. This is a open system puts atmosphere pressure to each cylinder side, refill it, in every middle position.
  7. wingert
    684Coins
    4DOF
    have built a another version no external valves, using 3D printed tubes with venting holes in the middle.
    20211104_104345.jpg 20211104_104345.jpg 20211104_104305.jpg 20211104_104245.jpg
  8. Gadget999
    12,072Coins
    did you make your own cylinders - did you use the old pistons ?
  9. wingert
    684Coins
    4DOF
  10. wingert
    684Coins
    4DOF
    I have expand it to simulate acceleration with 2 pads in backrest.
  11. wingert
    684Coins
    4DOF
    just a seat update
  12. wingert
    684Coins
    4DOF
    after a long period of testing and a split in a 3D printed tube, replaced with original tubes with tiny holes (4x3mm), given more boost. lateral_tubes4.jpg lateral_tubes2.jpg
  13. Gadget999
    12,072Coins
    Where did you get the cylinders from ? Are they pneumatic parts ?
  14. wingert
    684Coins
    4DOF
  15. Terje Helle
    Terje Helle New Member Gold Contributor
    138Coins
    My mind just got a little bit blown when I saw this.
    How do you feel it works? Have you any other motion on your rig?
  16. wingert
    684Coins
    4DOF
    it gives you a kind of pressure driving curves.
    Yes, a plattform mover SFX100 for suspension plus a front surge for braking, plus a airflow in back of seat for acceleration.Also for open cars a wind system for speed.
  17. Rainer Stehl
    Rainer Stehl New Member
    33Coins
    AC motor, 4DOF
    I am trying to build one similar to yours, but only with 2 450ml pads per side.
    I don't know how thick is the piston of my 160x100mm cylinder.
    Could you please tell me where you exactly bore the 3mm holes from the middle.
    My thoughts:
    When I assume that the cylinder is 180mm wide and the hub is 99mm (that is what I am measuring at the end...theoretically it should be 100mm) the middle is at 90mm and the cylinder ends 40,5mm from the middle on both Sides.
    So I have to bore the 3mm holes at 40,5-1,5=39mm from the middle if I want to close the gap completely or 40,5-1,0=39,5mm if I want atmosphere pressure in the middle position.
    Am I right?
  18. Gadget999
    12,072Coins
    I have been building my own air bag system over the last few days and have been testing it today
    It uses a single double acting pneumatic cylinder and a dc motor with a crank to actuate it back and forth. The motion is done using an arduino nano and SMC3
    The dc motor driver is an ibt2 and it has not been very sucessful so far. It keeps overheating and shutting down. I will swap it for a more powerful driver.
    There are 4 air bags, 2 on each side that are pumped up as the cylinder moves in and out.
    I will add a video and write up to my build thread soon
  19. wingert
    684Coins
    4DOF
    in my case the bores are 20 mm from the middle point, but this depends from thickness of the piston.
    The best method is disassemble the cylinder, measure the piston, so this is anyway necessary for burring the bores.
  20. Rainer Stehl
    33Coins
    AC motor, 4DOF
    Your work ist great! I am so happy that I found your thread: so much input.
