Question 6 DOF 350W motors with IBT-2 43A H-bridge
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by fuad, Jan 23, 2018.
  1. Mick29
    Mick29 New Member
    143Coins
    Oh sorry for the translation.
    ok !
  2. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    That 6dof looks very compact.:thumbs what is its dimensions?
  3. fuad
    fuad New Member
    kuwait
    23Coins
    @Fluke find attached picture. the rig is done i will post more pictures soon. im testing and configuring it.
  4. absyfadhel1
    absyfadhel1 Active Member
    bahrain
    550Coins
  5. Gadget999
    12,035Coins
    just connect the + - and signal wires together so they produce half the current each
  6. absyfadhel1
    bahrain
    550Coins
    sorry i did not get it , is this picture the same?
  7. Gadget999
    12,035Coins
    That should work ok
    If you find my 6dof thread you will see some different drivers I use 200amps
  8. absyfadhel1
    bahrain
    550Coins
    is there any powerful board to replace it with ibt-2?
  9. Gadget999
    12,035Coins
  10. absyfadhel1
    bahrain
    550Coins
  11. Gadget999
    12,035Coins
    yes - it can drive 2 motors - it uses pwm and direction pins same as ibt-2
  12. absyfadhel1
    bahrain
    550Coins
    what is the board name so i can order it from amazon?, becuase my ibt-2 cut the power from the motor
  13. absyfadhel1
    bahrain
    550Coins
  14. Gadget999
    12,035Coins
    yes - that looks like it
  15. absyfadhel1
    bahrain
    550Coins
    great, sorry for annoying, you think this driver could run 2x 12v 300w motor? , becuase my ibt-2 cut the power from the motor when there is force while the motor can take force via direct cable to psu? , so you think this driver will make it work?
  16. Gadget999
    12,035Coins
    yes - it can handle 100a continuous and 200a momentarily
  17. Billel
    Billel Member
    195Coins
    T
    the wiring on the bottom motor is wrong, the positive and negative wires of the motor should go to each of the two IBT2 (in the picture, the positive goes to 2 pins of one IBT2, and the negative goes to 2 pins of the other IBT2)
