Question Homemade 2 DOF motion simulator
Discussion in 'DIY Motion Simulator Projects' started by Witvrt, Feb 13, 2021.
  1. noorbeast
    152,277Coins
    +11,066 / 56 / -2
  2. Witvrt
    Witvrt Member
    127Coins
    just check and changed the regional settings to English as well removed axis limiting/startup and shutdown settings. Unfortunately without any change in behavior o_O
    152,277Coins
    +11,066 / 56 / -2
    Did you restart the computer?
  4. Witvrt
    Witvrt Member
    127Coins
    I tried following all your advice and made all the changes as suggested. The problem however continued to exist on my laptop. Installing the software on a new, fresh installed virtual machine did the trick. So I suppose, removing and reinstalling the software on my own laptop will work as well. Big thanks to you noorbeast :thumbs
    Now the last bit, tweaking. All suggestions are welcome.
    My config :
    2x dual Motomonsters
    2x 50A 12V Power supplies
    2x 90Zyt-155-12 25:1 motors
    :popcorn
    152,277Coins
    +11,066 / 56 / -2
  6. Witvrt
    Witvrt Member
    127Coins
    Hi guys,
    I have question about the settings in SMC3. I was doing some testing with load and I found out that the left motor stopped working while it was tilted to the left o_O. What setting should I adjust in SMC3 to prevent them from shutting down when they almost reach there max limits. Should I use PWMMin and PWMRev ?
    This is a picture of my settings in SMC3.
  7. Witvrt
    Witvrt Member
    127Coins
    I've read that PWMrev should have similar a value as PWMmax. What would be a safe value in my case?
    152,277Coins
    +11,066 / 56 / -2
    Shutting down can have a number of causes, but start by refining the SMC3 settings, which should be refined for your specific hardware.
    I would expect Clip Input and Max Limits to first be refined, followed by other settings.
    See the SMC3 instructions here re settings functionality: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    While written with JRKs in mind see this simple introduction to PID, which links to more hardcore information, depending on how far down the rabbit hole you want to go: https://www.xsimulator.net/community/faq/a-laymans-analogy-guide-to-pids-pid-tuning.219/
  9. Witvrt
    Witvrt Member
    127Coins
    Hi guys,
    I was doing some tests with the max limits and clipping input of SMC3 and I want to enable reverse braking.
    What I do not get is how I can get these max/clipping limits further away from my tipping point. (and only limiting my range of movement and increasing my range of protection)
    The only thing that seems to happen when lowering the Max limits is that the maximum range of movement is growing.
    Am I missing something or does Simtools use the max/clipping settings set in SMC3 in combi with the axis range defined. (ex. surge set to 20 % clipping happens at about 18 % max limits and max limits at 20 %)
    If anyone can explain this, please let me know.
    152,277Coins
    +11,066 / 56 / -2
    SMC3 sets the range and controls for the motors.
    SMC3 should be configured and working as expected before messing with SimTools.
    SimTools Axis Allocation lets you split the total range into allocations for various axis, SimTools mixes the axis allocations on the fly, grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
  11. sulfail
    sulfail Member
    Mason
    vigo(pontevedra) SPAIN
    205Coins
    Remember before putting the seat on the platform, look for the perfect balance point, being your mounted on the seat, more or less with the exact position in which you will drive, the more balanced it is, the better for the engines, another option is to balance it later with rubbers or springs, but that is the key point, you can do it simply sitting on top of a round stick, until he finds the balance.
