value1
Digital Combat Simulator – DCS Plugin 2.0.0.0
  1. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Thanks MarkusB for heads up on DCS_Exp
    It is brilliant! I have a 5 dof rig and, after the expected tuning each axis, all works really well. Nice having the easy facility to change the strength of the effects on the ground.
    Thanks again.
  2. Historiker
    9,208Coins
    Still using the pneumatic actuators Hugso?
  3. hugso
    hugso Active Member
    Glos UK
    611Coins
    Hi Historiker
    Yes, still working well with a few tweaks. Just upgraded my PC. I had given up with DCS with my old one. Literally a slide show when it eventually loaded. Brilliant now. Loaded in no time and I can fly round southern England with everything maxed at 160 fps or more. Even get 90fps at rooftop height over London. Still not gone VR yet. Have you tried VR?
    Have spent a long time getting Surge to feel right on take off. Finally got it now - seat moves forward a few inches and simultaneously tilts back giving a nice push in the back. All 5 axes feeling good. Using Roll rate gives a much better feeling than angle.
    Good to hear from you. Been tinkering with this on and off for a long time now.
  4. LeonSVK
    LeonSVK New Member
    Slovensko
    - 218Coins
    2DOF, SCN5
    i have problem with simtools 2.6 and DCS plugin... license is activated...
    152,676Coins
    +11,088 / 56 / -2
    There are a number of different DCS plugins, so can you please link to the one you are using.
  6. Kaneda
    Kaneda New Member
    84Coins
    Hello guys !!!
    We are agree they have not possibility to have extra 1 or 3 for sim with Traction loss actuators
    like Xplane or FS2020 (if i remember its extra3)
    Tuning center not receive Extra 1 2 or 3 informations :/
    I try with this plugin or expérimental (with anti Roll) but same issue
  7. yobuddy
    51,234Coins
    Please make sure your using the plugin installer with v2, and not installing plugins by hand.
    Take care!
  8. Kaneda
    Kaneda New Member
    84Coins
    Hello guys
    If you have any Idea for have extra 1 extra 2 or 3
    I try with both plugin but nothing :(
    Thanks you :cheers
  9. Richardamo1
    Richardamo1 Member
    307Coins
    Hi Guys
    did anyone ever get a working solution to the rollover issue in DCS,I have just completed my 1st 2 dof rig which works great other than nearly getting spat off when doing a barrel roll or vertical loop.
    Any suggestions would be gratefully received, i have tried the anti rollover function in 2d advanced ,but to no avail .
    Maybe it needs to be used in conjunction with other settings.
    I would have thought that just a max value for roll rate until reached would do it then just return to wings level rather than a violent return to center, which is also really hard on the rig
    152,676Coins
    +11,088 / 56 / -2
    Have you tried the Anti Rollover feature in SimTools:
  11. Richardamo1
    Richardamo1 Member
    307Coins
    Yup for sure ,tried that in 2 advanced but in isolation does little at all,I wonder if there is anything else that can be done as it spoils the whole experience,is there anyway of just limiting the roll to a fixed point then just return to wings level when you straighten out
    152,676Coins
    +11,088 / 56 / -2
    That is what Anti Rollover is meant to do.
    Have your tested Anti Rollover with just pitch and roll, with all other axis turned off? That way @yobuddy and others may be able to offer further advice.
    I am presuming you are using the plugin from this tread, but just want to confirm that as there are a number of DCS plugins.
    Can you please provide pictures of all of your settings, including Tuning Center.
    I see from existing images you have what seems to be excessive allocations like sway, which may complicate things as SimTools mixes all axis on the fly.
  13. hugso
    hugso Active Member
    Glos UK
    611Coins
    It is best to use Roll Rate. There is a plugin available called DCS_Exp which I am using and has the options to use angle or rate for pitch and roll.
  14. yobuddy
    51,234Coins
    This is what anti-rollover does, turn it on for roll and pitch, and then set the max/min values to -90 /90 and you should be good to go buddy.
  15. Richardamo1
    Richardamo1 Member
    307Coins
    Thanks as ever for the speedy replies.
    I will try this over the next 2 days
    I have a feeling that my understanding of the min max settings is incorrect.
    This could be as they say pilot error..
    Will report back once had chance to get stuck in again
    Thanks all again for your invaluable input
  16. Richardamo1
    Richardamo1 Member
    307Coins
    Cheers for that bud.
    Is that plugin available from the usual plugin page
    Thanks in advance for all your help
  17. Richardamo1
    Richardamo1 Member
    307Coins
    Thanks bud will track it down for sure.
    Thanks for all the input guys
  18. Richardamo1
    Richardamo1 Member
    307Coins
    Cheers bud.
    Will.track it down and give it a
    go for sure.
    Any help as always is much appreciated
  19. Richardamo1
    Richardamo1 Member
    307Coins
  20. Richardamo1
    Richardamo1 Member
    307Coins
    Hey yobuddy
    the -90/90 value ,is this set in the output rotational setting or somewhere else, i am using worm drive motors ,so should the output be set to rotational.
    Many thanks in advance
